Please Donate to the Prowler Owners Association | To post on these forums, you must register a username. It's completely free and takes only 30 seconds. Register Now! |
Off Topic Discussion Need help with other then Prowler
Author | Topic: Need help with other then Prowler |
posted 05-14-2009 09:20 AM
I would like to change the oil in a 1951 Chrysler with a Fluid Drive Transmission, I have heard the oil for the converter is with the oil pan for the engine and takes about 13 quarts? Is it all drained with the pan plug? Do you drain the converter separate? WOW over 50 years in the business and can't do a oil change,pretty sad. Any help would be nice. thanks |
posted 05-14-2009 09:41 AM
Maybe this site can help you. http://www.imperialclub.com/Yr/1951/index.htm |
posted 05-14-2009 11:08 AM
CURTIS, Nice to see you post.. I miss you my friend!! Sorry, but I was only 4 years old when that car came out. LOL Your friend.. Brad |
posted 05-14-2009 01:44 PM
Should be an inspection cover on the bottom of the bellhousing, remove it, rotate the torque convertor around till you find the plug on the convertor, remove and drain. |
posted 05-14-2009 04:26 PM
Hy-Drive was the trans using the engine oil (not Fluid Drive) for 1953 & 1954 Plymouth, Dodge, Desoto. ------------------ |
posted 05-14-2009 09:39 PM
Hi guys: I have the owners hand book from the glove box it is a Fluid-Matic Drive Transmission, the Capacities section says that the engine oil is 5 quarts plus one for the filter and the fluid-matic refill is only 3 pints. Just found this book today and also found a service manual online which I ordered. So guess is not the Hy-Drive of 53 54 fame. Thanks for all the help. Thanks again Curtis |
All times are CT (US) Top of Page Previous Page | Return to Off Topic Discussion next newest topic | next oldest topic |
