General Prowler Discussion What about a kit that makes the doors open wider?
Author | Topic: What about a kit that makes the doors open wider? |
georgieboy POA Site Supporter Prowler Junkie From:Lake Don Pedro, CA USA |
posted 09-13-2013 03:48 PM
I read somewhere that there is a kit available that makes the doors open wider. Does anyone know about this kit? Can you give me any info? Geo. |
nash2atl Prowler Newbie From:Nashville TN USA |
posted 09-13-2013 04:11 PM
Not sure about a kit but there is a fairly simple mod you can do that allows the doors to open a little wider |
posted 09-13-2013 04:16 PM
I believe Obi-Wan made a kit but he has passed a way. |
posted 09-13-2013 04:39 PM
it's easily done with washers. |
posted 09-13-2013 05:11 PM
quote: Easily? I have the spacers and understand what to do but it's in a very tight place. I'll do it sometime when I feel confident. This message has been edited by Gort on 09-13-2013 at 05:12 PM |
posted 09-13-2013 05:17 PM
quote: Piece of cake Gort. It's a good idea to clamp the door check with a pair of needle nose vise grips to prevent it from retracting into the door once the bolts are removed. There is a lot of pressure on it and if it retracts, it's a B*^ch to get back out. If using washers, use masking tape to tape a gang of 4 or 5 washers together. Tape the gang of washers to the end of a piece of stiff wire so you can lower them into place. If you're using a kit spacer, you can remove one bolt and just loosen the other. Once you get one end of the spacer bolted in, you can then remove the other bolt and swing the other end of the spacer into place and bolt it. It is tight in there! But one of the most rewarding mods to do. This message has been edited by beachcat on 09-13-2013 at 05:25 PM |
posted 09-13-2013 06:41 PM
Tom mills has aluminum spacers that fit like factory looking pieces |
posted 09-13-2013 06:57 PM
that mod was invented by catfish.thanks,this mod will give you another 7 to 8 inches of door opening.well worth it ,much easier to get in and out. ------------------ This message has been edited by catfish on 09-13-2013 at 07:06 PM |
posted 09-13-2013 07:05 PM
Georgieboy....There have been 6 posts to your original question....Are you any closer to having an answer? Come on, guys....If you can answer his question, do so.... |
posted 09-13-2013 07:09 PM
I think wildcat answered his question. I was answering gort's. Then catfish claimed to have invented the washer |
posted 09-13-2013 08:36 PM
Do a "search" door widening. |
Hamlyn Prowler Junkie From:Plano, TX |
posted 09-13-2013 08:44 PM
Check with prowl97 |
posted 09-13-2013 10:36 PM
i guess beachy cant read to well.i invented the mod.put 6 small washers behind each dr ck. bolt and your set to go.prowl97 has nothing to do with this mod. ------------------ |
posted 09-14-2013 12:54 PM
OK guys, I have the answer and its a simple fix. Thanks, Georgieboy |
