General Prowler Discussion 24-08-98 JUN 98 A/C Compressor - Growl Noise/
Author | Topic: 24-08-98 JUN 98 A/C Compressor - Growl Noise/ |
posted 09-07-2012 03:38 PM
24-08-98 JUN 98 A/C Compressor - Growl Noise I think I have this condition on my Prowler, it is listed in the "Garage" section but does not give any way of making a fix. Do I need to bring it in for service? |
posted 09-07-2012 03:58 PM
You'll need to describe the sound a little more in order to pin-point the problem and get you a cost estimate....
NRVOUS POA Site Supporter Prowler Junkie From:Pa |
posted 09-07-2012 04:05 PM
I'm saving that,LOL.
quote: |
posted 09-07-2012 04:09 PM
be more specific. ------------------ |
posted 09-07-2012 04:55 PM
quote: How about this then. $100.00 Hourly Labor Rate. $150.00 If you watch. $200.00 If you help. $300.00 If you worked on it first. |
posted 09-07-2012 05:01 PM
I would not have posted it as written unless I found the exact description in the "Garage" section. I can't describe it much better then as it's written. Maybe I call the seller and ask, being he's a mech. Thanks fo rthe good natured ribbing. |
posted 09-07-2012 05:07 PM
im not talking about the hourly rate,the post.could be many things causing the noise,maybe its the belts,maybe the belts are a little loose,they have very high ft.lbs of tension,very high,maybe there worn,who knows.since you dont want to be specific, your on your own. ------------------ |
posted 09-07-2012 05:22 PM
Dave, don't worry, you are not on your own but you might be better off now. I would take that TSB number to a dealer and ask to see the content of it. Or maybe a member here has access to that TSB. |
posted 09-07-2012 06:02 PM
My '97 has had the "growling" sound from day one. I was told something about a clutch and it was a natural sound. I fixed mine by turning up the stereo. It has worked perfect every since. |
posted 09-07-2012 06:03 PM
sorry double post This message has been edited by Me Time on 09-07-2012 at 07:08 PM |
posted 09-07-2012 06:05 PM
quote: |
posted 09-07-2012 06:51 PM
Check the AC belt .. Mine was doing the same thing and the belt was shot put on a new one and sounds fine now ,, |
posted 09-07-2012 07:07 PM
Thanks will give it a look Sat. This message has been edited by Me Time on 09-07-2012 at 07:08 PM |
posted 09-08-2012 12:44 AM
I saw that exact sign in a m/c shop on Friday. I took the Goldwing in for a rear tire and they had it on the window of the door leading to the shop. |
posted 09-08-2012 01:10 PM
quote: Dave, you now own the car, and drove it a significant distance to get home ... Therefore, First, I would not bother the sellar on this, or anything, anymore. Second, I would not go looking for problems to crop up ... just try to enjoy the car. and Third, find a local mechanic that you can trust to handle the issues as they do arise. My two cents. |
