  Speakers
Author Topic:   Speakers
RayA02
posted 04-23-2024 11:38 AM     Click Here to See the Profile for RayA02     send a private message to RayA02   Edit/Delete Message   Reply w/Quote   Search for more posts by RayA02
I am replacing all the speakers. From what I have read, to get the best sound, I need 2ohm speakers. Also, it seems that one of the more popular speaker replacement is the 3 1/2" Infinity speakers (3032CF) which are 2ohm. Apparently, they no longer make the 3032CF and 3032CFX is the replacement which only comes in 4ohm. Will that be an issue or should I look for another speaker that is true 2ohm?
Richnew41
posted 04-23-2024 08:40 PM     Click Here to See the Profile for Richnew41     send a private message to Richnew41   Edit/Delete Message   Reply w/Quote   Search for more posts by Richnew41
Hi Ray…
Just my 2 cents…
It’s not going to make any measurable difference in sound… I’ve done 4 ohm throughout without any issues…. The front and rear with just a 3.5 speaker takes almost nothing to drive them. Don’t sweat it and the 4ohm will do just fine… For the front under the dash and rear speakers 🔊 I recommend the
Hertz DCX 87.3 They are nearly the exact duplicate in size and will fit perfectly… They also are a bit more robust than most 3.5 and handle 60W rms
They are a very nice 3.5 and better than the infinity at that size in my opinion.
Richnew41
posted 04-23-2024 08:46 PM     Click Here to See the Profile for Richnew41     send a private message to Richnew41   Edit/Delete Message   Reply w/Quote   Search for more posts by Richnew41
RayA02
posted 04-23-2024 10:32 PM     Click Here to See the Profile for RayA02     send a private message to RayA02   Edit/Delete Message   Reply w/Quote   Search for more posts by RayA02
Originally posted by Richnew41:
Hi Ray…
Just my 2 cents…
Thanks. I will look into those. Any recommendations for the door speakers?
This message has been edited by RayA02 on 04-23-2024 at 10:36 PM
Richnew41
posted 04-23-2024 11:56 PM     Click Here to See the Profile for Richnew41     send a private message to Richnew41   Edit/Delete Message   Reply w/Quote   Search for more posts by Richnew41
Ok that’s a much different subject… I have always modified mine to the extent using a 3/4” spacer behind 6.5 as the additional room allows for a larger speaker when it comes to depth…. With the spacer, the door panels still fit without any modifications however, there is some drilling to fasten the spacers to the door frame. If you looking for exact fit, I will leave it to others to chime in as to what they have gone with…. I’m actually in the middle of a stereo upgrade and have the Alpine HDZ-65 for the doors (super expensive)… I have not gotten to them yet so I can’t provide install details….
Richnew41
posted 04-24-2024 12:03 AM     Click Here to See the Profile for Richnew41     send a private message to Richnew41   Edit/Delete Message   Reply w/Quote   Search for more posts by Richnew41
Side note… I have always had good luck with infinity on the doors as well but I’m not sure of the current models on the market to know if any will work. I can say the infinity had beautiful sound… I’m hoping the Alpines are a set up…
Will shall see….
kkuntz01
posted 05-03-2024 04:58 AM     Click Here to See the Profile for kkuntz01     send a private message to kkuntz01   Edit/Delete Message   Reply w/Quote   Search for more posts by kkuntz01
I replaced all 7 speakers 2 years ago. I used the prowler store to get the specks from the factory speakers,then replaced all with Kickers. Easy job and sounds great. Make sure you have a roll of black duct tape. Ken
Tchootch
posted 05-05-2024 12:04 PM     Click Here to See the Profile for Tchootch     send a private message to Tchootch   Edit/Delete Message   Reply w/Quote   Search for more posts by Tchootch
I installed JBL Club 6520 (6.5") in the doors and JBL Club 322F (3.5") everywhere else. All are 3ohm.
The door speakers came with a plastic mounting ring which screwed straight to the original holes in the door and which the speakers mounted too. Simple job and fits within trim and clears door internals.
Check out the following link for details. http://www.prowleronline.com/cgi-bin/postdisplay.cgi?forum=Forum1&topic=026415
