Author | Topic: Prowler Reliability |
posted 09-27-2005 08:25 PM
1997-2002 Plymouth Prowler: Reliability Trouble Spots Consumer Guide's® Auto Editors have scoured repair bulletins and questioned mechanics to search for commonly occurring problems for a particular vehicle. In some cases we also give possible manufacturer-suggested solutions. In many instances these trouble spots are Technical Service Bulletins posted by the manufacturer, however, we have our own expert looking at additional vehicle problems. Air conditioner: A growling noise from the A/C is probably due to the A/C line rubbing on the air-filter housing. A revised line must be installed. (1997-99) Dashboard lights: The low-tire-pressure warning may blink intermittently. If the pressure is not actually low, the pressure sensor(s) will be replaced. (1997-99) Dashboard lights: Low tire-pressure warning light might indicate a faulty sensor/transmitter. (1997-99) Fuel gauge: If fuel tank does not fill completely or is slow to fill, and updated filler neck and hose are available. (1997-01) Fuel pump: When refueling, the pump nozzle may keep clicking off and/or the tank may stop accepting fuel when it is only half-full due to a problem with the filler neck. A revised neck is available. (1997-99) Hard starting: Reprogramming the powertrain control module could aid cold start idle quality. (1997) Oil leak: In colder weather, oil may be forced out of the differential case vent. (1997-00) Vehicle noise: A fluttering or vibrating noise from the center dash vents means the HVAC mode door needs to be recalibrated which is done by removing the battery cable, turning the blower switch to high, and reconnecting the battery cable. (1999-2000) Consumer Guide® Estimated Repair Costs 1997-02: Some vehicles may have defective lower control arm ball joints, resulting in possible loss of steering control. Dealer will inspect and replace affected parts. 1999: Brake-indicator-lamp circuit does not contain the required ground circuit to illuminate the lamp in the event of a brake system hydraulic malfunction. 1999: Some aluminum castings used in manufacture of frame may have missed the required heat treatment; some of these frames could fracture under vehicle operating conditions. 2000-01: Some of the owner's manuals for these vehicles are missing instructions for properly attaching a child restraint system's tether strap to the tether anchorage. |
RED5 POA Site Supporter Prowler Junkie From:USA |
posted 09-27-2005 08:50 PM
Are these issues tech service bulletins? If I bring it in will they fix it for free?? I have that happen a lot with the fuel. |
posted 09-27-2005 09:18 PM
Tech service bulletins are not the same as recalls. You can probably get those items done while in warranty but not after that. This message has been edited by MDProwler on 09-27-2005 at 09:19 PM |
David Veu Casovic POA Site Supporter Prowler Junkie From:PIQUA, Ohio |
posted 09-28-2005 07:12 AM
My fuel tank would keep kicking off the gas hose when refueling the Prowler.It was repaired Per TSB# 14-04-99 replaced tube and hose.(FREE) Chrysler Part # Tube= #4786478AD Hose= #4865372AA (95%)improvement on refueling the Prowler. |
carbuff Prowler Junkie From: |
posted 09-29-2005 11:04 AM
Removed. This message has been edited by carbuff on 06-09-2006 at 12:42 AM |
Zack POA Site Supporter Prowler Junkie From:Oklahoma City, OK, USA |
posted 09-29-2005 06:05 PM
David, Were they replaced free under warranty period or after? |
