General Prowler Discussion Brand new owner!!! Need help..car has some issues. Thanks (Page 1)
Bottom of Page This topic is 3 pages long: 1 2 3 |
Author | Topic: Brand new owner!!! Need help..car has some issues. Thanks |
F6prowler Prowler Newbie From:Kihei, HI. USA |
posted 07-04-2015 01:57 PM
Just bought car a month ago...Love it!!! But, have some issues....driver window was off its track in the back when I bought the car...could get to go up and down with some help--- now the window fell totally down into the door....also, the car makes a rattling noise at low speeds and normal driving, but disappears once you get going or just accelerate hard...what's going on?? Also, car has a hesitation when you first start to take off , butt seems to disappear when car is warmed up...any help would be great.... |
posted 07-04-2015 02:03 PM
The windows are a very common problem. You can get an excellent after market fix from Jefferson Auto, Tom Mills and fix it for life. He advertises on the main page. The hesitation and vibration/rattle could be many different things. Be careful you don't break the glass with the broken window regulator. Fix it sooner, rather than later. |
posted 07-04-2015 02:12 PM
I had a rattle as well, it came from the engine compartment and only happened at low speeds until the car warmed up. There are some heat shields surrounding the engine that can produce a tinny rattle. All I did was bend them away from their contact point and it helped considerably. Hope that helps and congrats on your new Prowler! |
posted 07-04-2015 02:16 PM
Thanks Ed, going to take door panel off this weekend to get window out for now....saw the ad about Jefferson auto....which is weird because I lived real close to Mishawaka, IN and never knew he was into Prowlers, and now live 4000 miles away and will be ordering parts from him Wheezy, thanks will check into that also!!!!! |
posted 07-04-2015 02:18 PM
Weezy. Damn spell check!!!! From previous reply.... |
P1Prowln Prowler Enthusiast From:Bassfield, Ms, United States |
posted 07-04-2015 02:43 PM
Congrats on your new Prowler. Post some pics of it. |
posted 07-04-2015 07:34 PM
If you are going into the door panels it is a good time to replace the door speakers, most originals are bad or going bad. You will have it in your hand when you do a window regulator. |
posted 07-04-2015 09:10 PM
You won't be able to just pull your glass out of the door. There are a couple of bolts at the back that bolt it to the rear guide. Also you'll need to take the weather stripping off at the top of the door. This is the video to watch when installing the Tom Mills kit. It will illustrate how to take the window out. As far as the other stuff, it needs to be diagnosed by a mechanic. It's a common Chrysler engine so it shouldn't be hard to find a mechanic. If the hesitation turns out to be fuel pump related, then you will need to come back here for specialized info on that. |
posted 07-05-2015 03:53 PM
Got the window out today, but it wasn't really attached to anything, thus not sure what broke....ordering new regulator from Tom.. I assume even though I'm not sure what happened, Tom's kit will go in just fine...seems like someone has already been inside this door because there are zip ties in several places that don't look factory to me....thanks for the help so far!!!! |
posted 07-05-2015 04:38 PM
quote: That is a little strange and worrysome. There are parts you have to re-use with the new kit. Is it possible that you already have a Tom Mills kit in there and the bolts came loose and fell out? |
posted 07-06-2015 09:18 PM
Post a couple pics if possible so the window experts here will be able to help you more efficiently. welcome to the site. |
posted 07-12-2015 02:56 PM
Is it normal to have zip ties here helping to hold the regulator motor? P.S. How do you add pics to this site???? |
posted 07-12-2015 03:10 PM
Double post but I' m not sorry. This message has been edited by padroo on 07-12-2015 at 03:14 PM |
posted 07-12-2015 03:12 PM
posted 07-12-2015 03:18 PM
Thanks Padroo, but all I have is an Apple I-pad and it won't let me rename my pics, so far as I can tell. But thanks for the link... |
posted 07-12-2015 05:54 PM
email the photos to me at emonaha and that is at Gmail.com There is no N at the end of my name on the email. |
posted 07-12-2015 07:09 PM
You only need to rename them if the name is too long, I forget what the maximum length is but you could try anyway. Most cameras don't make the file name very long unless it has been changed. I tend to rename mine on my PC and then I have to shorten it up to post it on this forum. Try using the Test Post Area on this forum to practice uploading a picture file. This message has been edited by padroo on 07-12-2015 at 07:14 PM |
posted 07-12-2015 07:10 PM
you also need to re-name if the name you have, already exists on POA's server |
posted 07-12-2015 08:08 PM
quote: " posted 07-12-2015 03:18 PM by F6prowler F6, posting pics with a IPad is impossible. Email them to Ed as he has graciously offered and he will be more than happy to post them for you. See ya, there is a T-Rex chasing me. This message has been edited by Landscape Doctor on 07-12-2015 at 08:10 PM |
posted 07-12-2015 08:25 PM
quote: it is not normal to have zip ties holding anything. It sounds like someone has done a hack job. It's possible that some one had the regulator out to do a "Kraut Fix" on the OEM regulator. |
posted 07-12-2015 08:50 PM
Lots of folks use zip ties when they replace the speakers to keep the wires together and prevent a rattle. |
posted 07-12-2015 08:58 PM
posted 07-12-2015 09:02 PM
YOU said "not holding ANYTHING" |
posted 07-12-2015 09:03 PM
posted 07-12-2015 09:05 PM
Anything on the motor. It's held on with bolts. Sorry to confuse you but I was answering his question. Yes people use ties to secure wiring of course. "Is it normal to have zip ties here helping to hold the regulator motor?" This message has been edited by beachcat on 07-12-2015 at 09:07 PM |
This topic is 3 pages long: 1 2 3 All times are CT (US) Top of Page Previous Page | Return to General Prowler Discussion next newest topic | next oldest topic |
