General Prowler Discussion Desktop Dyno Software
Author | Topic: Desktop Dyno Software |
posted 04-18-2001 08:32 PM
DESKTOP DYNO SOFTWARE Dyno2000 also incorporates new simulation models that allow you to build an even wider range of engines for street or racing applications. Accurately analyze superchargers and alternate fuels (including nitrous), manifolds, and camshafts. And you can test any cylinder head design since flow-bench data can be loaded into Dyno2000. Dyno2000 has a powerful user interface specifically designed for Windows95/98 and WindowsNT. Change parts simply by clicking on any component. Nothing could be easier! Analyze engine performance using a wide range of full-color 3D graphics. All data and graphs can be printed on any Windows printer. You can even model several engines at once; just click on an Engine Tab to focus on any engine you choose. Dyno2000 is the most powerful, accurate, state-of-the-art engine simulation on the market. For the first time your computer can run as many tests as necessary to find the best engine combinations. Dyno2000 will analyze the results and pick the best setup from hundreds or thousands of test runs! Give your next street or race-car engine project the best start possible. Don't leave success to chance, use Dyno2000. System Requirements: DeskTop Dyno 2000 runs on any Windows95/98/2000 equipped IBM-compatible PC computer. A VGA graphics adapter is required. A CD-ROM Drive, 120MB hard-disk space. Our Intenet Special: With the purchase of a DeskTop Dyno 2000 all customers will receive a free Camdisk for the DeskTop Dyno 2000. This CD-ROM contains over 1200 cam-data files that you can easily load and test in the Dyno 2000. You'll find a wide range of camshafts, including marine camshafts in this comprehensive package. Find the right cam for your next engine project in minutes. And now, get this $29.95 value FREE with your purchase of Dyno 2000. Can also be ordered online at http://www.autoaccessory.com ------------------ |
posted 04-18-2001 08:48 PM
Superdan has this along with desktop drag strip. It came pretty close with the et's reached with his Nova. ------------------ |
posted 04-18-2001 09:53 PM
CJ,, your very resourceful,, thanks,, ------------------ |
posted 04-18-2001 10:26 PM
RPL says it's great! I guess Superdan can confirm that!? You're welcome! |
superdanthegarbageman Prowler Junkie From:nyc,ny |
posted 04-19-2001 05:46 PM
hey..let me tell you...it works...i was about .2 of a second off...and the miles per hours was a bit too...but i think if i was to put in a custom engine and install all the correct info...i think id have been closer ------------------ |
