Bottom of Page This topic is 3 pages long: 1 2 3 |
Author | Topic: motor |
posted 04-06-2013 04:27 PM
Prowler started running ruff to day after a 200 mi. . trip?? Motor is missing and when rebbed up the exhaust sounds louder that normal and smells like something is burning ? oil and water temp is fine ?? any Ideas ??? Could it be a bad EGR valve ??? |
posted 04-06-2013 05:33 PM
Did the check engine light come on? Did you just get gas before it happened? |
posted 04-06-2013 05:54 PM
engine light came on but got gas early to day .. I just checked the exhaust temp and the drivers side is at 160 f, and the pass side is 105 f. ?? |
posted 04-06-2013 06:06 PM
Bad 02 sensor will cause hell like that... I've seen it in other cars... |
posted 04-06-2013 06:08 PM
Burned or bent valve. Could have been some water in the gas you bought (water wont burn or compress). Always a lot of water in gas station tanks, at the bottom of the tank. If they dont keep the stock of gas replenished regularly then as you get to the bottom of the storage tank, you'll pump water. Driving at highway speeds after your fill-up probably was why you didn't notice the miss until you got home. JMO. |
posted 04-06-2013 06:09 PM
Pull the plugs and see what they look like.. While you have them out you might as well put in a new set.. Try that and see how it runs.. Buy a good set of Plugs.... onecatnodog |
posted 04-06-2013 07:43 PM
Jim, how many miles on your engine? |
posted 04-06-2013 07:48 PM
turned 52000 today will do a PC scan tomorrow .. Not sure why the driver side exhaust is running hotter than the pass side ?? but should have it resolved this coming week .. |
posted 04-06-2013 07:58 PM
see if any stored codes,a egr will set a code,whats the code,then you will know how to procede.could be many things causing a miss. and a 02 sensor will also set a code.let us know what you find.if it is a 02 sensor,go with a napa sensor,they are about 40.00 less than a mopar.around 60.00 vs 105.00.you will also need to know if its upstream or downstream.i replaced mine last yr.the sensor will not cause a miss,so it may be something else.----------------- fuel- valves or plug coil.its not the egr. ------------------ This message has been edited by catfish on 04-06-2013 at 08:43 PM |
posted 04-06-2013 09:06 PM
Thanks Catfish --- I should know more on Monday .. |
posted 04-06-2013 10:29 PM
If you just got gas, it could be just some water. If the station had just gotten a load of fuel the water in the tank gets stirred up. I do not buy if I see a fuel truck on the lot,but that doesn't mean they just dropped a load and left 5 minutes earlier I would try some water disapating treatment fill up again and give it a short drive. |
posted 04-06-2013 10:46 PM
Same thing happened to me WildCat and I added a can of Heat and threw a set of new plugs in the car and drove it down to a half a tank and went to another gas station... onecatnodog |
posted 04-07-2013 05:02 PM
Found the problem today .. Bad Coil replaced it and reset the PC .. Good to go .. That sure makes me feel Good ... |
POOLKAT > POA Site Supporter Prowler Junkie From:Sandy Hook Ct. USA |
posted 04-07-2013 05:07 PM
Good news ------------------ |
posted 04-07-2013 06:02 PM
Glad it wasnt anything worse! |
posted 04-07-2013 06:09 PM
That's great, a cheap and easy fix. |
posted 04-07-2013 07:10 PM
glad you found it,good guess jan. ------------------ |
posted 04-07-2013 08:29 PM
How did you troubleshoot it and find a bad coil? Enquiry minds want to know. |
posted 04-07-2013 08:33 PM
and where is it located?
posted 04-07-2013 08:58 PM
open your hood.look at the top of the engine you see those 6 rectangles on top of the motor,those are coils,one for each cyclinder.they provide the main spark to fire the plug.if you loosen the 2 screws on each one, and with engine running.one at a time remove,idle will change,meaning the coil is firing,if idle doesnt change when removed you have a bad coil usually.thats the first thing to ck,when you have a miss, and hope its a coil.could also be many other things that will cause a miss which im not going into.if i got paid for all the free advise over 14 yrs,i could be rich,of course you could allways pay 100.00 a hr at a dealer or repair shop. ------------------ |
posted 04-07-2013 09:12 PM
Catfish, you probably have benefitted by some FREE advice from the other members here. You have to look at both sides of the equation. |
posted 04-07-2013 09:30 PM
Thank you, on the info. Isn't my friendship here worth anything?
posted 04-07-2013 09:48 PM
This is the truth when I hooked up the autoxray scanner to the car and ran a scan it did not show any thing was wrong .I worked for 40 yrs at a Pipeline Compressor Station and some times we would have a problem that was hard to find like this. So I used a old trick . No coils were hot and did not see a problem with of them but when I turned out the lights with the motor running bingo I could see the coil sparking to block .. autozone $39.00 new one and good to go |
posted 04-07-2013 09:51 PM
quote: WTF does this mean - are you saying POA people should pay you to post your OPINION?? becasue that' the way your post sounds to me. |
posted 04-07-2013 09:58 PM
"O" NO -- NOT ME -- Just trying to help if some one else has a problem like this ?????? or just Pay some one to fix it .. |
This topic is 3 pages long: 1 2 3 All times are CT (US) Top of Page Previous Page | Return to General Prowler Discussion next newest topic | next oldest topic |
