Author | Topic: Waterpump ???? Thermostat ?? |
PHATCAT Prowler Newbie From:Dallas, Texas,USA |
posted 07-09-2008 07:25 AM
Hey guys I need some prowler advice here if possible?? I will keep it short , I have a 2001 prowler and yesterday while sitting in the drive thru my car started to over heat, what caught my attention was the check gauge light came on and by that time it was buried in the hot zone , ALOT of antifreeze shot out from the bottom ,not sure if it came from the weep hole down by the block or from the over flow but from what it looks like underneath the car is that all the fluid shot out the weep hole and I means lots , reason why I ask if it could be a water pump ??? I have added fluid back and now car will not leak a drop of water but still over heats ??? does this sound like a waterpump or maybe a thermostat ??? I'm clueless , I'm taking car in today for a diagnosis , was just hoping there was something I can try myself to save money , I received a price quote from the dealer to replace waterpump and 775.00 big ones !!!!!! WOW !!! wish I had bought the extended warranty !!! |
posted 07-09-2008 08:32 AM
Call my cell phone.. 214-557-1084 Brad |
bowton POA Site Supporter Prowler Junkie From:Walla Walla, WA. USA |
posted 07-09-2008 10:42 AM
Hey Phatcat, Just replaced my water pump on Saturday. Give me a call at 509-525-1107 if you wish. Sounds like a stuck thermostat to me. The "weep hole" most likely will produce only a hand size puddle of fluid in twenty-four hours with a bad pump. A defective radiator cap can cause major fluid loss through the overflow tube and overheating of the engine. If the pump is bad and needs to be replaced, be sure to replace the engine timing belt which also drives the water pump. Good luck, Larry Bowton ------------------ |
posted 07-09-2008 05:41 PM
make sure you also refill with distilled water,and zerex g05 coolant,ita a long life coolant and will stay cleaner than the original green. ------------------ |
posted 07-09-2008 10:15 PM
Something has happened, but if it lost much fluid up probably have an air pocket. Whenever adding antifreeze you should open the vent in the front of the engine to get all the air out Have not had to do this to mine but one owner did here at the house when his was running hot. Seemed to take care of the problem. It looks like a bleeder for the brakes. A small tube can be put on it to keep the antifreeze from going all over the engine. Located front center on the engine, but not 100% sure where to tell you to look and my car is not at the house to look at. Good Luck ------------------ |
posted 07-09-2008 10:16 PM
did you bleed the system after refill. ------------------ |
posted 07-10-2008 06:55 AM
Sorry for the late response but anyway I just ended up taking it to Neal who is a awesome mechanic who works at Preston Dodge here in Dallas and he is going to fix the issue , once I find out what the issue is I will let you guys know. I appreciate all your feed back and help , this site is GRRRREAT !!!!! Thanks again for the advice will use for future !!!!! will talk to you soon |
posted 07-10-2008 09:42 AM
Well the verdict is in and its the water pump !!! I hate to say it AGAIN but i should have bought the extended warranty !! live and learn !! Again i appreciate all the advice and will talk to you soon !!!!!! |
posted 07-10-2008 04:47 PM
PHATCAT.. Josh, I went by and looked at your car up on the rack. Sorry to say, but it for sure is the waterpump. Lots of stains from the water leaking thru the bottom of the pump. You already know that you are in good hands with the Preston Chrysler folks. It was kinda cool seeing 3 Prowlers in the Prowler Bays. Good luck. PS.. Your tires look good... Wana trade?? |
