Author | Topic: Front fender flaps |
Mastif Prowler Junkie From:Priceville, AL USA |
posted 09-21-2010 08:02 AM
Who has the best buy on a set of front fender flaps? Mark |
posted 09-21-2010 09:49 AM
I got mine thru a Chrysler dealer. |
posted 09-21-2010 05:59 PM
P.M. sent |
posted 09-27-2010 01:37 PM
I will have the first set of front mud guards to check for proper fit this Wednesday. Tom |
posted 09-27-2010 02:55 PM
I figured you would have them soon. Maybe I should run your way for a test fit. |
posted 09-27-2010 03:32 PM
And I do have a few pairs of the original rears at this time. |
posted 09-27-2010 03:50 PM
And what do you do if the mounting bracket on the fender is gone? |
posted 09-27-2010 03:57 PM
You can get one from Larry Lord |
posted 09-27-2010 04:05 PM
quote: It is such a simple fix. I bought 6 stainless bolts and 6 stainless repair washers. I welded the washers to the end of the bolts (opposite end to head of bolt), then cut off the head. Simply hold the splashguard in position and mark the hole positions. Draw a cross through the marked position. hold the washer over the cross to centre the thread and draw around that. Sand and degrease the whole area then bond the new thread onto the fender. I used stainless nylocs with repair washer to spread the load. |
posted 09-27-2010 04:19 PM
Well i just ordered the brackets from larry lord now i have to figure out what kind of epoxy to use to mount the brackets and i have to get the mud flaps painted not sure this is even worth it, So far $135.00 spent and they aren't even painted yet. |
posted 09-27-2010 04:29 PM
quote: I would give Crawford composites a call and ask to speak to Max. Tell him I recommended 3M 9323 in pink. I dont think it is available in the USA. Max will know the correct adhesive for the job. They are based in North Carolina and are a superb company. As for Max, I believe him to be an absolute gentleman. |
posted 09-28-2010 12:32 PM
I pick up the first pair today for the trial fit and they look great. The price is going to be affordable too.I will know as soon as I get my final numbers together but I hope to be in the $75.00 to $80.00 a pair range. I will keep you posted on the progress but they should be ready in a couple of weeks now. Tom |
posted 10-01-2010 10:28 PM
I will have the price on these front mud guards the middle of next week and it looks like I may be able to do better than I thought on the price. |
posted 10-02-2010 06:59 AM
Great news Tom!!! Thanks for all you do for the owners!!! |
posted 10-03-2010 08:06 AM
posted 10-06-2010 10:12 PM
I should have the first run of front mud guards the end of next week. They will be black plastic and look the same as the originals. With the many suggestions to make them shorter I decided to make them an inch shorter than the originals. I know a lot of the guys have trimmed theirs and when you do you lose the finished edge and they look like you cut them off. These will have the finished edge on the bottom and look like they should. For those that haven’t trimmed theirs and are tired of hitting and scraping them on every little bump these should help that situation out considerably. I can’t help but think that the constant hitting and scraping may be the reason that some are losing their mud guard metal retainer bracket from the fender. I am going to price orders thru the end of October at $59.95 including mounting hardware, shipping is additional. If you would like to have a pair please email me at prowlerparts@jeffersonautocollision.com I also have some of the original rears left |
posted 10-07-2010 12:00 AM
quote: Wonderful explanation ... and as Geno observed and commented ... certainly is quite clear, and bears repeating! |
posted 10-07-2010 11:10 AM
heres one easier than that.mark where you want the studs,on inside of fdr.roughen up that area with 40 grit paper.use devcon 5 minute epoxy and they will stay forever.epoxy studs directly to fdr.very easy to do.let epoxy dry 24 hrs and bolt up flaps.you can also use the epoxy to mount the new brkt if needed.devcon is available at ace or true value hardware.to unbolt the fdr assembly.remove wheel and there 3 bolts that hold the complete assembly to the knuckle,you will need to remove fdrs to do the repairs. ------------------ This message has been edited by catfish on 10-07-2010 at 11:20 AM |
posted 10-15-2010 08:03 PM
I picked up the first set of shorter splash guards today. They look good and fit as the originals. Here is a picture of the originals and the shorter ones for comparison. |
posted 10-15-2010 09:34 PM
Tom, I am sending you an email, I need these asap. I picked up my car this afternoon from the paint shop. Mark |
posted 10-15-2010 10:04 PM
Great job Tom. Thanks for doing this. |
posted 10-20-2010 06:28 PM
I picked up the the final pair today after a few adjustments on the tooling and gave the OK, they look very nice. I will have inventory to ship out next week. I will email all that have placed an order as soon as I get them. |
posted 10-25-2010 08:03 PM
I picked up the first order of splash guards today and I will be ready to ship on Friday. I will send emails to those that have place orders,in the order I received them. Tom |
posted 10-25-2010 09:24 PM
Tom, How much shorter than stock are these? |
posted 10-25-2010 10:04 PM
one inch shorter, there is an explanation about 9 posts up This message has been edited by Tom Mills on 10-25-2010 at 10:05 PM |
