Author | Topic: post a picture? |
burglarman POA Site Supporter Prowler Junkie From:Hollister, Calif |
posted 12-15-2004 01:01 PM
How do I post an jpeg image here? |
Jim C Prowler Junkie From:Corona, Ca |
posted 12-15-2004 02:37 PM
burglarman, click on the paper clip icon do a browse find your jpeg in the file you have it residing in double click on it or select. if you want it posted right away double click on the red to the left. It will come back showing some strange verbiage. but it's there and then select submit and wala it's there ... |
posted 12-15-2004 04:05 PM
you make it sound so easy !! i've done all that... and failed miserably....is there a particular size the image must be ? .. whats to big?... whats to small?... i'm doing something wrong.....i got one to post in the test area but , but couldn't get it to work after that.. |
posted 12-15-2004 06:43 PM
Thanks, it worked..... |
ProwlinNM POA Site Supporter Prowler Junkie From:Albuquerque, NM, USA |
posted 12-16-2004 12:19 AM
How do you make a pic file smaller. When I tried to post a pic, I was told that I was over 500k. |
posted 12-16-2004 01:07 AM
to make a pic smaller that you have in your pute already, I have always opened it with paint... then edit, select all, and re-save it, as a jpeg. This usually decreases the size of the file. When you do, make sure you rename it, perhaps only by adding a letter/number after the original name, then compare the two and upload the 'correct' one. |
