This topic has been transferred to: Technical Questions & Answers |
Author | Topic: Gas Octane |
ntprowl Prowler Junkie From:Ballwin, MO, USA |
posted 03-18-2008 11:51 AM
Please excuse this newbe if this topic has been discussed on past occasions or if I'm posting in the wrong forum. What octane gas do most of you use? The manual for my 99 kat notes to use an minimum octane of 91 and does not recommend using a higher octane. In my area of the midwest (St. Louis) the available octane are 87, 89 and 93. I have been using the 93. I would appreciate input from you long time owners. Ntprowl (Bob) |
posted 03-18-2008 12:01 PM
9 years ownership and 36,000+ = miles. I have always have used Premium 91-93 Octane gas and after the first 5,000 miles have always used full synthetic motor oil. |
posted 03-18-2008 12:02 PM
I use 87 octane with no Problems & on the rare ocassions that I had used a higher octane there was no notably difference at all in all 3 of my prowlers. JMHO toys |
posted 03-18-2008 01:15 PM
I use 87 most of the time and have had no problems or knocking. Every couple of fill-ups I will use 93 just to give average of 91. I noticed no difference with the 93 either. |
posted 03-18-2008 01:27 PM
Check your owners manual and then see # 2 under Who Needs Premium. I am sticking with Premium. JMHO
The Bottom Line Most cars don't need premium, but a few do -- and not necessarily the ones you'd expect. And premium's not likely to "clean" your engine, either. While many people claim that their car runs better on premium, this costly fuel is really only needed in a few circumstances. However, when it is needed, it must be used to spare your engine from costly damage. On the other hand, if you burn premium when your car doesn’t need it, the damage won’t be to your engine but only to your pocketbook. It’s All In The Numbers The AKI (anti-knock index -- also known as "octane rating") of the fuel is an average of two different methods of computing the fuel's ability to resist engine knock. Regular unleaded gas in the U.S. has an anti-knock index of 87, while mid-grade is usually 89, and premium typically is 91 - 93. The higher the number, the more anti-knock protection the fuel offers. Engine knock occurs when the fuel in the cylinder ignites by itself before the spark plug ignites it. The technical name for this condition is "pre-ignition." It sounds like marbles rattling around in a can, and it generally gets worse the harder you press on the accelerator pedal. Knocking can indeed damage an engine because what is in effect happening is the "explosion" of the fuel/air mixture is trying to push the piston downward in the cylinder before it's gotten to the top of its stroke and is free to move downward. The engine is actually working against itself to a degree, and there is a lot of mechanical stress placed on certain engine parts, such as the pistons. In extreme cases, knocking can burn holes in the pistons and create other forms of engine damage. Oil companies sell higher AKI fuels (also known as premium) to address this problem. A fuel with a higher AKI actually burns more SLOWLY than fuel with a lower AKI. This is because the fuel is less volatile and requires more heat input before it begins to ignite. (For this same reason, high AKI fuels will actually make your car HARDER to start on a very cold day. In extreme cold -- below 0 degrees F -- you want a more volatile fuel which ignites easily so you can get the engine going without extensive cranking. So if extreme cold is expected, buy 87 AKI gas unless your owner’s manual advises against it.) Who Needs Premium? Basically, all premium fuel does is resist knock. So the short answer to the above question of “Who Needs Premium?” is simply any vehicle whose engine knocks without it. Consider these guidelines as you decide whether you really need premium or are in the majority who do not: 1. If your vehicle makes the above-described knocking sound when you accelerate, try the next higher grade when you refuel, and then see if the knocking goes away. If it does, stick with that grade. If not, bump it up another grade the next time you get gas. Generally speaking, high mileage vehicles with a lot of carbon deposits in the engine are likely candidates for needing premium or mid-grade gas, since these deposits reduce the volume of the engine's combustion chamber and make knocking more likely. In addition, the carbon deposits themselves get hot and may act to ignite the fuel if lower AKI fuel is used. High mileage engines do not always have carbon deposits; those that have been driven mainly in town and done a lot of idling are most likely to be “carboned up.” My Ford F-150 has 210,000 miles on it and does not knock on 87 AKI regular unleaded, so that’s what I use. 2. If your owner's manual calls for higher