Author | Topic: trailer hitch help!!! |
posted 10-05-2002 07:36 AM
The dealer took the hitch off the old cat and returned it to me, now going to install on the new one, I remember drilling two holes in the frame at the time but I cant remembe the location or size and want to install this on the new car anyone have a set of instructions and could pass on this info to me?? please PM or post the info. thanks ------------------ |
posted 10-05-2002 07:41 AM
If you do not have them yet call me monday and I will fax them to you 952-873-6626 |
posted 10-05-2002 07:59 AM
Thanks Bob curtis |
prowlerbabe POA Site Supporter Prowler Junkie From:Treasure Island, Florida |
posted 10-05-2002 12:50 PM
Block buster, aka: SUNKIST (cool choice-but I still like Fuzzy Navel) Drill two 1-1/8" access holes (one each side)into the rear face of the frame crossmember using the existing holes in the vertical plates of the hitch assembly as a guide. (I used a hole saw attachment with an electric drill-need that extra power a cordless drill doesn't have) Drill four 7/16" holes (two each side) into the bottom of the frame crossmember using the existing holes in the horizontal plates of the hitch assembly as a guide. Insert two nut plates into the access holes (one each side) and align them with the 7/16" holes in the bottom of the frame crossmember. If you need more instructions, let me know, I'll post here or email for you. Good luck! Kendra This message has been edited by prowlerbabe on 10-05-2002 at 12:50 PM |
posted 10-05-2002 09:27 PM
PB: thanks for the answers to my question I think that will jar the memory buttons in the back of the cobbwebs somewhere, printing right now. thanks |
posted 10-06-2002 01:25 AM
Blockbuster, Tami, and Kendra - just installed the hitch today on the Alley Cat. Took MadMax and I four hours, several beers, swearing, bs ing, and some laughs to finish. Done deal now. Curtis, aren't you missing two nut plates left in the bottom of the frame of your old cat? Can't see how you could get them back out after once dropping them down into the 1 1/8" hole???
Did any of you 'plug' the 1 1/8" hole you drilled into the frame??? MadMax concluded that water would enter the hole and over a long period of time could cause corrision to occur. Max cut the bottoms off of some small plastic bottles that fit just perfect to plug the holes up. After setting the nut plate into the hole to bolt up the bottom of hitch plate, the holes become useless. Just a thought to ponder ------------------
posted 10-06-2002 01:40 AM
AC, only took me a couple of hours the first time, but then I didnt have any beer, yes I got the plates out of the old car, may put it on this weekend not sure kinda busy but dont want to get caught with a place to go and cant pull the trailer also have to wire in the third light to the car but the harness is already in. block-buster (curtis) |
posted 10-06-2002 09:50 AM
AC: Glad to hear that you got the hitch installed! Did you have it chromed? Bet it looks good! Good idea about the bottle bottoms - didn't even think about that. Very good point! T |
posted 10-06-2002 11:57 AM
Tami - not chromed, but going to put a strip of polished stainless on the facia going across the hitch for that appearance look. Removed the decals and placed them on the underneath side of the hitch. While we had a good time installing the hitch, I wouldn't want to do it everyday. The BEAT goes on,,,, |
posted 10-06-2002 06:23 PM
Hooray for AC! I knew you could do it. If it weren't for the beer, swearing & bs ing, I bet you could have had it done in 2 hours. Hope I get to see the Alley Cat some day. Kendra |
