General Prowler Discussion Anybody Having Body Fit Problem?
Author | Topic: Anybody Having Body Fit Problem? |
deelmakur Prowler Enthusiast From: CT(NYC), Gulf Stream, FL, Seattle (Kat stays in WA) |
posted 04-10-2001 05:17 PM
My new Mulholland appears to have a gap where the rear deck lid meets the fender (about where one of the the top snaps is).Basically, when I look in the side mirror I can see that it isn't flush where the door meets it. Not sure if the top is pulling up on it, or if it is faulty workmanship. Anybody know if there is an adjustment on the rear lid? Just haven't had time to take it to a dealer. This message has been edited by deelmakur on 04-10-2001 at 05:17 PM |
CoolRich Prowler Junkie From:Perris, CA |
posted 04-10-2001 05:23 PM
I have the same problkem with my Black 2000. But only when the top is UP!. It is my understanding that the top may be mis-aligned somehow, throwing off the decklid when the top is snapped in. I haven't really worried about it since the top is usually down. If someone knows a fix...let us know. ------------------ |
posted 04-10-2001 06:16 PM
They adjusted mine when it was new, so it can be adjusted. |
posted 04-10-2001 06:18 PM
this may be something you might have to live with. The top pulls up on the trunk edges and the trunk is latched in the center causing a bowing effect. When it's not just right, the trunk or top will rattle. Someone fixed this with rubber doughnuts over the top pins. It's not the best design when coupled to the flexibility of the whole car. You can lower the center latch to pull the lid further down and screw down the stops at the trunk edges to make it sit lower. ------------------ This message has been edited by butchcee on 04-10-2001 at 06:20 PM |
posted 04-10-2001 08:18 PM
I had to have my top adjusted at the time I picked my Cat up 2 1/2 years ago. I've not had any problem since and the gap has not reappeared ------------------ |