AKI fuel, use what the Good Book says. Usually this will be specified by manufacturers of high compression, high performance engines. If lower AKI fuel were used in these engines, performance would suffer because the engine's computer system would have to retard the ignition timing (reducing horsepower and fuel economy) to keep the engine from knocking. If, in such an engine, the computer could not retard timing enough to keep it from knocking, the engine itself could be damaged. This would not be likely to happen on one tank of fuel, however. So if you lend your BMW to your son or daughter who has a hot date, don’t run for the siphon hose if he or she returns it with a full tank of regular unleaded. Just drive more easily than normal so the engine's maximum performance isn't needed, and there should be no problem. But I Want to Keep My Engine Clean! The higher AKI of premium gasoline does not in itself make it any cleaner than regular gas. Oil companies, however, like to advertise that their premium fuels are ‘specially formulated” to clean fuel injectors, restore lost power, and, hey, maybe even improve your sex life. But the truth of the matter is that any “cleaners” that could be added to gasoline itself are probably not going to be present in sufficient quantities to do much good. A better strategy to keep your fuel injectors clean is to buy your gas from reputable stations that have a relatively brisk business. In this way the gasoline is liable to be freer of water and other contaminants. It’s also not a bad idea to avoid buying gas from stations while their tanks are being filled by a big tanker truck. It’s possible that the filling process could stir up gunk that’s settled to the bottom of the station’s storage tanks and make it more likely that debris could wind up in your own tank. (Gas stations have filters that are supposed to prevent this, so this is a minor point for those who want to be extra careful; it’s not a really big deal.) “But I Just Think Premium Makes My Car Happy” If you enjoy using premium because you think it makes your car “happy,” then go right ahead and use it. President Bush has asked Americans to spend money to support the economy, so you can view it as your small patriotic contribution. And if you own stock in an oil company, so much the better. Using fuel with a higher AKI than needed will in no way harm an engine. Also, your engine won’t get “a taste” for the good stuff and rebel against you if you fall on hard times and have to use cheap gas. Alcohol: The Tough Question No, this isn't a lecture on drinking and driving. Ethanol is a type of alcohol that is often added to fuels to increase the AKI rating. Government regulators like it because they claim it helps engines burn cleaner. Should you use it? This is a more complex question than what AKI rating to use. Alcohol-gasoline blends may make a car do better on an emissions test, so if you need one to get your car licensed in your state and are afraid your car may not pass, fill your tank with an ethanol blended fuel before you take it for its emissions test. Whether these blended fuels actually keep any pollution out of the environment is not as certain. This is because emissions tests don’t necessarily take into account the fact that your car may burn more fuel if you use an ethanol blend. On a per-gallon basis, a car will emit fewer pollutants with an ethanol blend fuel because ethanol burns more cleanly than gasoline. But on a per-mile basis -- the only basis that matters -- an ethanol blend fuel might not be any cleaner than gasoline because cars typically get worse gas mileage with it than with straight gasoline. For example, if you get 30 miles per gallon with straight gasoline, and 28 miles per gallon with an ethanol blend fuel, for every 1000 miles you drive, you are burning a little over two more gallons of the ethanol/gas blend than you would have burned if you had used straight gasoline. So even if the ethanol/gas blend burns, say, 5 percent cleaner than straight gas, you are still actually polluting more with the blend because you’re burning almost 7 percent more fuel. There are other issues as well: Ethanol has a tendency to degrade rubber fuel system components such as gaskets. While late model cars have supposedly been made with gaskets that resist damage from ethanol, some older models may not be so resilient. What can happen is little pieces of rubber that have come off of deteriorating gaskets can find their way to fuel filters or fuel injectors and gum things up. All in all, for the environment as well as most vehicles, ethanol in gas is probably not going to do much harm or much good. But on the off chance that it may, I personally prefer to avoid it. Trouble is, in a lot of states, stations do not have to tell you if their gas has ethanol in it. You can, however, look for stations who advertise their fuel as “100 percent gasoline” or similarly. (These comments do not apply to newer dual-fuel engines that designed to run on either gasoline or methanol. If you have one of these engines and use methanol, follow owner’s manual recommendations.) In Summary Fuels with a high AKI number are needed in a few cars, but the majority will run fine on regular unleaded. If your car knocks when you accelerate, or if your owner’s manual calls for a higher AKI, use one of the premium grades. Otherwise, regular unleaded will save you money and reduce your driving costs. This message has been edited by BeWare on 03-18-2008 at 01:29 PM |
