Author | Topic: Tire Pressure Question |
Largent POA Site Supporter Prowler Junkie From:Saugus, CA, USA |
posted 02-01-2016 09:11 PM
The factory specs say to inflate the original runflats to 28 psi. But now, I'm ruining the Falken Azenis tires. The Falken tires state the max pressure is 50 psi. Hmmmm - 28 psi or 50 psi or something in-between... What is the recommendation for non-original tires? |
posted 02-01-2016 10:07 PM
I would say go with the sidewall on the tire. Whatever they recommend. |
TucsonJer POA Site Supporter Prowler Junkie From:Tucson, AZ, USA |
posted 02-01-2016 10:22 PM
The 50 lbs. is a maximum pressure. Most dealers use 34 lbs. as a standard. Hope that helps. Jer |
posted 02-02-2016 06:03 AM
I have the Falken tires and run 35 lbs. in them never had a problem |
georgieboy POA Site Supporter Prowler Junkie From:Lake Don Pedro, CA USA |
posted 02-02-2016 07:51 AM
The tire pressure printed on tires is not the recommended pressure but a maximum pressure not to be exceeded. The pressure recommended by Chrysler is the pressure to use on all tires of that size. The front and rear tires have a different recommended pressure being different size tires. |
posted 02-02-2016 07:57 AM
quote: I hear ya - This is why I'm asking... |
posted 02-02-2016 04:01 PM
That 50 lbs. Written on the sidewall of the tire is a maximum safe pressure the tire should never excede. The tire should be inflated to the numbers written on the drivers door opening. The fronts are 28 psi and the rears are 32psi. I am assuming you are running stock size tires. http://m.discounttire.com/dtcs/infoAirPressure.do This message has been edited by padroo on 02-02-2016 at 04:03 PM |
posted 02-02-2016 06:55 PM
Yes - I am running stock size tires. |
posted 02-03-2016 02:38 PM
My door sticker says 28 PSI for both front and rear tires as does the owners manual on page 101. |
posted 02-03-2016 03:34 PM
Vince - This is Richard from the So Cal Prowlers group. I'm the one with the Woodward. My door and manual also state a single value of 28 lbs. |
posted 02-03-2016 04:27 PM
On newer cars, the recommended pressure is most commonly listed on a sticker inside the driver's door. If there's no sticker on the door, you can usually find the specs in the owner's manual. Most passenger cars will recommend 32 to 35 psi in the tires when they're cold This message has been edited by enzvoy on 02-03-2016 at 04:28 PM |
posted 02-03-2016 06:15 PM
I run the Continental Extreme Contact DWS tires front and rear. I keep 28 pounds (cold) in all 4 tires. I had my oil change place put 35 pounds in them one day and I thought I was going to bounce off the road before I lowered the air pressure. My TPM's don't work anymore (a small piece of black tape covers the dashboard idiot light), so I carry a good air pressure gauge in the glove compartment. Usually check them on Saturday every week. I always do a walk around anytime I leave home to make sure none of the tires have lost air. I like these tires and have never had a problem with them loosing grip on the road. |
posted 02-03-2016 07:04 PM
Hey LSK... Why not just replace tpm in the tires... Got to be better than black tape look... You could always pull the dash and remove the bulb... Takes just a minute... |
posted 02-03-2016 07:27 PM
I think the question about inflating close to the max psi listed on the sidewall has been answered well. I believe the engineers that designed the suspension came up with 28 psi for handling, ride and safety. You can run higher psi than recommended but one or more of the 3 items I listed may be affected. |
posted 02-03-2016 08:09 PM
I run lower pressure for a softer ride. |
posted 02-03-2016 08:34 PM
quote: Agreed - thanks for the help |
