General Prowler Discussion Plastic door pull handle inserts
Author | Topic: Plastic door pull handle inserts |
dartmaster POA Site Supporter Prowler Junkie From:Phoenix |
posted 12-06-2011 11:55 PM
One of my Prowler door armrest insert handles is cracked Does anyone know where I can find the plastic door handle inserts? Thanks, Jeff |
posted 12-07-2011 12:00 AM
"It helps if you go in with the correct part number, that way it makes their job easier. If what you are describing are the little "cups" that drop down into the door trim panel that you stick your fingers in to pull the door shut when you are seated, the part number is SV10LAZAA. The correct nomenclature is "Handle, Pull". Both sides are the same part number, there is no left or right. I've had good luck with Moparparts in Florida, you can reach them at 1-800-428-0517. Be sure to ask for the Prowler Club Discount. They wont charge you an arm or a leg for shipping either. And, the best part is they wont give you any Attitude... Good luck!" That was from BuddyC about 8 years ago. This message has been edited by ed monahan on 12-07-2011 at 12:17 AM |
posted 12-07-2011 10:48 AM
earnhardt chrysler in mesa,can also get them for you.call mark @ 480-813-5544-tell him jan sent you and you will also get a discount,give him the part number. ------------------ |
posted 12-09-2011 04:46 PM
Junkyard! I can't find my notes but I think they are off a Stratus or Breeze. I pick up several whenever I go to the junkyard. If you can't find them I'll check what I have. Gary |
posted 12-09-2011 06:40 PM
the cups are prowler specific/prowler only. ------------------ |
posted 12-09-2011 09:40 PM
I don't think so Jan. I have replaced mine with ones from the junk yard, exact match. |
posted 12-09-2011 09:44 PM
Catnip is not having a good week. |
posted 12-09-2011 10:01 PM
quote: Gary, it must be so. We must be mistaken. |
posted 12-10-2011 12:05 AM
quote: I was told they are the same as the Dodge Neon. This message has been edited by phil2237 on 12-10-2011 at 12:06 AM |
posted 12-10-2011 07:27 AM
This kinda reminds of when Bullhead as a matter of factly but wrongly stated that our Prowler transmissions were only specific and stand alone only to the Prowler toys |
posted 12-10-2011 08:07 AM
toys your stepping on your brains again,a prowler trans is a 42 le,the 42le is prowler specific,the 42le is used in the prowler only.da.according to the chrysler parts manual the dr pulls are a diff part number and 3 times the price of a prowler.well toys see you havent donated to the website in 3 years wow. ------------------ This message has been edited by catfish on 12-10-2011 at 08:18 AM |
posted 12-10-2011 11:01 AM
jjprowler has gotten some at a junkyard in the past. They were not out of a Prowler and worked just fine. If you used your telescope and zoomed in really close you would be able to see that they were not an exact color/size match, but they worked just fine. |
posted 12-10-2011 11:44 AM
quote: ............................................................. But the Chrysler 300M for one not to mention a few other Chrysler products also use a 42LE or A606 trans the same exact transmission.DUH!!!!, you really do have to stop looking at that big purple manual before you go blind or at least wash your hands when your done In regards to my donation status your RIGHT FOR ONCE!!!, NOT A NICKLE HAVE I DONATED AND SO WHAT!!!!!!!! toys |
posted 12-10-2011 12:04 PM
idive I believe the stratus or intrepid are exact match, size and color. |
posted 12-10-2011 12:41 PM
Gary is correct.. |
posted 12-10-2011 04:12 PM
If they are the same I would guess they have the same part number. That should settle it. |
