Thread Closed  Topic Closed
  Speakers Help !
Post New Topic
Author Topic:   Speakers Help !
Nyle Wing
posted 01-20-2001 09:26 PM     Click Here to See the Profile for Nyle Wing     send a private message to Nyle Wing   Edit/Delete Message   Reply w/Quote   Search for more posts by Nyle Wing
I would like to upgrade my speakers only.
Is there a better set out there than the stock ones.
Or won't changing just the speakers help ?
Thanks for your Help
Nyle
davidn
unregistered
posted 01-20-2001 09:32 PM           send a private message to Nyle Wing   Edit/Delete Message   Reply w/Quote   Search for more posts by davidn
NYLE,
MB Quart IS the only way to go!!!
davidn
Nyle Wing
posted 01-20-2001 09:36 PM     Click Here to See the Profile for Nyle Wing     send a private message to Nyle Wing   Edit/Delete Message   Reply w/Quote   Search for more posts by Nyle Wing
Hey David give me plain english
Do you have part #s
Do you change all 6 speakers ?
Nyle
davidn
unregistered
posted 01-20-2001 09:46 PM           send a private message to Nyle Wing   Edit/Delete Message   Reply w/Quote   Search for more posts by davidn
Okay,
I would leave the speaker in the dash alone in the doors I changed them to mbquarts 4 inch(mbqkdc108) in back 6inch(mbqpkc116).
davidn
This message has been edited by davidn on 01-21-2001 at 01:45 PM
Glenn
posted 01-20-2001 11:05 PM     Click Here to See the Profile for Glenn     send a private message to Glenn   Edit/Delete Message   Reply w/Quote   Search for more posts by Glenn
Nyle,
Checkout my audio upgrade in the Garage on this site.
Glenn's audio upgrade
I list all the speakers part numbers with links the tho Mfg's. I also have MQ Quartz Q series plus Infinity Kappa's, and new subwoofers.
Glenn
This message has been edited by Glenn on 01-20-2001 at 11:08 PM
Nyle Wing
posted 01-21-2001 07:51 AM     Click Here to See the Profile for Nyle Wing     send a private message to Nyle Wing   Edit/Delete Message   Reply w/Quote   Search for more posts by Nyle Wing
Thanks
WPG
posted 01-21-2001 09:30 AM     Click Here to See the Profile for WPG     send a private message to WPG   Edit/Delete Message   Reply w/Quote   Search for more posts by WPG
I replaced my speakers with MB Quart (got the complete set from Sound Advice for $250):
1) Dash and rear: DKC 108 3.5" (they fit, but dont fit exactly, I am making a rubber spacer to make them fit perfectly)
2) Door: DKD 116 6.5" (the stock size is 6.75", so I had to add brackets to make them fit correctly)
I added a custom 12" speaker box to the trunk, which sounds pretty good and adds much-needed lower frequencies that the stock woofer can't touch. I am replacing it today with a 15" to go for even lower frequencies.
My new head unit should be in this week. When it arrives, I will post pics of the complete installation.
This message has been edited by William Gallagher on 01-21-2001 at 09:33 AM
WPG
posted 01-21-2001 09:36 AM     Click Here to See the Profile for WPG     send a private message to WPG   Edit/Delete Message   Reply w/Quote   Search for more posts by WPG
I forgot to add... the link to these speakers on the MB Quart website is http://www.mbquart.com/mobil/autobahn_coax.htm
I also wanted to add that these speakers sound excellent. With a frequency response out to 32,000HZ, the highs are very crisp and clean.
Post New Topic
