Author | Topic: TPMS with screw on sensors? |
Orange Power Prowler Enthusiast From:Edmond,OK,USA |
posted 03-09-2013 04:33 PM
Any one use a after-marktet TPMS that has screw-on sensors? Like these: TyreDog http://www.amazon.com/Newest-Automotive-Pressure-Monitoring-System/dp/B00AMBQ7CC/ref=pd_sim_sbs_p_14 Pro: Con: |
jwallis POA Site Supporter Prowler Junkie From:JOHNSONBURG, PA., USA. |
posted 03-09-2013 05:05 PM
I have not tried them, they would be good for on your trailer. |
jimsutton POA Site Supporter Prowler Junkie From:Ocala, Fl., usa |
posted 03-09-2013 06:17 PM
I wonder if it will effect the wheels balance ? I have a set but never used them .. |
posted 03-09-2013 06:55 PM
"The sensors weigh 10 grams each, so in theory you’d need a wheel balance but in practice we didn’t find any appreciable difference." http://www.4wdhandbook.com/content/tyredog-tyre-pressure-monitoring-system http://www.tyredog.com |
spoons POA Site Supporter Prowler Junkie Personal ScrapBook From:JUPITER, FL, United States |
posted 12-13-2021 12:35 PM
This is long over due....this is brief overview of the Prowler tire pressure monitoring system: I hope this helps other Prowler owner out This message has been edited by spoons on 12-13-2021 at 12:36 PM |
posted 12-13-2021 03:25 PM
Thanks for your video. I was able to change TPMS sensors by just breaking down one side of the tire. There is no need to remove it from the rim. |
tbonelynch POA Site Supporter Prowler Junkie From:Fayetteville, GA, usa |
posted 12-18-2021 09:01 AM
I disconnected the TPMS module and light bulb and replaced it with these http://www.amazon.com/gp/product/B08GZPJXJM/ref=ppx_yo_dt_b_asin_title_o01_s00?ie= UTF8&psc=1 I use my cell phone to monitor tire pressure. It shows PSI and TEMP. Batteries are easily replaced. This message has been edited by tbonelynch on 12-18-2021 at 09:02 AM |
1stMadMan POA Site Supporter Prowler Junkie From:Bristol , Gloucestershire , United kingdom |
posted 12-18-2021 12:21 PM
I’ve had something similar for around five years works perfectly. I just have to change the batteries once a year which is very easily done. They also make units like this with six sensors, perfect if you have a trailer with run-flats. |
posted 12-18-2021 12:34 PM
I have a set both of mine now..I like them better than OEM This message has been edited by jimsutton on 12-18-2021 at 12:35 PM |
posted 12-18-2021 04:47 PM
I have the valve stem caps also. Have to remove them to change the battery and put air in the tire. Would like to drill a second hole and put in a valve stem to use just for these caps. Then if you have to put air in the tire, no need to remove the caps except to change the battery. |