posted 03-18-2008 02:11 PM
So according to this if i don't feel a difference in performance and engine isn't knocking there should be no problem. |
posted 03-18-2008 02:31 PM
quote: The way I read it there SHOULD be no damage to the engine, however you will likely experience reduced fuel mileage and performance. Not feeling a difference and actually having a difference are not ncessarily one in the same. I personally am not a RISK taker so this is why I am sticking with what the manufacturer recommends. Also I read another similar article that stated if you are not going to keep the car go ahead and use the lower octane fuel. However if you are going to keep it long term, go with the recommended octane fuel. This is due to long term issues such as carbon deposits and engine wear etc. that are not necessarily considered as the engine damage as described above. Again JMHO. Bottom Line Do what is best for you. Just a thought. Many if not most of us pamper our Prowlers in so many other ways so why not do the same when it comes to the fuel octane we use? I am always reminded of a car service commercial where they say "PAY ME NOW or PAY ME LATER" OK I am off my soapbox. I have probably said way too much already. This message has been edited by BeWare on 03-18-2008 at 02:38 PM |
posted 03-18-2008 02:57 PM
For "general" use, the computer on the 3.5 HO engines is more than capable of preventing spark knock or pre-detination. If you are operating at higher altitudes or full performance acceleration, or pulling the trailer, use the premium grades, 89 / 93 every other tank will keep it on an even keel. Under performance conditions the computer will not advance the timing enough to provide full available HP or torque on 87 octane. A few trips to the drag strip will show you in real numbers. I have used 89 when pulling the trailer with no adverse affects, even through the mountains of Tenn. and NC. |
posted 03-18-2008 04:04 PM
Rich this is good info to know. No problem expressing your opinion, that's what he ask for. Jim had it right also, if I was going to the track I'd fill up with prem. Like I said I try to mix my fill ups between 87 and 93 to make a 91 blend which manual calls for, but you are right with all the money we spend on the cars a extra $3 per tank is cheap insurance for engine problems later on. |
posted 03-18-2008 04:25 PM
The first few years I always used premium. A few years ago Bob Longstreth posted something similar to what Rich posted and since then I have been using 87 with no noticable problems (noticable being a key word) |
posted 03-18-2008 06:00 PM
87 octane.prowlers have a knock sensor which will automatically retard the timing if the engine started knocking.have never had that problem w/87. ------------------ |
posted 03-18-2008 06:41 PM
Below is a post I made to a thread about this topic a couple of years ago. I'm sure you'll find it interesting, and I hope reading what an expert says will help each of you decide for yourself which grade of fuel to use: ******************************************************** I'm not going to tell you my thoughts,,,,,instead,, I'm going to let MASTER Car Technician Mark Salem, tell you his. Mr. Salem has done several auto repair segments for NASCAR televison, has a weekly television show about auto repair, a weekly radio auto repair show, owns his own very successful auto repair business in Tempe, Az, and his articles can be seen at NASCAR.COM - http://www.nascar.com/auto/cct/ ******************************************************* Q: Super or regular unleaded? A: First, let me make this distinction. Pre 1981 cars do not have the ability to change the timing if the engine is pinging. Cars and trucks made after 1981 have a on board computer that will see the engine pinging and retard the timing to eliminate the ping. Then the computer will try and sneak the timing up, all the time watching to see when the ping comes back. When it does, the timing is moved back a couple of degrees to eliminate the ping. AAA says only 5 % of the cars on the road today absolutely need super unleaded and I agree. If you in