Author | Topic: Help for the 33 |
Don Prowler Junkie From:Quaker Hill, CT USA |
posted 11-15-2011 09:09 AM
Can anyone come up with new ring and pinion set for Plymouth 8.75 741 case with 3.91 gear. |
posted 11-15-2011 10:22 AM
if your talking about the prowler,it does not have a ring and pinion.it has 2 gears and a chain.,0r are you talking about a 33 plymouth. ------------------ This message has been edited by catfish on 11-15-2011 at 10:23 AM |
posted 11-15-2011 10:27 AM
Can't promise they will have it but call a company called Unitrac, They are located in Anaheim California. They specialize in gears & drivelines only. The last phone I had is 714 630 4327 This is the supplier I use to use for all my gear work. If they don't have it, they can probably point you in the right direction. There is also a company called Currie Enterprise here in Anaheim California that might also be able to help. |
posted 11-15-2011 10:31 AM
quote: Jan, he is looking for parts on a 1933 , not the Prowler This message has been edited by phil2237 on 11-15-2011 at 10:32 AM |
posted 11-15-2011 10:40 AM
Thanks, I'll give them a call. |
posted 11-15-2011 10:45 AM
If they have it , I can pick it up & ship if they do not ship it themselves. This message has been edited by phil2237 on 11-15-2011 at 10:48 AM |
posted 11-15-2011 08:02 PM
quote: Don there are no 391 ring and pinion for a 741 case that i could find new. you might get a used set, but would be better to get a 742 or 489 case then you can get whatever gear ratio you want. Randy's had only 355 or "373" for a 741 case (what i have in the Dart)I had a factory set of 3.91 but had some pitting on the teeth, so we changed them to 3.73. I wanted to keep the gears but before I got back to the garage they thru them out. You should have no problem finding the better case I have 3 cases and all are 741 ------------------ |
posted 11-16-2011 06:05 AM
Larry,, I hate to change gear as this performs very well with the Dodge 518 trans with OD. I am getting 21,22 mpg. The problem I am having is a heave whine on excelration.It will be most expensive to change over to a 742. I guess I could try to reset pinion. |
posted 11-16-2011 04:34 PM
quote: my 373 whine like crazy, I hate it too. Thought about putting the 3.23 back in The 741 case has a smaller pinion bearing dia. (I think) If they are aftermarket gears you may never get the whine out of them. Had a long discussion with Rick Allison from A&A transmissions (long time drag racer) he said many of the aftermarket gears whine and there is nothing you can do to help them IMO, would find a guy in the area that is good with rear ends and see what they think before you go any farther Good Luck |
