Thread Closed  Topic Closed
  Mouse in Trunk!
Post New Topic
Author Topic:   Mouse in Trunk!
FloridaProwler
Prowler Enthusiast
posted 03-10-2002 05:03 PM     Click Here to See the Profile for FloridaProwler     send a private message to FloridaProwler   Edit/Delete Message   Reply w/Quote   Search for more posts by FloridaProwler
When I have the top up there's a horrible squeaking sound that is made in the trunk. Actually I think its the top sitting on the trunk. There doesnt seem to be a tight seal which causes it to move a little and squeak. Has anyone else had this problem? Thanks
Todd Cameron
unregistered
posted 03-10-2002 05:28 PM           send a private message to FloridaProwler   Edit/Delete Message   Reply w/Quote   Search for more posts by Todd Cameron
I had it with two cars, but it was coming from the lock down seals in the front. Dealer fixed it.
2000 Black, 2001 Black Tie, 2001 Orange
WildCat
posted 03-10-2002 06:19 PM     Click Here to See the Profile for WildCat     send a private message to WildCat   Edit/Delete Message   Reply w/Quote   Search for more posts by WildCat
Are you straping the top down when you lower it?
Larry & Sue Mayes
GRROWL
posted 03-10-2002 06:58 PM     Click Here to See the Profile for GRROWL     send a private message to GRROWL   Edit/Delete Message   Reply w/Quote   Search for more posts by GRROWL
Recognize that when the top is up, it is tensioning the front of the trunk lid - it then behaves differently than when the top is down. In my case, that was enough to cause the two chrome locating pins on the sides to squeak & chatter against the plastic receivers. Greasing the two pins completely solved the problem.
ed monahan
posted 03-10-2002 07:52 PM     Click Here to See the Profile for ed monahan     send a private message to ed monahan   Edit/Delete Message   Reply w/Quote   Search for more posts by ed monahan
You can adjust the pins in the top so that they do not pull the trunk up, which may also be your problem.
Dave Mills
posted 03-10-2002 07:56 PM     Click Here to See the Profile for Dave Mills     send a private message to Dave Mills   Edit/Delete Message   Reply w/Quote   Search for more posts by Dave Mills
I had the same problem. Pin adjustment at the deck lid solved mine.
Mopar(Plymouth Forever)Dave
1928 Plymouth Q
1951 Plymouth P-23 Club Coupe
1966 Plymouth Sport Fury Convertible
1975 Plymouth Duster
1999 Prowler
FloridaProwler
Prowler Enthusiast
posted 03-11-2002 10:48 AM     Click Here to See the Profile for FloridaProwler     send a private message to FloridaProwler   Edit/Delete Message   Reply w/Quote   Search for more posts by FloridaProwler
I'll try the pin adjustment and get back to you. Thanks
Post New Topic
