General Prowler Discussion Headlight Vertical and Horizonal Settings Needed Please
Author | Topic: Headlight Vertical and Horizonal Settings Needed Please |
posted 05-05-2001 06:34 PM
Hi I was wondering if someone has the settings for the Vertical and horizontal levelers for the headlight housing. PS. The cleaning solution worked like a dream, no spots in the lens and they are clear as crystal now. I will post later the details. ------------------ This message has been edited by SasyMama on 05-05-2001 at 06:34 PM |
posted 05-05-2001 07:40 PM
Sasy, According to the Prowler service manual, you must fill up your fuel tank prior to making any adjustments on the headlamps. There is a bubble level on top of the assemblies and the preferred alignment for both vertical and horizontal is zero, but an acceptable range is .75 up to .75 down. The hi beam pattern will be correct when low beams are correctly aligned. |
posted 05-05-2001 07:53 PM
With all the work your doing,, it'd be smart to buy a manual,,, ,,,, unless,,,,,, nah ,, never mind,,,
This message has been edited by jd2ksilver on 05-05-2001 at 08:02 PM |
posted 05-05-2001 08:24 PM
Hi John I ordered one friday. I like to learn about the little things. I think it all part of being the owner. Sasy Thanks MidlifeProwler ------------------ This message has been edited by SasyMama on 05-05-2001 at 08:25 PM |
posted 05-05-2001 08:31 PM
Good for you Sassy,, a manual will definitely help you, it has me. ------------------ This message has been edited by jd2ksilver on 05-05-2001 at 08:32 PM |
posted 05-05-2001 08:43 PM
Did you get your headlights replaced. If mind fog up more, I will ask to replace them.I am washing her tomorrow and checking for leaks. Someone told me that DC is aware of the problem and they have done some modifications like using a different sealer around the clear lens. Any tips if I have to see the service manager to get them to replace them. Also, I was wondering if water got in, can the light bulbs exploded from water. Sasy ------------------ |
Ray unregistered Admin Use |
posted 05-05-2001 09:07 PM
No, I don't believe the headlight bulbs will "explode from water", actually, the effect that the HID bulbs, I believe you said you replaced the stock ones with - correct?, will actually provide a way cool look to oncoming traffic if you fill the entire headlight housing with H20 ... plus, it eliminates the water spotting problem all together ... best of luck, let us know how it goes .... k? ------------------ |
posted 05-06-2001 03:03 AM
Actually, if you look, I believe the clear lens, and the rest of the exterior is one piece. Just molded to look like two. So the unit is like a clam I guess, interior and exterior, with screws and glue attaching the two. The top does come off to replace the lamps... If you had the unit off the car I would drill a weep hole at the bottom of the unit for drainage., I have not received my lights as yet. One side, the drivers, was on back order. I haven't called back as of last Tuesday. ------------------ This message has been edited by jd2ksilver on 05-06-2001 at 03:23 AM |
oops This message has been edited by jd2ksilver on 05-06-2001 at 03:05 AM |
posted 05-06-2001 08:00 AM
Hey now, I found the leak to come from the top cover of the headlight assembly. Mine started fogging up on the right side when I wash it after I had replaced the headlight bulbs. The gasket they use is way to skinny and if its not centered on the small hump that is the sealing surface, it will leak. I had to shim my gasket to get it to sit right. All Chrysler needs to do is make the gasket wider too fill up the whole width of the sealing surface............. |
posted 05-06-2001 08:07 AM
John How long has your lights been on order? Sasy ------------------ |
posted 05-06-2001 11:09 AM
I believe your right Fat Man. Also, one of my lights was missing the rubber plug at the adjustment holes. But I still think they need to have weep holes to get the water out once it is in. My lights have been on order maybe 6 work days Sassy. This message has been edited by jd2ksilver on 05-06-2001 at 12:15 PM |
