Author | Topic: 345-25-20 Pirelli |
343RWHP Prowler Newbie From:Chandler, AZ |
posted 06-05-2002 01:20 PM
Anybody run this tire on the rear? Does the width clear? This tire would add two inches in width (one inch on each side) From what I can see I think I'm going to order some and give it a try. It's 2 inches shorter so the speedo will be off by about 6% |
posted 06-05-2002 01:25 PM
Dunlops are a much better choice, ride is doubled with pleasure(way better ride). They don't hook up as well as the stockers, I think the Dunlops look way better. There is already to much tire on the rear of the stock tired prowlers. JMO ------------------ |
posted 06-05-2002 01:30 PM
quote: Too much tire? When you ran your 12.70, you had no traction problems whatsoever? I can absolutly toast my 295's on the street all day long. (paxton and gears) Dunlop doesnt make anything close to a 345-25-20. |
posted 06-05-2002 01:40 PM
Don't get me wrong. I really had to drive the deal to go 12.7, rolled out very easy for 6-8 feet, 60 ft times sucked with a 1.91 was my best. 13 lbs of boost BTW. ------------------ |
posted 06-05-2002 01:41 PM
I had wanted to put the same size rear tire the concept car had, which I believe was a 315/40/20 (?). Where can you get the 345/25/20 at? ------------------ MTD Prowler Intake System 2.2 |
posted 06-05-2002 01:43 PM
click here ------------------ |
posted 06-05-2002 01:52 PM
My only concern if the tire fits is that the car might look a little "off" with the tire being two inches shorter. Would have to get a shorter front tire also and then have the car lowered 2 inches. Who makes a lowering kit for the Prowler? |
posted 06-05-2002 01:55 PM
343, no one as of yet on the lowered deal. I thinks we need to be patient, more 20" tires should be produced in the future, ya think? |
posted 06-05-2002 03:58 PM
quote: A 335-35-20 would be the same height as factory, that would be cool. Over the next year there will be TONS of new sizes in 20 inch thru 24 inch tires. |
saber Prowler Enthusiast From:burbank califonia usa |
posted 06-06-2002 01:02 PM
Dunlop is coming out with a 315-40-20 in 2 months I just talk to them on 6/5/2002. ------------------ |
posted 06-07-2002 12:17 PM
Just a Note : The Electronic Ratio Adapter that was used with the G-Force gears to adjust the speedo can be set to compensate for tire size changes as well. ------------------ TonyG@ProwlerOnline.com |
posted 07-07-2002 02:10 AM
Has anyone gone to larger sizes? Please post if so. I would also like to go to wider sizes. Mostly for looks, but I think the car will brake slightly better with wider fronts. ------------------ |
posted 07-08-2002 08:33 AM
quote: I went with the stock size in the rear for the time being until I find a larger size I like. I had ordered 235/45ZR17 tires for the front but cancelled my order when Tire Rack contacted me to inform me it was not a recommended size. I do intend to put 235/45ZR17 on the front within the next couple months. They are .9" wider and only .4" taller than stock. ------------------ MTD Prowler Intake System 2.2 |
posted 07-11-2002 10:49 PM
Bill, Sounds like we are on the same wave length. I too would like to go with 235/45 up front, just wondering if it will rub in any way. ------------------ |
posted 07-12-2002 09:52 AM
quote: JP, |
posted 07-12-2002 01:26 PM
Trust me on this, if you go with a wider tire on the front, the car WILL dart around more. It will follow every surface and rut change in the road. I have a LOT of experience with larger and wider tires and the front end will suffer. The rears are no problem. JRL |
