Author | Topic: prowler center cap |
posted 07-11-2010 02:47 PM
Well I bought new tires for the Baby - softer ride no more Run Flats - and sooner or later this will happen to you . You know the the plastic pins that hold the cap on the wheel broke off .. so I thought I would try to fix it and this is what I came up with . I know that there are some other cap fixes out there and this is mine ..[img]http://www.pr owleronline.com/ubb/image_uploads/caprepair4pict0003.jpg[/img][img]http://www.prowleronline.com/ubb /image_uploads/caponwheeelpict0004.jpg[/img] |
katmat POA Site Supporter Prowler Junkie From:PALOS PARK, IL, US |
posted 07-11-2010 02:52 PM
What tires did you go with, any pictures & cost? Thanks, |
posted 07-11-2010 03:33 PM
The tires are Falken --ZIEX S/tz 01 It is a nice tire Good ride - I have them on 4 of my cars .. |
posted 07-11-2010 03:34 PM
bad picture sorry |
posted 07-11-2010 05:08 PM
Jim, between 'each' picture you upload,,,double or triple space so they don't run together. This message has been edited by ALLEY CAT on 07-11-2010 at 05:10 PM |
posted 07-11-2010 05:22 PM
I like the tread design... |
posted 07-11-2010 05:27 PM
had them on for the last year, Ride and performance is MUST better This message has been edited by DFOTOPRO on 07-11-2010 at 06:47 PM |
posted 07-11-2010 05:35 PM
quote: Or instead of an extra 2 or 3 keystrokes you can just hit the enter key (aka return key) once or twice after each picture. |
posted 07-11-2010 05:45 PM
OK idive -- I will try that --- I allways havs trouble postion pictures on this web sight . and I need all of the help I can get.. THANKS |
posted 07-11-2010 11:04 PM
Jim - 1 return puts it on the next line so that they line up vertically. You will not have a space between pictures (they will butt up vertically). 2 returns does the same thing but it will leave a space between the pictures so that they don't run together vertically. The reason the others didn't work was you had a space in the text of the picture. pr owleronline in one and ubb / in the other. I don't know how that can happen unless you are manually typing in the location into your post, but it happens to many people. Good luck. |
posted 07-12-2010 10:59 AM
idive .... you say the return key ? is that the same as the back space key ??? |
HScott POA Site Supporter Prowler Junkie From:NJ |
posted 07-12-2010 11:06 AM
So how did you do the center cap repair and what parts did you use and from what store? |
posted 07-12-2010 12:01 PM
Jim The 'Return' key is the 'Enter' key above the Shift key. |
posted 07-12-2010 10:11 PM
I pulled out a couple old keyboards and snapped a couple shots. MAN they were dirty. LOL. These are both Enter keys but sometimes they are labeled Return instead of Enter. |
posted 07-13-2010 08:27 PM
OK -- Kid dooos - Thanks I got it and I will try the return key next time .. Boy What was I thinking ??? |
posted 07-13-2010 08:36 PM
HScott --- On the center cap repair I broke off all of the plastic clips then ruffed up that area .. then cut a fiber glass back plate and a center plate . made the O ring out of 1/4 rubber hose and epoxyed it all together on the cap ... |
