Author | Topic: Zaino |
posted 09-24-2001 06:13 PM
while we were cruising Skyline Drive I asked Mean Gene and Niteman Bill what type of wax they used. They use Zaino and it is noticably better than any of the other waxes. Gene's car definitely looked better than mine. I am now a true believer and give Zaino the Alley Cat/Big Foot/Sasquatch seal of approval. I can do that since I gave him most of those names. He was wandering and wondering aimlessly before I came to the rescue. |
posted 09-24-2001 07:05 PM
It's hard for me to believe Ed, that you would rescue anyone (at least not for free). ------------------ |
posted 09-24-2001 09:23 PM
thanks Dave (or Tom) |
cmitch81 Prowler Enthusiast From:Overland Park, Kansas USA |
posted 09-24-2001 09:33 PM
I love the Zaino products. The polish goes on really easy and comes off easy with a great deeeeep shine, especially if you use 4 or 5 coats. Also the Zaino Ultra Gloss Enhancers is great for shining up between waxes. It, with the polish, makes the finish so slick that the bottle will slide off the hood if you set there! The ClayBar product is great if trying to remove small particles like flecks of paint or grit. I've used it on two of my other cars that inadvertently covers with a fine spray from painting my house! ------------------ |
banzairex POA Site Supporter Prowler Junkie From:Lutz, Florida 33548 |
posted 09-24-2001 09:39 PM
If you like the Zaino wax, you'll love their leather cleaner and conditioner. Also their wax and swirl filler for non clear-coated older car finishes works great. Rex ------------------ |
posted 09-24-2001 10:04 PM
Ed - I trust and value your opinions, and if you say so then the Zaino gets the ALLEY CAT SEAL OF APPROVAL.....
posted 09-24-2001 10:28 PM
I too have recently switched to Zaino. I'm impressed so far, only one coat, and have to add some info. If you haven't already done so, try it on the bumpers. It gives them a shine and possibly makes them easier to clean. ------------------ |
VT Prowler Prowler Junkie From:Annandale, VA |
posted 09-25-2001 12:33 AM
I have one question about Zaino. I have read their page and notice nothing but polish. I might be wrong and just a little dumb, but polishes polish waxes protect. Is that true? I can't find were they say they have a wax. I use all 3M and am pleased with the results when I keep up with it. One year later, after applying show wax, and I still get an incredible bead on water. Guess I could call and ask, but am lazy. Can any Zaino users straighten me out? AC, you must be getting old. You are to trusting. Big Red to the national championship. Trust that one?? Someone please get me straight. I'd switch if someone can honestly tell me Zaino is better than 3M. ------------------ |
posted 09-25-2001 07:28 AM
Jeff, I've tried a lot of products for various cars with mixed results. Zaino has two advantages over any other products. 1.The "OTHER" wax/polish ALWAYS has to be applied in Cool/Shaded spot. 2. The "OTHER" wax/polish ALWAYS leave a residue, that I have to clean off later.
Zaino Cheat Sheet
2.OPTIONAL STEP - Z-18 ClayBar Step - use if surface is not smooth as glass or to make sure all the contaminants are removed from paint. While using ClayBar make sure you are keeping the surface area well lubricated. Use a spray bottle filled up with a mixture of 12 ounces of water to a half a capful of Z-7 Car Wash for this purpose. Important: Do not use the ClayBar every time you wash your car. 5.Apply Z-5 Polish for Swirl Marks and Fine Scratches or Z-2 Show Car Polish. Suggest using the Z-5 first. You can leave Z-2 or Z-5 on for hours or overnight if you desire. I always leave it on overnight to be sure it's dry. When it is not humid Z-2 will take anywhere from 30 to 60 minutes to dry. Depending on how heavy you applied it. People have applied Z-2 in the Arizona sun and it dried in approx. 3 to 5 minutes. It's been applied in 38-degree temperatures and it took about 2 to 3 hours to dry. Be patient. It's worth it. Different situations affect drying times. Also, remember you have Z-1 and Z-5 both on the car. Those are two products that have to dry at one time. Z-2 or Z-5 does not contain any oils and once it's dry will never ever look smeary or feel greasy. To test if Z-2 or Z-5 is dry and ready to be removed wipe your finger on a hazed section. It should immediately come off and leave a crystal clear finish. If it smears, it is still wet. If you remove Z-2 or Z-5 before it is thoroughly dry and get any smears, just wipe down the car with a damp cotton towel. This will remove any smears. Then you can re-apply it. When dry you should remove the polish/residue using large white 100% cotton towels made in the U.S.A. After a successful application and removal of Zaino Z-2 or Z-5, you should wait 24 hours if the outside temperature is under 70 degrees and 6 hours if over 70 degrees before applying the next coat of Z-5 or Z-2. Start this countdown after you have removed a coat not when you apply it. You can switch to Z-2 as soon as you are happy with the way the paint finish looks. Example, no more swirls, scratches etc. It's up to you. Z-2 has higher optical properties than Z-5. You can go from Z-2 to Z-5 and then back to Z-2 as often as you want. Z-2 and Z-5 are 100% compatible and interchangeable. Note: You should always end up with Z-2 as the last coat because of its higher optics. Remember to use Z-6 Gloss Enhancer between every coat of Z-5 or Z-2. 7.Your final step should always be to finish with Z-2.
