Thread Closed  Topic Closed
  Running over mudflap
Post New Topic
Author Topic:   Running over mudflap
MIKE GATLIN
POA Lifetime Supporter
posted 11-15-2000 05:08 PM     Click Here to See the Profile for MIKE GATLIN     send a private message to MIKE GATLIN   Edit/Delete Message   Reply w/Quote   Search for more posts by MIKE GATLIN
While parking at Black Barts in Flagstaff, I managed to pinch front flap between tire and sink hole while backing up. Net result, kink in fender, bracket all screwed up and flap in a couple of pieces. Have I seen posts about this problem being warrantied?
Gary C
posted 11-15-2000 05:31 PM     Click Here to See the Profile for Gary C     send a private message to Gary C   Edit/Delete Message   Reply w/Quote   Search for more posts by Gary C
Larry Lord told me that it is a factory item((mudflap) and will be warrantied?
If you have a problem you can always call for
Quicksilver
posted 11-15-2000 07:04 PM     Click Here to See the Profile for Quicksilver     send a private message to Quicksilver   Edit/Delete Message   Reply w/Quote   Search for more posts by Quicksilver
Prowlerman, is that a stack of nickles or are you just "HAPPY" to be PROWLERMAN! hehehe
PhxSuncat
unregistered
posted 11-15-2000 08:58 PM           send a private message to Quicksilver   Edit/Delete Message   Reply w/Quote   Search for more posts by PhxSuncat
Scott - looks like a roll of quarters.
Only in his dreams!
No man of steel there,
I've been told.
MIKE GATLIN
posted 11-15-2000 09:28 PM     Click Here to See the Profile for MIKE GATLIN     send a private message to MIKE GATLIN   Edit/Delete Message   Reply w/Quote   Search for more posts by MIKE GATLIN
PROWLERMAN..If you run out of change I have a rolled up madflap you can use. On warranty front..do you mean flap, fender and bracket assembly or just the flap is a warranty item?
Larry Lord
posted 11-15-2000 11:16 PM     Click Here to See the Profile for Larry Lord     send a private message to Larry Lord   Edit/Delete Message   Reply w/Quote   Search for more posts by Larry Lord
Mike,
My dealer (one of the best in my opinion) said that if the mudflap was purchased from a dealer and I had the receipt he would replace the fender at no charge under warranty. His thinking was that the fender was stock and the mudflap was a factory sold item and as such it would be covered under warranty. Labor to R&R and paint were also taken care of.
I've e-mailed you part numbers and information on the brackets as a separate item. They list at $235.00 per side.
I hope this helps.
Post New Topic
