Author | Topic: TRUE OR FALSE |
joe cat Prowler Junkie From:Lancaster, Pa, USA |
posted 09-22-2007 09:09 PM
THE SERVICE ENGINE LIGHT GOES ON WHEN THE OIL NEEDS TO BE CHANGED??? OR WHEN THE FLUIDS ARE LOW??? IF SO HOW DO YOU RE-SET IT YOURSELF?? THANK YOU JOE CAT |
posted 09-22-2007 10:00 PM
False, The Prowler does not come with a water or oil monitor. You can reset it with a OBII reader , providing there are no problems, If there is a problem with one of the sensors , the light will come right back on. This message has been edited by phil2237 on 09-22-2007 at 10:01 PM |
posted 09-22-2007 11:06 PM
quote: Somewhat TRUE Very low or no engine oil,,,,,,,crank breaks,,,,pistons explode with connecting rods through the side of the block,,,,,you roll to a stop >> chances are the Check Engine light is now ON |
LAwil POA Site Supporter Prowler Junkie From:Southern Calif. |
posted 09-23-2007 03:42 AM
WOW Larry. Good to know. |
posted 09-23-2007 07:43 AM
Joe cat, I get an intermittant check engine light when I let one of the Cats sit too long without firing it up. The start-up will have the engine stumbling and grumbling and will misfife one time and walla, here comes the little light. Have also has it come on when I used the wrong key in the door, or didn't have the gas cap on tight. I just pull the disconnent switch I installed on the batteries and leave off for some 20 min., and it will reset itself. If it comes back on, time to get the trouble code read. |
Snoman unregistered Admin Use |
posted 09-24-2007 09:46 PM
posted 09-26-2007 06:13 AM
Thanks y'all. I disconnected the battery and BINGO its off! JOE CAT |
posted 09-26-2007 08:39 AM
JOE, Don't forget to reconnect the battery before you try to start it again... or you may think something else is wrong. |
