Author | Topic: Installing rear mud flaps |
posted 06-19-2013 11:28 AM
Would like to know when putting on the mudflaps, after removing the screws, there also bolts on there. I keep on screwing the bolts but the bolts are not coming off. The whole thing the nut and bolt just keep spinning. Any suggestions? Thank you |
posted 06-19-2013 11:43 AM
the bolts look rather rusted,that may be your problem. ------------------ This message has been edited by catfish on 06-19-2013 at 11:44 AM |
posted 06-19-2013 12:04 PM
I put WD40 on it After a certain point the whole thing keeps spinning. Ok thank you, at least I know it has to come off. quote: |
RichO POA Site Supporter Prowler Junkie From:Nashville |
posted 06-19-2013 01:02 PM
Unless your Kat is different from mine (and trailer also -- same fitment), you don't remove the bolts. The flaps go over the studs and the original cap nuts tighten right up to the flaps. They're long enough for the cap nut to grip. Put a thin washer on if you like but don't know if the studs are long enough. |
