Author | Topic: Ball Joint UPDATE 7/2 |
posted 07-02-2018 07:59 PM
In contact with Rare Parts and have good news. There is quite a bit of testing regarding ball joints and their application(s) in general. A lot of the testing revolves around how much integrity the ball joint has to have based off it's application in the vehicle. I had sent RP a good ball joint(bad boot), so they could get test results and make sure a replacement was at the very least as strong as our originals. Most of the strength test revolves around what is called,"pull out strength". The stock b-joint I sent them required 8000 lbs to pull the stem out of the housing! Form what I'm understanding the replacement they've put together has 2 TIMES THE PULL OUT STRENGTH as our stocks do! And for some of you that have wanted, it will be grease-able as well!!! So as it stands right now, there's a couple more items they're finishing up with. Working on the price as well so should have that soon. So hang tight everyone. This looks VERY promising for us!! Will get you all info as soon as I have it. And I think it will be very soon!! Thanks for your patience........Mike |
u00tjs2 a POA Site Supporter Prowler Junkie From:ft wayne, in, USA |
posted 07-02-2018 08:18 PM
Thanks to you for all the heavy lifting! This is great news! |
dru POA Site Supporter Prowler Junkie From:Texas |
posted 07-02-2018 09:52 PM
Thanks for all your hard work on this project. Sounds very promising. |
posted 07-02-2018 10:57 PM
Fabulous news. Great work. |
posted 07-03-2018 06:13 AM
Excellent news! I will be buying several sets. |
posted 07-03-2018 07:11 AM
Freaking Awesome. |
posted 07-03-2018 09:45 AM
Great job, Mike. Thank you for all your hard work on this. |
posted 07-03-2018 10:45 AM
AND DONT forget I'm buying your 1st set Mike.... and if Bob (rpl)has any luck on racks we all will be in "happy land" .... |
posted 07-03-2018 11:37 AM
Thanks to everyone. There's a couple of items that I have brought up with Glen as well. The replacement ball joint will probably not have the black plastic coned attaching nut as the factory did. So we will probably be running a washer under the nut so the nut won't gall the aluminum steering knuckle. I believe that the replacement will have a way of holding the top of the stem while we are torquing in place to prevent it from possibly spinning. Probably have to use a crow foot socket as well. Have more info for all when I get it. Any body else that can think of any topics or concerns regarding this, now is the time to bring them up. Mike This message has been edited by CAT-A-TONIC on 07-03-2018 at 11:38 AM |
posted 07-03-2018 02:29 PM
what are they doing to reduce the torque or twisting on the dust boot from turning the steering wheel? Thank you, BTW!! |
posted 07-03-2018 02:40 PM
Boot should be made from material that is highly resistance to sunlight (UV) and ozone, since we have an open-wheel design front end. Boot should also be highly resistant to torsional loads (rotating) , as when wheel is turned during steering maneuvers. I would be great if boot can be replaces without having to press out ball joint. Just separate knuckle. Glad to hear they will be grease-able. |
Largent POA Site Supporter Prowler Junkie From:Saugus, CA, USA |
posted 07-03-2018 02:48 PM
This is all very good news. Thanks again for the effort! |
posted 07-03-2018 10:36 PM
One of the differences that we will see and deal with regarding Rare Parts replacement b-joint will be the attaching nut. It will be a castle nut and it will have a more conventional cotter pin. I was somewhat concerned that with out the black coned washer to prevent the stem from turning we might have an problem pulling the stem through the steering knuckle. Well.....after going over this, it became apparent that the reason the black coned washer is there in the first place is to prevent the stem from turning not because of how it fits in the knuckle but because the factory nut is a ny-lock design. It's only there to overcome the ny-lock tension on the upper portion of the threads!! The service manual didn't elaborate on this and it seemed like a mystery. If someone had brought this up before I missed it. I for one never thought of it being anything other than another odd ball design with Prowlers in general. It isn't, it's simple! I'm still floored over not figuring this simple design feature out during the million discussions over these ball joints. |
TucsonJer POA Site Supporter Prowler Junkie From:Tucson, AZ, USA |
posted 07-04-2018 07:06 AM
Thank you so very much. The Prowler community will forever be in your debt. Jer |
posted 07-04-2018 08:33 AM
There's a neat new solution for a castle nut and cotter pin. A friend just received a patent on it. Trying to figure out how to post a picture. Sorry. |
posted 07-04-2018 11:01 AM
Bob, is this what u are looking for? |
posted 07-04-2018 11:24 AM
That chrome cap setup is NICE!!! That will be just the finishing touch. |
posted 07-04-2018 11:25 AM
Steve, THANK YOU! That the one. |
