Thread Closed  Topic Closed
  Anyone Find a chrome grill source?
Post New Topic
Author Topic:   Anyone Find a chrome grill source?
SasyMama
posted 04-07-2001 10:39 PM     Click Here to See the Profile for SasyMama     send a private message to SasyMama   Edit/Delete Message   Reply w/Quote   Search for more posts by SasyMama
I am sill looking for a good company that knows how to chrome a plastic grill. I have heard bad stuff about the person in Florida, and the person in Ohio does not return phone calls. So who is left?
Anyone else have any luck. I would like to find someone ASAP.
Thanks
Sasy
Gary C
posted 04-07-2001 10:44 PM     Click Here to See the Profile for Gary C     send a private message to Gary C   Edit/Delete Message   Reply w/Quote   Search for more posts by Gary C
You have a place in your backyard.
Click here
GaryC@ProwlerOnline.com
jd2ksilver
posted 04-07-2001 11:03 PM     Click Here to See the Profile for jd2ksilver     send a private message to jd2ksilver   Edit/Delete Message   Reply w/Quote   Search for more posts by jd2ksilver
Good luck,, this turned out pretty good, but I had to paint the rear of the grill black to take off the raw edge look of the unpolished portion of the chrome.
This is from the guy in Fla you heard bad things about, I took this to three other chromers when I got it back and they all told me they could not do better.
If you find a better place, please post it.
This message has been edited by jd2ksilver on 04-08-2001 at 12:52 AM
Ray
unregistered
posted 04-08-2001 12:45 AM           send a private message to jd2ksilver   Edit/Delete Message   Reply w/Quote   Search for more posts by Ray
My grill is in FL right now. Owner has been VERY responsive to my questions and concerns over some negative and, I might add, erroneous posts from on here. He has given me 'fair' expectations and, along with Laddie's experience, I feel confident that I will be satisfied. I will post my honest thoughts when I get it back ... should be soon.
Also, guy in MI is for iterior pieces, different process and NOT what you want done for an exterior grill item. Believe me, I have called them all too.
jd2ksilver
posted 04-08-2001 12:53 AM     Click Here to See the Profile for jd2ksilver     send a private message to jd2ksilver   Edit/Delete Message   Reply w/Quote   Search for more posts by jd2ksilver
Ray, what were the erroneous post you are referring too?
STARFLAME
posted 04-08-2001 03:54 AM     Click Here to See the Profile for STARFLAME     send a private message to STARFLAME   Edit/Delete Message   Reply w/Quote   Search for more posts by STARFLAME
I have a question,With ALL the Tallent WE have in this
Site,Why could not SOMEONE make an aluminum GRILL to be
CHROMED???
STARFLAME
jd2ksilver
posted 04-08-2001 07:26 AM     Click Here to See the Profile for jd2ksilver     send a private message to jd2ksilver   Edit/Delete Message   Reply w/Quote   Search for more posts by jd2ksilver
Starflame, do a search for grills I think and you should find several different ideas. I think you will find that someone has come out with brushed aluminum or stainless steel one.
This message has been edited by jd2ksilver on 04-08-2001 at 07:27 AM
jd2ksilver
posted 04-08-2001 08:12 AM     Click Here to See the Profile for jd2ksilver     send a private message to jd2ksilver   Edit/Delete Message   Reply w/Quote   Search for more posts by jd2ksilver
http://www.prowleronline.com/ubb/Forum1/HTML/002149.html
SasyMama
posted 04-08-2001 09:21 AM     Click Here to See the Profile for SasyMama     send a private message to SasyMama   Edit/Delete Message   Reply w/Quote   Search for more posts by SasyMama
Hi All
Since I am an engineer, I think I will try to contact some past associates in the auto industry and try to get a design off for a true chrome grill for the Prowler. I will start to work on this ASAP. As far as the gentleman in MI that does the dash parts, he did tell me that this is a vacuum method. The finish is not durable unless it is clear coated with a very durable finish. I think this is OK if done right. After all the grill is only plastic too.
Sasy
Ray
unregistered
posted 04-08-2001 10:23 AM           send a private message to SasyMama   Edit/Delete Message   Reply w/Quote   Search for more posts by Ray
Sassy ...
Careful ... Exterior parts, specially in the very front of the car where it is sujected to bugs and road debris, needs to be electroplated for duability. Vaccume plating is fine for interior pieces that are not 'stressed'.
If you DO go that route, though, let us all know how it holds up ... I found MANY place that do that process, just very few (1) that does the electroplate and will polish someting as tough as the Prowler grille.
SasyMama
posted 04-08-2001 10:39 AM     Click Here to See the Profile for SasyMama     send a private message to SasyMama   Edit/Delete Message   Reply w/Quote   Search for more posts by SasyMama
Hi
I just worked up a grill design and will show it to my fabricator this week. I think I have a very good shot at this.
Sasy
Todd Cameron
unregistered
posted 04-08-2001 11:20 AM           send a private message to SasyMama   Edit/Delete Message   Reply w/Quote   Search for more posts by Todd Cameron
Polished SS I think would be the way to go... a little clear coat and it will look like chrome and LAST.
2000 Black, 2001 Black Tie, 2001 Orange
IN Phil
posted 04-08-2001 11:37 AM     Click Here to See the Profile for IN Phil     send a private message to IN Phil   Edit/Delete Message   Reply w/Quote   Search for more posts by IN Phil
Have you checked out this source?
