General Prowler Discussion The three R's - Rodent Removal Recommendations
Author | Topic: The three R's - Rodent Removal Recommendations |
Steve.in.Roanoke Prowler Junkie From:Roanoke, VA US |
posted 05-08-2008 09:39 AM
I believe I have a deceased rodent of some variety lodged in my heat/ac ducts, possibly close to the fan. What is the most expedient method for inspection & retrieval? Suggestions / encouragement most appreciated. Steve.in.Roanoke |
posted 05-08-2008 11:32 AM
Maybe start with removing the top of the dash section,,,and look around after it is off. Hopefully,,you'll be able to find and remove it without further disassembly of parts? Dash top pops and pulls off,,,,,,,,do a search for instructions/how to. Pumpkin's website usually has some excellent examples and directions................ |
posted 05-08-2008 11:41 AM
The number one preferred method... GET A KAT! TLRandall I think had that problem before. Maybe he'll chime in. |
posted 05-08-2008 01:18 PM
The easiest way is to remove the blower - just remove the 3 screws in the bottom of the blower housing (under the glove box). With the blower removed, you can access much of the ductwork. On the way back from Rt 66, my blower started vibrating a little. Turns out there was a mouse nest inside - it must have been there since I bought the car 2 years ago. Have Fun! |
posted 05-08-2008 02:35 PM
A rolling Kat gathers no mice. |
posted 05-08-2008 05:25 PM
Remove the blower, he is probably in there, that is where my nest was, didn't seem that he could get any further into the car. cstall is right, 3 screws and it drops out, a real easy check. |
posted 05-08-2008 07:31 PM
Here's what was in my blower... |
posted 05-08-2008 07:50 PM
quote: NO,,,HELL NO A cat will pee on your wheels/tires, and tear up your top and/or interior seats. The only good cat is a flat cat! NUMBER 1 method V V V V V |
posted 05-08-2008 11:34 PM
I had a mouse problem about 5 years ago. I used the glue traps and caught every last one of them. Maybe 6 or so. The only time I ever had a mouse problem and I didn't think it would ever end. |
posted 05-09-2008 06:09 AM
quote: A cat will pee on your wheels/tires, and tear up your top and/or interior seats. The only good cat is a flat cat! NUMBER 1 method V V V V V [/B] Ummmmm.... I said KAT, not CAT... Now, for the AC rendition of the Rosanna Rosanna Danna immitation... Oh! Thats very different... Nevermind... |
posted 05-09-2008 04:18 PM
Probably ran himself to death once he found the wheel of the blower! |
posted 05-09-2008 07:09 PM
posted 05-12-2008 09:41 AM
Update. Pulled the fan housing & squirrel cage out Sat. removing the three screws. Squirrel cage was pretty much at capacity with insulation & leaves. Removed all & vacuumed up into duct area. Reassembled. Still have a lingering 'odor'. Suggestion? Many thanks for the helpful directions in addressing my 3-R's. Steve |
posted 05-12-2008 10:30 AM
quote: Might try some baking soda - put some in a sock and attach the sock to the inside of the ductwork. It may take a while and you may have to change the sock a few times. |
