  Technical Questions & Answers
  Turn Signal Troubles..mystery solved... fixed (Page 1)
   Bottom of Page
This topic is 2 pages long:   1  2
next newest topic | next oldest topic
Author Topic:   Turn Signal Troubles..mystery solved... fixed
halicat
unregistered
posted 05-13-2006 03:42 PM           send a private message to Marty Usher   Edit/Delete Message   Reply w/Quote   Search for more posts by halicat
I've been having troubles with my passenger side turn signal. It works sometimes....and sometimes it flashes fast in the rear, but nothing in the front.
heres what I know...
its not a bulb
its not a bulb socket...
its not a side light problem...
its only the front....
the emergency flashers work fine...
could it be the flasher relay up by the steering wheel just affecting one side ?
I don't know how to use a multi meter...
If anyone has some ideas it would be greatly appreciated....
Thanks
Jim
This message has been edited by halicat on 07-10-2006 at 04:45 PM
Dave Mills
posted 05-13-2006 04:16 PM     Click Here to See the Profile for Dave Mills     send a private message to Dave Mills   Edit/Delete Message   Reply w/Quote   Search for more posts by Dave Mills
I was having a similar problem but in the rear. It turned out to be a loose plug in the wiring harness near the rear of the car. The only way we found it was to to trace the wiring harness back from the lights. We fixed the plug and now my lights are fine.
ALLEY CAT
posted 05-13-2006 04:43 PM     Click Here to See the Profile for ALLEY CAT     send a private message to ALLEY CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by ALLEY CAT
Hand signals
halicat
unregistered
posted 05-13-2006 05:43 PM           send a private message to ALLEY CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by halicat
Originally posted by ALLEY CAT:
Hand signals
I only know one...
and everyone gets mad when i use it......lol
idive
posted 05-13-2006 10:59 PM     Click Here to See the Profile for idive     send a private message to idive   Edit/Delete Message   Reply w/Quote   Search for more posts by idive
There is a thread someone made a while back compiling everyone's troubles on one thread. I posted mine there (page 3 I think). I had the same problem with my 97. I think they said it was a short in the harness. Fixed under warranty so I don't know what they did. But I believe they told me it was a harness short. I think a couple others have had this problem as well. Good luck. (DC reimbursed me for the bulb I bought that didn't fix the problem.)
halicat
unregistered
posted 05-14-2006 03:12 PM           send a private message to idive   Edit/Delete Message   Reply w/Quote   Search for more posts by halicat
Sounds as though I'll be off to the dreaded Chrysler Dealer with this one....
If anyone can think of anything I can try it would be great...
hasn't worked right for 2 days now... !*@#
I have no warranty..
This message has been edited by halicat on 05-14-2006 at 03:12 PM
ALLEY CAT
posted 05-14-2006 03:37 PM     Click Here to See the Profile for ALLEY CAT     send a private message to ALLEY CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by ALLEY CAT
No warranty left? I feel your pain,,,,I'll pray for you son. @ $125 usd per hour,,,they should have you back up operating in about two hours or so
Jimbo - I'd let this thread run for a few more days [entire week],,,,,maybe someone else will read with a suggestion
halicat
unregistered
posted 05-14-2006 04:25 PM           send a private message to ALLEY CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by halicat
I swear........
Dealers break stuff just to get ya back in....
I have one dealer I kinda trust, but they are an hour drive away and worked on very few Prowlers...
I'll hang on for a while...
TooHipCat
posted 05-14-2006 04:28 PM     Click Here to See the Profile for TooHipCat     send a private message to TooHipCat   Edit/Delete Message   Reply w/Quote   Search for more posts by TooHipCat
Originally posted by halicat:
I only know one...
