Author | Topic: Bad ball joints |
John1923t Prowler Enthusiast From:ENGLEWOOD, Florida, United States |
posted 05-19-2016 05:36 AM
Ball joint failure last night,I had to put baby on a flatbed, 2nd one in 34,658 miles, they will have to arrest me to get me out of that dealership today if I get any crap. I read all of the post's on the ball joint recalls last night. I am not leaving with out new steering knuckles, ball joints and brake lines. |
parts POA Site Supporter and Vendor Prowler Junkie Prowler-Parts.Com Call 248-952-1669 Email Bill at Prowler-Parts.Com From:troy mi. usa |
posted 05-19-2016 05:45 AM
Sorry to hear that hope all works for you. Good luck quote: |
posted 05-19-2016 08:10 AM
Keep us updated.....send up a flare if you need reinforcements. Robin |
ecomaine POA Site Supporter Prowler Junkie From:Scarborough, Maine |
posted 05-19-2016 08:53 AM
I'll watch the news tonight... |
posted 05-19-2016 05:49 PM
Like I have said before and I will repeat,,,, the ball joints need to be greased. Get a needle atachment for a grease gun,,, when you pearce the boot mark it somewhere so to use the same hole when it needs to be done again. I do this to every vehicle I have ever owned that does not have servicable ball joints. The ball joints take a extreme beating and as soon a they get a bit dry,,,, good bye Jack. Put your head out the window while driving and look at the fender and you will know what I mean. A ounce of prevention is better than a pound of agrivation. This message has been edited by Landscape Doctor on 05-19-2016 at 05:53 PM |
Dfsc1 Prowler Enthusiast From:Long Island, NY, USA |
posted 05-19-2016 07:22 PM
Do they just let go with no warning signs? No creaking, crunching, rattling or noticeable movement when jacked up and wheel tugged on? |
posted 05-19-2016 07:48 PM
quote: I would say it all depends on road conditions where you live and drive. Look to see if yours have a 'x' at the end of the serial # at the bottom of the joint. The 'x'signifies the recall has been done. Jack it up and put a long bar under the wheel and pull up on the bar. Look for slop in the ball joint. Have someone give you a hand,,, the helper lifts up on the bar and you check for slop. This message has been edited by Landscape Doctor on 05-19-2016 at 07:53 PM |
posted 05-19-2016 08:00 PM
You maybe leaving with new knuckles ,brake lines etc, but you will be paying for them too. |
posted 05-19-2016 08:26 PM
[QUOTE]Originally posted by Landscape Doctor: [B]Like I have said before and I will repeat,,,, the ball joints need to be greased. Get a needle atachment for a grease gun,,, when you pearce the boot mark it somewhere so to use the same hole when it needs to be done again. I do this to every vehicle I have ever owned that does not have servicable ball joints. Putting grease under the boot is NOT where the grease is needed. You must get it thru the bottom of the ball joint to lube the ball & socket itself. A good way to do this would be to drill a hole at the base of the ball joint and tap it out and install a zerk fitting. This message has been edited by phil2237 on 05-19-2016 at 08:31 PM |
posted 05-19-2016 08:42 PM
I would have to disagree with you Phil. The boot actually covers the joint. When you grease a jerk fitting the excess goes into the boot,, so putting grease in the boot lubes the joint in reverse. If you cut open a boot on a ball joint you can see the ball and joint. By putting grease in the boot keeps the joint lubed. Phil, have you ever used a needle? If used correctly it does not let in water and dirt in. This message has been edited by Landscape Doctor on 05-19-2016 at 08:45 PM |
posted 05-19-2016 09:44 PM
quote: There was a recall on Prowler ball joints, was yours done under the recall? If it has been replaced and still failed I would send a complaint to the NHSTA. |
posted 05-24-2016 04:00 PM
Status update from John???? Hope your not in jail! |
posted 05-24-2016 07:10 PM
quote: By putting grease under the boot, There is NO way for it to get down under the ball where it fits into the socket. The socket area is where the grease is needed. That is why most Ball joints have a fitting at the bottom of the ball joint as grease enters the socket area. The boot is there for a reason, to keep water & dirt from entering. You don't poke holes into it as you defeat the whole purpose of the boot. Even the smallest hole can allow water to enter. If you want to put grease under the boot, all you would have to do is lift the outer edge of the boot and grease it. NO need to poke holes in it. Yes I have several needles. They are actually made to fill bearings where the rollers ride during assembly, & to lube in tight areas. That ball and socket on the ball joint is fitted so tightly and there would be no way for grease to enter the socket area by putting grease under the boot. All you are doing is putting grease on top of the ball where it is NOT needed. If you feel like this works for you, do it your way, but you are wasting your time. This message has been edited by phil2237 on 05-24-2016 at 07:18 PM |
syswayne1939 Prowler Junkie From:Lubbock, Texas |
posted 05-24-2016 08:13 PM
quote: By putting grease under the boot, There is NO way for it to get down under the ball where it fits into the socket. The socket area is where the grease is needed. That is why most Ball joints have a fitting at the bottom of the ball joint as grease enters the socket area. The boot is there for a reason, to keep water & dirt from entering. You don't poke holes into it as you defeat the whole purpose of the boot. Even the smallest hole can allow water to enter. If you want to put grease under the boot, all you would have to do is lift the outer edge of the boot and grease it. NO need to poke holes in it. Yes I have several needles. They are actually made to fill bearings where the rollers ride during assembly, & to lube in tight areas. That ball and socket on the ball joint is fitted so tightly and there would be no way for grease to enter the socket area by putting grease under the boot. All you are doing is putting grease on top of the ball where it is NOT needed. If you feel like this works for you, do it your way, but you are wasting your time. [/B][/QUOTE] |
posted 05-24-2016 08:18 PM
