Author | Topic: Pin guide inserts and bezels |
jpt POA Site Supporter Prowler Junkie From:DeLand, FL, USA |
posted 06-05-2013 01:09 AM
Does anybody know where I could find a set of two pin guide plastic inserts for the convertible top? Also, can someone describe to me how to remove the left and right bezels without doing any damage to the top of the windshield frame. The bezels(I think that it is the correct name) are the parts where the pin guide plastic inserts are pressed in. Thank you for your help. John |
posted 06-05-2013 07:50 AM
wholesalemopar.com Part Number 4410254 The photo is from another thread where the member was having a problem getting the inserts to snap in. I had a similar problem but just filed a little to shape and get it to snap in. This message has been edited by stevedymo on 06-05-2013 at 07:54 AM |
posted 06-09-2013 04:36 PM
I also need to replace mimes, any particular way taking them out? Or just go in with a flat head screw driver ? Thank you |
posted 06-09-2013 04:59 PM
the only way to get them out is to pry up on them.you may break it and have to buy new ones.there is no way to release the clip part that holds them in place. ------------------ |
posted 09-15-2014 06:40 PM
quote: Not so. If you pry off the surrounding bezel, the insert will come with it and be free. |
SILVRKAT POA Site Supporter Prowler Junkie From:Capon Bridge, WV USA |
posted 09-16-2014 07:17 AM
I need both insert and bezel on both sides. Are both available? If so any idea about how much and where? Thanks |