doubt, try this. Have your spouse fill up your car and NOT tell you what fuel they used. Do this 3-4 times. See if you can tell the difference and / or guess which fuel they used. If you can't tell the difference, there is no difference. I use the cheapest gas I can find in my Corvette. In tests we ran, the zero to 60 time was 1/10 of a second slower with regular when compared to super. Not much reason to pay 35-50 cents more per gallon. Here's the difference. Regular burns fast, one molecule ignite ten and ten ignite a thousand and they ignite a million. The explosion is similar to a balloon popping. We measure the explosion in milli-seconds. Super burns slower, more like a someone letting a balloon go and fly around the room. One molecule ignites 10, 10 ignite 20, and 20 ignite 30. Now don't start writing me and telling me I'm over simplifying this, I already know it! So super, because it burns longer, should give you more power, better performance and better mpgs. However, the difference between the two different burn times may only be .8 to 1.2 milliseconds of time and I am quite sure no one I know can feel that. Yes, we can measure that on our dyno in 0-60 mph runs and other tests, but unless you can FEEL the difference, there is no difference. Are there any other benefits to using super, No. If you use the cheapest gas you can find, you will save lots of money and when you need to replace, repair, clean your injectors, you'll have plenty of $$ to do that. I can't tell you how many times I bid injector repairs (some as high as $1300 for 6 new injectors on a V-6 Nissan) and the customer says, "But I use super, doesn't that eliminate this repair?" and of course the answer is NO.
ProwlerBobWpg Prowler Junkie From:Winnipeg, Manitoba Canada |
posted 03-18-2008 10:41 PM
We have gas stations called Husky and Mohawk, here that provide a gasahol (about 10% methanol alcohol) at the regular price, and it is rated at 91. Clean burning, good octane and at the "regular" price. Could be something to look into in your area, because this does it all. This message has been edited by ProwlerBobWpg on 03-18-2008 at 10:42 PM |
dhp Prowler Junkie From:Kranzburg SD USA |
posted 03-19-2008 08:32 AM
Here in South Dakota we have many Blender pumps which you can mix up to 30 percent ethanol. It takes the fuel to 95. I have not tried it in my prowler but have in my 99 Avenger, f150, and pt cruiser. Its actually all I run in those three vehicles. in the Avenger with town driving I get 26 miles a gallon average with regular gas, 30 percent ethanol I get 24.9 mpg. It could be my driving style, or the nice balmy 30 below winters(where I let the car warm up too long)I have had no problems with it and it has 212,000 miles on it. I guess bottom line is that I would rather see my few extra dollars go to my local, American farmer for his corn, than to a foriegn company that is posting the largest profits in history. |
posted 03-19-2008 08:57 AM
I always used the higher octane in the Prowler until the last year. I started using the lower octane and haven't noticed any difference in performance or engine knock. I even ran her at the track this past weekend on lower octane and saw no difference. T |
posted 03-19-2008 09:58 AM
quote: Unless the conditions were exactly the same as the last time you ran with the higher octane the only true test would to have made a run on higher octane and then a run on the same day under similar conditions with the lower octane and check the difference. Similar conditions equal engine temp, track temp, humidity and head wind etc. It would be very hard to do this. This message has been edited by BeWare on 03-19-2008 at 09:59 AM |
posted 03-19-2008 10:18 AM
Ok Rich - let me rephrase that - I saw no "noticeable" difference. T |
posted 03-19-2008 04:13 PM
Thanks to all of you for your advice and experience. While I am not adverse to saving $$ my main concern is the well being of my Prowlers engine! I purchased my prowler last November to celebrate my 70th birthday and to fulfill a long overdue desire. As such I am extremely protective of my new toy and hope to enjoy my newfound pleasure for many years. To illustrate how anal I am about my Kat, and not being an expert in this field, I was concerned about using too high an octane! Especially since the manual noted that it did not recommend using a octane higher than the specified 91. Since economy is not my main concern I think I'll try alternating fill ups of 89 and 93 to average the specified 91. Next to keeping my wife purring, keeping my Prowler purring is my main goal, (actually the Prowler could be my main goal). You have also answered a question I had in my mind about driving in the high altitudes of Denver this June. Sounds like the higher Octane is the answer. Thanks again. Bob (Ntprowl) |