Harry Findley POA Site Supporter Cantankerous Ol Fart From:Joyce, Washington, 98343 USA |
posted 09-25-2001 02:00 PM
MeanGene----Just got through perusing your post on Zaino. Due to my advanced age I wasn't sure I was going to get all the way through My question is -- do you own stock in zaino? Your expertise here is awsome, but again due to my advanced years (110 +), I'am not sure I could manage all those steps. Do you hier out to do polishings? My boy's are grown and gone so it looks as if I'll have to recrute a half dozen kid's from the local hi school. I once suggested to my better half that she just wash -- not even polish the car. I won't shock your tender ear's with her reply. Well, If I'm going to get the KAT zaioned by Xmas, guess I'd better get started. ------------------ |
Y2K Rod Prowler Junkie From:Warrenton, VA, USA |
posted 09-25-2001 06:42 PM
Jeff, the Corvette clubs have been swearing by Zanio for some time, in fact that's how I was introduced to it. Sal swears this stuff is a protectant and gloss enhancer. Check out most waxes, they include carnuba which leads to a yellowing hue. Zanio does not. As for beading water, well there's a tough subject. Years ago that was no doubt the sign of a great wax--maybe not any more. New paints don't have the resilence of older paint (probably have to do with the removal of lead). Acid rain damage is something we never heard of before and it is caused by water beading up on a paint job. The bead contains air contanmiants, dust, and such. Sun then hits the bead and creates heat (like the magnify glass being used to start a fire). The dust and such then get burned into the paint around the edges of the water bead leaving Acid Rain damage. Some argue that a great polish/wax should cause water to flow off of your car in sheet, which I tend to agree with. Enough rambling--get Zanio and you'll be impressed. BTW, I've seen other clubs get short term deals with Sal (one was buy 4 items and get a free bottle of car wash). With enough interest, we may want to ask Sal. ------------------ |
posted 09-25-2001 09:09 PM
I have ordered several times from Sal and it seems as though he has people standing by to fill orders...turn around time is very quick and dependable. ------------------ |
posted 09-25-2001 11:36 PM
MeanGene and Gil, I'll probably give it a try. Willing to try anything once, well almost anything. I have seen the cheat sheet before, but thanks for the reminder. ------------------ |
posted 09-26-2001 09:50 AM
Harry, No, I don't own stock in Zaino -or- work for them -or- have a distributorship - just a normal user. If YOU are willing to drive your Prowler here , I'll do the Zaino steps for free. This is due to your advanced age, I respect my elders. ------------------ |
posted 09-26-2001 11:32 AM
MeanGene-- Thanks -- You've got a deal. Now, the only other question is is MD part of the contential U.S? When I was in school, some 100 years ago() they didn't teach U.S. history as there wasn't a U.S. and anyway, we were still busy making history. Horses & covered wagons didn't use zanio anyway. But I digress----you'r a gentleman & a schollar and your respect for your elders is commendable. If I did head out for MD, due to my advanced age/altzheimers/short & long term memory loss, I'd probable forget where I was going, why I was going & what I was going for. I'd better print out your instructions for applying zaino before I forget why I started this thing in the first place. ------------------ |
KatAddict POA Site Supporter Prowler Junkie From:Greencastle, PA, USA |
posted 11-05-2001 12:58 PM
Just entered a car show this weekend, the Zaino issue came up again. Have to agree by far, my car looks much deeper than the last time I used and expensive polish/wax. It really did not require a huge amount of time. I like the fact that you can apply the stuff, come back a day later and remove it or do it in the sunlight which would be a "NO WAY" with other waxes. Thumbs Up, ------------------ *99 Yellow *Borla Exhaust *Mud Flaps *Mac Cold Air *Yellow Windshield Banner "Prowler" *MGW Prowler Hitch Cover "COOL" *Logo Valve Stem Caps *Chrome Wheels Done Aftermarket *No Bumpers *Tom Mills Bumper Covers *Removed Visors *Chrome License Plate Frame *Ceramic Brake Pads *SOON TO HAVE: *Shimmers *Chrome Cooler Cover *Rear Belly Pan |
posted 11-07-2001 02:22 PM
I've used Zaino on my car since it was new. Besides looking good, Zaino seems to have some kind of electro-static properties that prevent the car from getting dusty. I noticed this the first time I used it. I got caught in an AZ dust storm after Zaino'ing only half the car. The half that got Zaino'd wasn't nearly as dusty as the other half. |
NVRMND POA Site Supporter Prowler Junkie From:Houston, Texas usa |
posted 11-08-2001 06:52 AM
I have used all of the top brand waxes and Zaino really works great. I think some people have the impression that since it is a two step process, that it is difficult. However, each step combined is easier than the removal of same waxes. I have put 5 coats on mine just once and it was really glossy and deep. ------------------ |
posted 11-08-2001 01:49 PM
Ed, I don't know how you get this many responses to a seemingly innocent statement...it's probably just that new "eagle" signature...or... a need for attention! ------------------ |
Larry Summers POA Site Supporter Prowler Junkie From:Bonita Springs, Florida USA |
posted 11-08-2001 02:23 PM
I acknowledge that if Mean Gene were a Physician, he would write a "mean" prescription. Mean Gene, I took your advice and ordered Zaino products, but haven't used them yet. I did get the shimmers installed, and immediately reduced my ET by .0000000l of a second in the quarter. |
posted 11-08-2001 03:33 PM
MeanGene, It is my rivetting personality, charm, wit and good looks. Also the fact that I am humble. I am still applying Zaino and hope to finish up before Spring. lol It is time consuming just because it takes a while for it to dry and then you have to wait 24 hours before you apply the next coat but I can see a huge difference already. It is really easy to apply and remove and that makes up for it. I am just glad that meanGene could finally contribute something constructive to this site. lol. ------------------ |
posted 11-09-2001 08:48 AM
Larry, I know with the shimmers installed I have reduced my E.T's by at least .00025. I know I have received a lot of help and info on this site. Ed, ------------------ |
