Thread Closed  Topic Closed
  Chrome center caps-------------
Post New Topic
Author Topic:   Chrome center caps-------------
ALLEY CAT
posted 04-04-2001 11:31 PM     Click Here to See the Profile for ALLEY CAT     send a private message to ALLEY CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by ALLEY CAT
Those of you who regularly pull off your tires, how do you prevent the breakage of chrome center cap????
Let us all know your secrets..........
Larry Salzman
Call 911 - there is a Prowler in my garage....
Ray
unregistered
posted 04-04-2001 11:39 PM           send a private message to ALLEY CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by Ray
That's an easy one ... buy the "tool" from Chrysler ... it's a long flat ended plastic tool that you can gently prey off the cap without damage. Has worked for me with great results.
Gary C
posted 04-04-2001 11:51 PM     Click Here to See the Profile for Gary C     send a private message to Gary C   Edit/Delete Message   Reply w/Quote   Search for more posts by Gary C
I wrap a flat bladed screw driver with a paper towel, I think the problem is when you reapply the cap.
ALLEY CAT
posted 04-04-2001 11:52 PM     Click Here to See the Profile for ALLEY CAT     send a private message to ALLEY CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by ALLEY CAT
Ray - I have the Miller tool, and have pulled one off with success. I'm asking this question for others who are having breakage problems taking off and replacing. Looking for other success stories.
Larry Salzman
ALLEY CAT
posted 04-04-2001 11:55 PM     Click Here to See the Profile for ALLEY CAT     send a private message to ALLEY CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by ALLEY CAT
Gary - then how can breakage be prevented when reapplying the cap? Any ideas are welcomed.
cnote6
posted 04-05-2001 12:02 AM     Click Here to See the Profile for cnote6     send a private message to cnote6   Edit/Delete Message   Reply w/Quote   Search for more posts by cnote6
Bam Bam Bam
hehe, goodnight
TGF spolier, bumper kit,Hardtop
Real Rod exhaust & Chromed front end protecters
2000 bumpers & shimmers
carlini trans cover & brake lines
Chromed front & rear of Kat
Chrome 2000 shifter
Dunlop SP 9000's
Gary C
posted 04-05-2001 12:08 AM     Click Here to See the Profile for Gary C     send a private message to Gary C   Edit/Delete Message   Reply w/Quote   Search for more posts by Gary C
Warm them up?????????????
WildCat
posted 04-05-2001 08:33 PM     Click Here to See the Profile for WildCat     send a private message to WildCat   Edit/Delete Message   Reply w/Quote   Search for more posts by WildCat
You should buy trim stick. It is a plastic stick about 6" long 1/8" thick and narrows on each end. Check at auto parts store or auto tool supplier.
The flat screwdriver will work but it can still ding the plastic, even with a towel around it.I have 4 I can show you that had a Towel wrapped around it and still messed up the edge of the slot.
To install, center the cap and push equally around. I suspect, if you install one side then pop the other down is what breaks the tabs. I have had mine off several times and broke one tab and it was when I was not in good position to push straight on.
Larry & Sue Mayes
This message has been edited by WildCat on 04-05-2001 at 08:34 PM
FL Phil
posted 04-05-2001 09:19 PM     Click Here to See the Profile for FL Phil     send a private message to FL Phil   Edit/Delete Message   Reply w/Quote   Search for more posts by FL Phil
The tool is Miller Special Tools #C4755. You can have your Chrysler Service Department Manager order them < $5.00 for you.
I've had a couple stems break the first time the cap is removed and used epoxy to repair. Haven't had another breakage after removing them a half a dozen times. I try to keep the caps evenly on the rim holding one side and gently tap the the center with the palm of my hand and move around the cap evenly set into place.
Easier done then said.
Hope that helps.
This message has been edited by CA Phil on 04-05-2001 at 09:21 PM
STARFLAME
posted 04-05-2001 09:54 PM     Click Here to See the Profile for STARFLAME     send a private message to STARFLAME   Edit/Delete Message   Reply w/Quote   Search for more posts by STARFLAME
Larry,
Why is EdM calling You,(BIG FOOT Salzman)???