You're supposed to use the thumb Jim...the thumb!!!
halicat
unregistered
posted 05-14-2006 04:41 PM           send a private message to TooHipCat   Edit/Delete Message   Reply w/Quote   Search for more posts by halicat
I thought the finger i was using meant "do not pass"
halicat
unregistered
posted 05-20-2006 09:50 AM           send a private message to TooHipCat   Edit/Delete Message   Reply w/Quote   Search for more posts by halicat
Any hints of what to try before i take my Kat to be violated by the dealer ?????
could it be the turn signal flasher thingy ?
We may set a record for this thread for being "least helpfull".....
come on guys... i'm dying here...
ALLEY CAT
posted 05-20-2006 10:12 AM     Click Here to See the Profile for ALLEY CAT     send a private message to ALLEY CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by ALLEY CAT
quote by Mike,,,years ago:
The Body Control Module (BCM) is programmed to sense the current from the running lights, turn signal/stop light bulbs and flashes rapidly if there is a problem. It will also illuminate both turn signal indicators on the dash when the turn signal is not on. It's programmed that way to let you know if your bulbs have gone bad or if there is a wiring problem. The tail lights and front turn signal bulbs both have two filaments, one for running lights and another for turn signals and in the case of the tail lights both running lights and turn signal/brakes.
Go outside the car and check both front and back turn signals left and right and I would bet that one of the bulbs is bad if not, you either have a wiring problem or the BCM is defective.
The same holds true for the TGF bumper delete kits (I have second generations and they do it). There are LED's in place of the front bumper lights and the indicators and turn signals will flash rapidly because the LED's draw less current and they don't use the running lights. The Tom Mills and Real Rod kits utilize stock bulbs and will act normally. Perhaps TGF has recently changed theirs, so maybe Norm or Bob will jump in and let us know.
Mike Krehel
Also: http://www.prowleronline.com/ubb/Forum2/HTML/000118.html
Let's help this poor soul out!!!
This message has been edited by ALLEY CAT on 05-20-2006 at 10:15 AM
MDProwler
posted 05-20-2006 12:05 PM     Click Here to See the Profile for MDProwler     send a private message to MDProwler   Edit/Delete Message   Reply w/Quote   Search for more posts by MDProwler
Hali,
Check the harness and plug on the front signal that does not work when the problem occurs. Remove the bulb and make sure the socket is not corroded. try plugging in the other side into the bad side(I think the fronts will reach) and see if that side starts working. If you plug the other side in and it works the problem would be in the bumper wiring /socket/bulb.
Or you could just sell it on ebay and get one with lights that work!
halicat
unregistered
posted 05-20-2006 01:19 PM           send a private message to MDProwler   Edit/Delete Message   Reply w/Quote   Search for more posts by halicat
Thanks guys...
I've switched the left side bulb and harness with the right side and the same side doesn't work...... so its from there back.... The emergency Flashers work perfectly...Ac sent me some reading on the problem so i'll see if there is something there that will help....
simply put:
when turning right the rear signal light blinks twice as fast as it is supposed to, and the front doen't blink at all......or even light up......
halicat
unregistered
posted 06-27-2006 02:51 PM           send a private message to MDProwler   Edit/Delete Message   Reply w/Quote   Search for more posts by halicat
thought i'd bump this up as my Turn signal still doesn't work and I've been unable to determine what the problem is....
Any ideas ???
Kruisin Kat
posted 06-27-2006 04:20 PM     Click Here to See the Profile for Kruisin Kat     send a private message to Kruisin Kat   Edit/Delete Message   Reply w/Quote   Search for more posts by Kruisin Kat
Hali, I'll take a stab at this. I would check any and all ground straps for corrosion at the place of contact (bolt, screw or clips) you may have one that is loose or not getting good contact somewhere could even be disconnected. Check all of them everywhere.
It is time consuming but doesn't cost anything and it just might work.
Good luck.
