General Prowler Discussion Automotive Belt Tension Tester
Author | Topic: Automotive Belt Tension Tester |
posted 08-30-2004 08:37 PM
Possible solution for the belt-breakage problem. Re-posted with permission of the author:
quote: |
posted 08-31-2004 08:27 AM
Looks like a good thing to have.... Still not comprehending how it measures tension, but looks worth getting. I don't have to understand how a TV works to use one either...LOL. |
posted 07-07-2010 09:22 AM
How accurate is this guage? |
posted 07-07-2010 11:07 AM
Gates offers a similar gauge, the Krikit II. It is part number 91132. How accurate are these? Better than guessing. How do they work? They work on belt deflection. Measured belt tension on a newly installed belt will decrease as the belt stabilizes over time and should be rechecked and adjusted. |
posted 07-07-2010 05:05 PM
that gauge is for vbelts only.i bought one today and its going back.last paragraph on instruction page says do not use on a belt that is wider than the gauge.the serp belt is twice as wide as the gauge.so i wont use it due to a very possible incorrect reading.ok on vbelts but not serp belts. ------------------ |
katmat POA Site Supporter Prowler Junkie From:PALOS PARK, IL, US |
posted 07-07-2010 05:45 PM
Here is the tool that Chrysler/Plymouth says to use: Cooling System & A/C > 7198A sorry I can't post the picture. |
posted 07-07-2010 05:46 PM
THANKS! Should have opened the box and READ the instructions. Good catch! |
posted 07-07-2010 05:53 PM
saw that and thought this isnt going to work on the serp belt.good for the v belt.a little to loose might be ok.to tight might prematurely wear the accessory pulley bearings.have never thrown a serp blt but the a/c v belt is real critical on tension to loose and it will throw it. ------------------ |
posted 07-07-2010 06:22 PM
Amen! The car has tossed three so far. |