Prowler Grill
PG PRWLR
99 Red
leon kurzweil
posted 04-09-2001 09:10 AM     Click Here to See the Profile for leon kurzweil     send a private message to leon kurzweil   Edit/Delete Message   Reply w/Quote   Search for more posts by leon kurzweil
I have been sitting on an extra grille for 3 weeks now trying to determine who to send it to...I saw Joebob's at TMS and it looked pretty good and Laddie's from what I could tell through the bra looked good as well..both were done by the company in FL...I got a quote from a chromeservices.com for $500.00 but I have not heard from anyone else that has used them...I welcome any help and assistance...I'm thinking about just sending it to FL and rolling the dice...
Thanks
Leon
Mulholland
Borla Exhaust
Carlini Trans Cooler Cover
Ceramic Brake Pads
more to come
Gary C
posted 04-09-2001 10:59 AM     Click Here to See the Profile for Gary C     send a private message to Gary C   Edit/Delete Message   Reply w/Quote   Search for more posts by Gary C
My understanding is that the good chromers of plastic put down copper first and sand and polish then chrome. Am I correct?
jd2ksilver
posted 04-09-2001 12:26 PM     Click Here to See the Profile for jd2ksilver     send a private message to jd2ksilver   Edit/Delete Message   Reply w/Quote   Search for more posts by jd2ksilver
I looked through my records and I can't find it. It is my understanding,,it is a three coat process that custom coatings use,, copper, zinc (I think) then the chrome... Someone with more knowledge please correct me if I'm wrong.
The problem has always been it was too difficult to polish the inaccessible areas between coatings, hence the raw metal look at the rear of the fins.
SasyMama
posted 04-11-2001 08:30 PM     Click Here to See the Profile for SasyMama     send a private message to SasyMama   Edit/Delete Message   Reply w/Quote   Search for more posts by SasyMama
Thank you...
Laddie Roussel
>POA Lifetime Site Supporter
posted 04-11-2001 08:53 PM     Click Here to See the Profile for Laddie Roussel     send a private message to Laddie Roussel   Edit/Delete Message   Reply w/Quote   Search for more posts by Laddie Roussel
Custom Coatings process is:
Copper, Nickel, & Chrome...
Electroplated on Plastic....
adciocca
posted 04-11-2001 10:25 PM     Click Here to See the Profile for adciocca     send a private message to adciocca   Edit/Delete Message   Reply w/Quote   Search for more posts by adciocca
What is this guys name and number here in Florida that does the crome?
Thanks,
Antonio
2000 Prowler Woodward Edition (red/black-USA)
1993 Viper RT-10(red-USA)
1991 BMW 850i (black-USA)
2001 Mercedes S500(silver-USA)
2001 BMW Z8(silver-Italy)
2000 Audi A6 wagon (silver-Italy)
1987 Ferrari 328 GTB (red-Italy)
1985 Ferrari GTO (red-Italy)
1989 Ferrari Testarossa (red-Italy)
1996 Ferrari F50(red-Italy)
Laddie Roussel
posted 04-12-2001 05:09 AM     Click Here to See the Profile for Laddie Roussel     send a private message to Laddie Roussel   Edit/Delete Message   Reply w/Quote   Search for more posts by Laddie Roussel
Custom Coatings Corp. 850-562-0538.
4794C Woodlane Circle, Tallahassee, Fl. 32303
If memory is correct, his name is Bill ...
SasyMama
posted 04-12-2001 08:19 PM     Click Here to See the Profile for SasyMama     send a private message to SasyMama   Edit/Delete Message   Reply w/Quote   Search for more posts by SasyMama
Thanks Laddie
SasyMama
posted 04-12-2001 08:20 PM     Click Here to See the Profile for SasyMama     send a private message to SasyMama   Edit/Delete Message   Reply w/Quote   Search for more posts by SasyMama
PS
Laddie
Did you have yours done by hime, how is it?
WildCat
posted 04-12-2001 09:21 PM     Click Here to See the Profile for WildCat     send a private message to WildCat   Edit/Delete Message   Reply w/Quote   Search for more posts by WildCat
[QUOTE]Originally posted by Laddie Roussel:
[B]Custom Coatings Corp. 850-562-0538.
Laddie is correct
the last time it was posted they charged $400 and 10~12 week wait. I had mine done over a year ago and told them when I wanted it and I had it back but it was 7 weeks. At that time they said 6~8 weeks
Larry & Sue Mayes
Laddie Roussel
posted 04-13-2001 05:31 AM     Click Here to See the Profile for Laddie Roussel     send a private message to Laddie Roussel   Edit/Delete Message   Reply w/Quote   Search for more posts by Laddie Roussel
Sassymama, I've had mine grill almost 20 months (aug 1999) and I think it is fine... It wasn't until I heard other comments that I realized it wasn't completely polished. It looks fine to me & I would use Custom Coatings again... There's always a lot of talk, but, to date, NO one has come up with another source that will tackle chroming this grill... There is another grill being offered by M&L (I think)and you can always use the tape idea.
It took six or seven weeks to have mine done by CCC & that's what they quoted...
GaryE
POA Site Supporter and Vendor
Prowler JunkieProwler Products by Gary
posted 04-13-2001 07:09 PM     Click Here to See the Profile for GaryE     send a private message to GaryE   Edit/Delete Message   Reply w/Quote   Search for more posts by GaryE
Hi everyone, I know it has been quite awhile since you have heard from me. My health took a dump, but is now on the mend. I currently have 12 of our grills, Carlini Design, in production and should have some within the next 30 days. Check out our web site. I hope I can be of some help.
Post New Topic
