Author | Topic: Oil filter |
p-rowl Prowler Newbie From: |
posted 09-03-2016 02:16 AM
Can anyone verify the correct oil filter for these cars? I have a 2000 and all my local parts stores are giving me the Mopar oil filter number MO-090. When I went to change the oil filter out yesterday the MO-090 filter was quite a bit larger than the oil filter currently on the Prowler. I decided not to change the oil until I could verify the correct oil filter. Looking at the MO-090 oil filter, it looked like it would not fit the engine block because it was too large in diameter. Can someone please give me a correct part number for the oil filter? Otherwise what are you guys using for filters? |
posted 09-03-2016 05:48 AM
That's the right one |
parts POA Site Supporter and Vendor Prowler Junkie Prowler-Parts.Com Call 248-952-1669 Email Bill at Prowler-Parts.Com From:troy mi. usa |
posted 09-03-2016 06:11 AM
I use WIX 51515 quart size, one of the best you can buy. quote: |
posted 09-03-2016 06:57 AM
quote: Drew is correct,,,,,that is the OEM Mopar filter to use,,,,,,,,,,,,,,and is used on many other Chrysler/Dodge vehicles. WIX is another fine filter to use ,,,, is also packaged as a NAPA GOLD and CARQUEST filter at those parts stores. |
posted 09-03-2016 11:30 AM
Be careful of the oil sending unit which can be easily damaged since it is very close to the filter. |
posted 09-04-2016 04:03 PM
A lot has been written about the oilfilters. My best experience use Mobil 1 Full Synthetic 10W30 with a Purolator PureONE, P/N PL14670, it contains an anti drain back valve and will help reduce oil chatter at startup. look it up in the search section. Kees ------------------ This message has been edited by kees on 09-04-2016 at 04:04 PM |
posted 09-05-2016 03:39 PM
Thanks for the replies. |