This message has been edited by Kruisin Kat on 06-27-2006 at 04:22 PM
halicat
unregistered
posted 06-27-2006 04:34 PM           send a private message to Kruisin Kat   Edit/Delete Message   Reply w/Quote   Search for more posts by halicat
Thanks KK,
I'm going to replace all the bulbs then if that doesn't work I will trace everything to check the grounds. that must be it... as it only did it when it rained or I washed the car at first... its pretty much out of commission totally now ....any and all help is greatly appreciated...
catfish
posted 06-27-2006 09:13 PM     Click Here to See the Profile for catfish     send a private message to catfish   Edit/Delete Message   Reply w/Quote   Search for more posts by catfish
i know you say its not the bulb but replace it and see what happens.sometimes the filament will be broken on one end,pull the bulb and hold it buy the base,flick the bulb w/your finger while watching the filament,if its loose you will see it move.
halicat
unregistered
posted 06-28-2006 06:26 AM           send a private message to catfish   Edit/Delete Message   Reply w/Quote   Search for more posts by halicat
jan,
is it possible that a rear bulb gone bad make the front bulb act up ?....
I'm going to replace all the bulbs today, trace back and check the grounds, if this doesn't work, i'll replace the turn signal relay.... if all this fails, it off to the dealer..
Thanks for your help
Ray
unregistered
posted 06-28-2006 06:55 AM           send a private message to catfish   Edit/Delete Message   Reply w/Quote   Search for more posts by Ray
Good luck with the do-it-yourself portion of the 'fix' ... mine did this a long while ago and it was the bulb had come out of the holder in the side panel but still in the socket and broke the filiment while dangling inside the engine compartment. I didn't notice because I don't 'see' the side of the car flasher when turning. Replaced bulb and was fine ... Please share your results and hopefully you can avoid the dealership ... just ask Red5 about this too!
catfish
posted 06-28-2006 11:17 PM     Click Here to See the Profile for catfish     send a private message to catfish   Edit/Delete Message   Reply w/Quote   Search for more posts by catfish
halicat,yes if the one bulb back or frt.goes out it will make the other bulb blink faster than normal.good luck,let us know what you find.
Prowl 36
posted 07-03-2006 05:00 PM     Click Here to See the Profile for Prowl 36     send a private message to Prowl 36   Edit/Delete Message   Reply w/Quote   Search for more posts by Prowl 36
If all that fails, run a new wire from the back turn signal flashing light. Turn the signal on and test which wire is the hot one that is flashing and run it to the front. Just a easy fix if you do not want to take it to the dealer. I HATE TAKING MINE IN!
Tony Goertz
Administrating Kat
posted 07-03-2006 06:33 PM     Click Here to See the Profile for Tony Goertz     send a private message to Tony Goertz   Edit/Delete Message   Reply w/Quote   Search for more posts by Tony Goertz
halicat - sorry I missed this post earlier. What year is your car? There are two 97s in my area with a similar problem. Sometimes the front DRL is on and sometime not. Sometimes the front single light works, sometimes not. ( I can't remember if it was the driver or passenger side)
Since two cars had the exact same problem and both are Canadian cars - I expected that the problem is the DRL module but have not yet dug into the problem further.
- idive - could your 97 have been a "Canadian" car.
-- TonyG
halicat
unregistered
posted 07-04-2006 10:07 AM           send a private message to Tony Goertz   Edit/Delete Message   Reply w/Quote   Search for more posts by halicat
Hi Tony,
thanks for the info... mine is a 2000 , i think it may be the flasher relay. I'm going to replace it this week and will post my results......maybe the daytime running module is the culprit... keep me posted if you find anything out...
Jim
idive
posted 07-04-2006 03:40 PM     Click Here to See the Profile for idive     send a private message to idive   Edit/Delete Message   Reply w/Quote   Search for more posts by idive
Tony - My 97 is not a Canadian car. I bought it new from a local dealer. It was 1 of 5 delivered to Houston around July or August 97, along with Mr. K's 97.
(With a build date in August, I guess it wasn't delivered in July... LOL)
This message has been edited by idive on 07-07-2006 at 11:24 PM
