Author | Topic: Horn |
blackcat POA Site Supporter Prowler Junkie From:atlanta, ga |
posted 07-06-2000 11:59 PM
I know this is an old topic so please forgive me but, I disabled the horn on my alarm. How do I reverse the condition. Thanks in advance, Blackcat |
posted 07-07-2000 01:06 AM
I looked in the Service and Diagnostic Procedure Manual and found the following: "The audio alarm output the horn and engine disable portion of th VTSS will not function until there has been four consecutive engine run cycles. When this has occured the total VTSS will function." If you have not just disconnected the battery, you might want to try disconnecting the battery and leave it disconnected for about 5 minutes and then reconnect. If you still have problems after this you should probably consult your Prowler tech. |
davidn unregistered Personal ScrapBook Admin Use |
posted 07-07-2000 01:16 PM
Blackcat, unlock the car from remote ,hold down lock and unlock at the same time for 10 sec.unlock. when locking that sould do it,i just tested on my car able and disable the same way . the owners manual on page 12 says that a long flash can be added when locking the car NOT!!!! gone to two dealers spend 2 hours with the scan tool(drbIII) no luck it is not there. looked at body, alarm and every where else can't find it along with two prowler techs!!! any ideas ?
posted 07-07-2000 07:37 PM
thanks guys. i'll give it a try |
