Author | Topic: Bushings |
EarlB Prowler Newbie From:Winter Springs, Florida, USA |
posted 05-21-2011 06:14 PM
Can anyone tell me if these bushings,(See Photo all 4 are shot) can be replaced or do you have to replace the stabilizer bar and bushings? In either case, can anyone recommend replacing them with a Chrysler part or another supplier? How difficult is it to replace? A lot of questions. Any help would be greatly appreciated. |
posted 05-21-2011 06:35 PM
http://www.prowleronline.com/ubb/Forum21/HTML/000013.html Look here and you will find a great replacement by one of our members here on POA. Send Spoons a PM and he should be able to take care of your needs. I installed these on my Dad's Kat and at some point will get them for mine. This message has been edited by alrtg on 05-21-2011 at 06:38 PM |
posted 05-24-2011 08:16 PM
Earl, Don't feel bad. Everyone has had those side seals crack and fall apart. If you perform a search you will find many different fixes from the .50 cent cure to the $50 dollar + cure. I went thru this years ago and the basic answer is 'no they are not shot'. Only the cover went south. You can clean off the grease and remove any remaining side seal and run them like they are. It would take many years for the joint to loosen up since a secondary seal is on the ball if you take a close look. Bad material choice by the supplier. |
stprinz POA Site Supporter Prowler Junkie From:ITALY |
posted 05-25-2011 12:41 AM
I just installed the ones from spoons. They Are great. quote: |