quote: By putting grease under the boot, There is NO way for it to get down under the ball where it fits into the socket. The socket area is where the grease is needed. That is why most Ball joints have a fitting at the bottom of the ball joint as grease enters the socket area. The boot is there for a reason, to keep water & dirt from entering. You don't poke holes into it as you defeat the whole purpose of the boot. Even the smallest hole can allow water to enter. If you want to put grease under the boot, all you would have to do is lift the outer edge of the boot and grease it. NO need to poke holes in it. Yes I have several needles. They are actually made to fill bearings where the rollers ride during assembly, & to lube in tight areas. That ball and socket on the ball joint is fitted so tightly and there would be no way for grease to enter the socket area by putting grease under the boot. All you are doing is putting grease on top of the ball where it is NOT needed. If you feel like this works for you, do it your way, but you are wasting your time. [/B][/QUOTE] Anyone have any pictures? So I can grease mine. This is scary. I know what can happen going down the road and one goves completely out. Thanks syswayne1939 |
posted 05-24-2016 08:37 PM
quote: By putting grease under the boot, There is NO way for it to get down under the ball where it fits into the socket. The socket area is where the grease is needed. That is why most Ball joints have a fitting at the bottom of the ball joint as grease enters the socket area. The boot is there for a reason, to keep water & dirt from entering. You don't poke holes into it as you defeat the whole purpose of the boot. Even the smallest hole can allow water to enter. If you want to put grease under the boot, all you would have to do is lift the outer edge of the boot and grease it. NO need to poke holes in it. Yes I have several needles. They are actually made to fill bearings where the rollers ride during assembly, & to lube in tight areas. That ball and socket on the ball joint is fitted so tightly and there would be no way for grease to enter the socket area by putting grease under the boot. All you are doing is putting grease on top of the ball where it is NOT needed. If you feel like this works for you, do it your way, but you are wasting your time. [/B][/QUOTE] Anyone have any pictures? So I can grease mine. This is scary. I know what can happen going down the road and one goves completely out. Thanks syswayne1939 [/B][/QUOTE] |
posted 05-24-2016 08:45 PM
quote: Looked it up in my service manual and changing out the upper and lower ball joints is got to me very expenses. |
posted 05-24-2016 08:50 PM
Cross section of a ball joint. This pic does not have a boot but you can clearly see the ball. By putting grease in the boot lubes the ball,,, by the action of the ball joint working the ball moves thus grabbing the grease and working it around the ball and joint. Here is another pic with a zerk fitting. Hypothetically remove the zerk fitting and imagine putting grease into the boot if the ball joint was not serviceable. Most of the new ball joints have the cross groves that transfers the grease around the ball.
Most non serviceable grease fittings you will not be able to get the needle under the boot because of the way it is assembled. If you are not comfortable poking a pin hole into the boot to lube a ball joint DO NOT DO IT. I have had great luck over the years and never lost a ball joint. Here is another,,, looks like a non serviceable ball joint. If grease was inserted into the boot the grease will work its way around the ball joint. This message has been edited by Landscape Doctor on 05-24-2016 at 09:08 PM |
posted 05-24-2016 09:11 PM
Until the recall neither the upper or lower ball joints were serviceable. You had to replace the control arm. They now offer lower ball joints separately. |
posted 05-24-2016 10:31 PM
This message has been edited by phil2237 on 05-25-2016 at 07:23 AM |
posted 05-25-2016 09:29 AM
Thanks for all the information. Makes me feel some better. Very professional done. Thanks again syswayne |
posted 05-28-2016 09:11 PM
Phil, do you have any factual evidence in all your years of mechanic work that a needle does not do anything or is it just a asumption? Just curious if you have tried it and you had ball joints fail because of using a needle. I have had cars well over 200k and have used a needle and never had a issue. I have worked on cars, trucks, heavy equipment, motorcycles, gas engines, diesel engines ect,ect,ect.for over 30 years. This message has been edited by Landscape Doctor on 05-28-2016 at 09:13 PM |
posted 05-29-2016 09:21 AM
quote: Do what ever makes you happy, Put 2 tubes of grease on top of each ball joint if it makes you happy. Like I stated, They are sealed from the factory. Find an old joint and you will see there is a seal at the top of the ball just under the lip of the steel casing of the joint which keeps grease in the joint when they were manufactured. If the grease can't escape, you sure wouldn't be able to get grease into the top of the joint when it is sealed. You want to put grease on top of them , Go for it. Pep Boys has grease on sale this week end at 30 % off, best to stock up on that price. When using tools, use them for what they are designed to be used for. You want to poke holes in them, be my guest. A needle is useful when used correctly and used what it is designed for. I guess a landscaper would know more than a mechanic. This message has been edited by phil2237 on 05-29-2016 at 09:30 AM |
posted 05-29-2016 10:04 AM
Throw darts Phil,, I have thick skin. Back to the point at hand,,, So 1,,, you have never done it. You answered that question beating around the bush. That's landscaper lingo Phil. 2, answer me this,,, if a ball joint has a zerk fitting and you put grease in the fitting the excess goes into the boot,,, correct? So that just contradicted you saying grease will not escape that outer seal? |
posted 05-29-2016 10:38 AM
Any Person would know if you put pressure from any grease gun against a seal, of course it will force it past the seal. Applying it on top without pressure to force it thru the seal is worthless. If you believe your way works , Go for it, STOP WASTEING MY TIME This message has been edited by phil2237 on 05-29-2016 at 10:40 AM |