STARFLAME
ALLEY CAT
posted 04-06-2001 08:58 AM     Click Here to See the Profile for ALLEY CAT     send a private message to ALLEY CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by ALLEY CAT
Reggie - for many reasons, I'm sure.
He is proud of his size 14 shoe size
Gary C
posted 04-06-2001 09:29 AM     Click Here to See the Profile for Gary C     send a private message to Gary C   Edit/Delete Message   Reply w/Quote   Search for more posts by Gary C
You know what they say about big Larry?
butchcee
posted 04-06-2001 10:19 AM     Click Here to See the Profile for butchcee     send a private message to butchcee   Edit/Delete Message   Reply w/Quote   Search for more posts by butchcee
The harder they fall?
AL
Yellow is DCOOLEST
Gary C
posted 04-06-2001 10:38 AM     Click Here to See the Profile for Gary C     send a private message to Gary C   Edit/Delete Message   Reply w/Quote   Search for more posts by Gary C
Amen.
2kprwlr
Prowler Enthusiast
posted 04-06-2001 01:11 PM     Click Here to See the Profile for 2kprwlr     send a private message to 2kprwlr   Edit/Delete Message   Reply w/Quote   Search for more posts by 2kprwlr
If you're going to be taking them off and on with some frequency, one thing I have found to work, is to get them off the first time (or if you bought replacements do this before you put them on the first time). Apply roughly 1cm bead of epoxy behind the tab. You can find some epoxies that have some flex to them. Do this behind all the tabs and let dry completely. Once dry, it will help support the prong during countless applications and removals. I would still recommend using the Chrysler tool to remove. The screwdriver works in a pinch, but better safe than scratched.
Prowlin' Doc
This message has been edited by 2kprwlr on 04-06-2001 at 01:12 PM
neal
DC Certified Prowler Tech
posted 04-06-2001 05:34 PM     Click Here to See the Profile for neal     send a private message to neal   Edit/Delete Message   Reply w/Quote   Search for more posts by neal
I have also had problem reinstalling center caps. I've broken a few myself. I have found that pushing 3 of the locking tabs in and taking a small screw driver and depressing the last locking tang in with the screw driver.
I hope this helps.
Neal
butchcee
posted 04-06-2001 05:50 PM     Click Here to See the Profile for butchcee     send a private message to butchcee   Edit/Delete Message   Reply w/Quote   Search for more posts by butchcee
I broke one also, but just glued the tab back on with C.A. (aka crazy glue, but good quality) and reinforced inside with a bead of high quality silicone.
AL
Yellow is DCOOLEST
This message has been edited by butchcee on 04-06-2001 at 05:51 PM
ALLEY CAT
posted 04-09-2001 08:44 PM     Click Here to See the Profile for ALLEY CAT     send a private message to ALLEY CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by ALLEY CAT
Thanks to all of you who helped add input to this question.
prwlyn
Visit Fred's Lord Of The Looks
posted 04-10-2001 09:13 AM     Click Here to See the Profile for prwlyn     send a private message to prwlyn   Edit/Delete Message   Reply w/Quote   Search for more posts by prwlyn
Ok, here is one of my "home" remedies for re-installing the caps. I have been using a bar of hand soap. This method is also used to make screws go into wood eaiser. Drag it lightly over the prongs and then apply light even pressure to the center of the caps, it will slide on just fine and the cap has not slipped off after. The first time you wash the car after that it washes whatever soap may be left on the inside. Do use the tool to remove them, it is just safer for sure.
Fred J. Henkel
http://www.lordofthelooks.com
ALLEY CAT
posted 04-11-2001 09:30 PM     Click Here to See the Profile for ALLEY CAT     send a private message to ALLEY CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by ALLEY CAT
Fred - I like it!
What about very lite layer of Vasoline?
Post New Topic
