HOME PAGE OWNERS REGISTRY DISCUSSION FORUMS PROWLER STORE CONTACT 10th Anniv Wallpaper ABOUT
Prowler Products By Gary Tom Mills / Jefferson Auto
Topic:SPEAKER TROUBLE
DON WIEBERmy speaker behind the driver has a hum in it. no voice just a hum. can i turn it off or do i have to take the wire off? is that an easy job?
catfishyou need to unplug it,which means removing,what i will call that fuzzy panel covering it,or you can turn the balance to frt. only,but you will lose the lt and rt rr speakers also.you will have to remove all the plastic retainers to get the panel off,and some may break.they get brittle after all these years.
idiveIf I remember right, someone posted that (it was either the front or the rear speakers) don't have a plug and are soldered on. I can't remember whether that was for front or rear speakers. Maybe check pumpkin's page on speaker replacement.
Greg and Veta
quote:
rear speakers don't plug in as I recall
All material contained herein, Copyright 2000 - 2012 ProwlerOnline.com
E-Innovations, LP
