Please Donate to the Prowler Owners Association | To post on these forums, you must register a username. It's completely free and takes only 30 seconds. Register Now! |
Author | Topic: a couple pics of progress |
MetalWithGrace POA Site Supporter Prowler Junkie From:Seattle, WA, USA |
posted 12-22-2007 10:18 PM
Sorry guys, I wanted to be finished with the first by now but I had to stop and get some more consumables, smaller collets, and smaller weld rod and I am moving a little more slowly with the flu.. this picture shows the differences in the patterns from the M&L grille and the stock grille.. I had to change my patterns and bucks for fit.. this illustrates why. ------------------ |
posted 12-22-2007 10:20 PM
Thanks for the update |
posted 12-23-2007 05:26 AM
Grace Very cool toys |
posted 12-23-2007 09:04 AM
One of the more difficult aspects of this project is bending the surround on the grille.. 11 gauge stainless doesn't like to bend much. That is why I made the bending buck that you see pictured above.. made of layers of plate steel and cut to shape that piece enables me to have something to work over which will give me a consistent shape over and over again.. After bending Pantera's grille surround and getting a good fit and correct lines from my modified pattern I decided to cut, clean up, and prep the first ten. I worked many long hours and I have the first eight ready. I am going to go home and get some much needed rest and be back at it later today.. videos coming soon.. I am having my daughter put one together (she does all of my videos).. ------------------ |
posted 12-23-2007 03:28 PM
This girl is no fluke, I just watched her in a video and she knows what she is doing... onecatnodog |
posted 12-23-2007 06:21 PM
Here is the Video I saw... http://www.metalwithgrace.com Click on it if you are interested... onecatnodog |
posted 12-23-2007 06:36 PM
Just watched the video. Next time we are out there to visit our son, I will try and stop by. |
DRIVER POA Site Supporter Prowler Junkie From:BELLEVILLE , NJ |
posted 12-24-2007 12:12 PM
Keep up the good work,don't worry about time, QUALITY is much more important. You are an inspiration to all us metal knockers! |
posted 12-24-2007 02:10 PM
Thanks for the great comments, and the support.. I will be working on these until the quality is what I want.. I will make all of my supporters proud! I need a smaller collet for my tig welder so I am not blowing so much gas off, and the puddle is more controlled for the tight edges I am welding in. The people I get my supplies from have been closed since thursday, so the moral to the story is that I likely won't finish Pantera's grille until Wednesday or Thursday.. On the bright side, since my patterns worked out so well and since everything is fitting how I want it to, I cut out and am cleaning up the first 12 shells.. so when I get what I need for the welder we should have a lot going out.. I am leaving my shop for a bit.. I will be back for a while this evening but spending Christmas with my girls tomorrow. Merry Christmas to all!! ------------------ |
TaxKat POA Site Supporter Prowler Junkie From:Huntington Beach CA |
posted 12-25-2007 10:47 AM
Enjoy your day with your girls Merry Christmas to you and your family |
JohnC POA Site Supporter Prowler Junkie From:Kechi, KS 67067 |
posted 12-26-2007 06:07 PM
Has anyone heard how Grace is doing? Hopefully the flu bug didn't wipe her out too bad. ______________________ JohnC - Kechi, KS |
posted 12-26-2007 06:53 PM
I am happy to say that I survived my flu.. actually got a good number of hours in on getting shells ready while I was ill.. (don't worry they still match the pattern ) I was able to pick up my welding supplies today and am finishing the surrounds and welding tonight.. will have pics, will have one finished.. but likely late.. I go home in the early evening to make dinner and then I will be back tonight to finish this one out.. but since I have all of my supplies I doubt anything will get in my way of getting done... Not nearly soon enough to suit me, but I am happy all the same.. ~Grace
posted 12-26-2007 09:04 PM
Grace Hope your Christmas was Merry. Thanks for the update toys |
posted 12-27-2007 02:18 PM
okay.. so I have about a dozen shells prepped.. they fit really nicely.. the new framework makes for a simple install.. but, I had to change the patterns last week, so now all of the bars have to be remeasured.. My welder was still having trouble and after troubleshooting they have agreed that there is likely trouble with my shielding gas, so I am off to pick up a new canister in the morning. For now I have enough surrounds and bars prepped for nearly a dozen, thanks to my bad shielding gas the first grille is garbage, I could fix it but it wouldn't be as good as fresh, so it becomes a permanent pattern,.. I am going to run home and take a nap since I worked all night.. things are going very well.. just a couple little adjustments.. please note that the above part is not a final piece.. and the nose it is on is a test fit buck that I am using.. thanks ------------------ |
posted 12-27-2007 10:14 PM
Well, there's certainly ample airflow on that one. Speaking of airflow, what ever came of any airflow tests that were run? Or have they been run yet? (Yes, I know you gotta have one made to do the tests, but it seems to me that there is a go on the current pattern, and I missed any test results post.) |
posted 12-27-2007 10:34 PM
the difference in the gapping on the bars is nominal, but I will run tests when I have the first one fully together, I am picking up a new weld canister in the morning, I cut cleaned and polished parts today so it should go together quickly and I will have better information then, I will let you know what I find. ~Grace |
posted 12-28-2007 04:19 PM
I have an engineer coming with an animometer so we can test the exact airflow changes. They will be here Tuesday or Wednesday, I will post a full report. : ------------------ |
thomas leuschner POA Site Supporter Prowler Junkie From:e.islip,ny.,usa |
posted 12-28-2007 05:16 PM
Grace Is the outter shell going to be that thickness or is it going to be thin like the other picture. |
posted 12-28-2007 05:24 PM
Okay, got clarification.. the part seen in the pictures is the inner shell which mounts into the car, which the bars affix to, this is not the visable edge.. the edge you will see after the bars goes on appears about the thickness of the bars.. it is 1/2 inch, but tapers out so appears a little smaller.. ~Grace This message has been edited by MetalWithGrace on 12-28-2007 at 05:51 PM |
posted 12-28-2007 06:15 PM
Grace, Just to make sure I understand (along with everyone else) regarding the edge treatment of the grill: Are you saying that the exposed edge will be about the same size as each of the tubes? I tried to include a picture below for clarification: I think one of the most appealing factors of your design is that there is not a wide surround or frame going around the outside of the grill. At least it's the most appealing factor as to why I'm buying one. On a side note, does anyone know where to get one of those hood emblems? |
posted 12-28-2007 06:18 PM
yup.. correct.. that's what he was asking about.. the outer edge is not thick.. : the emblem seen here is a vinyl sticker that M&L had made.. ~Grace |
prowler6 Prowler Newbie From: |
posted 01-04-2008 06:16 PM
Saw this thought it was cool.... http://www.theprowlerstore.com/The_Prowler_Store_Order_page_1.htm |
All times are CT (US) Top of Page Previous Page | Return to Off Topic Discussion next newest topic | next oldest topic |
