  Technical Questions & Answers
  won`t start if sits for 2 weeks
Author Topic:   won`t start if sits for 2 weeks
scottmartin
Prowler Enthusiast
posted 09-03-2018 04:30 PM     Click Here to See the Profile for scottmartin     send a private message to scottmartin   Edit/Delete Message   Reply w/Quote   Search for more posts by scottmartin
anyone else have problems with their Prowler not starting if it sits for a week or two - I put a brand new battery in June because of this issue - I bought new battery and it is back to not starting again if it sits. Anyone else have this problem??
DublinOH
posted 09-03-2018 05:18 PM     Click Here to See the Profile for DublinOH     send a private message to DublinOH   Edit/Delete Message   Reply w/Quote   Search for more posts by DublinOH
I have a 2000 that does this. I put a quick disconnect on the negative terminal. That solves the problem. I also have a 99 and my dad has an 02 and neither of them suffer from parasitic drain. One of these days I may get around to troubleshooting.
garysss
posted 09-03-2018 07:03 PM     Click Here to See the Profile for garysss     send a private message to garysss   Edit/Delete Message   Reply w/Quote   Search for more posts by garysss
Both of mine do it when weather gets colder. They are usually ok from May - October as long as I drive them once a month. November - April I use a battery tender. The 99 seems to drain faster then the 01. This is first year I left tenders on all summer.
padroo
posted 09-04-2018 08:39 AM     Click Here to See the Profile for padroo     send a private message to padroo   Edit/Delete Message   Reply w/Quote   Search for more posts by padroo
Have you measured it to see how much it is drawing?
http://www.amazon.com/gp/product/B0014DDK5O/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
This message has been edited by padroo on 09-04-2018 at 10:24 AM
HawaiiHaze
posted 09-05-2018 02:30 AM     Click Here to See the Profile for HawaiiHaze     send a private message to HawaiiHaze   Edit/Delete Message   Reply w/Quote   Search for more posts by HawaiiHaze
Mine has this problem, even after putting a new Optima battery in it. I think thr main cause for mine is the stereo system I had put in, which includes an always on USB charger. Anyway, I got myself a little battery tender a couple of months ago and now it starts like a charm every time. Highly recommend this strategy. The battery tender disconnects in just seconds, so not a hassle at all.
robin
posted 09-07-2018 10:05 AM     Click Here to See the Profile for robin     send a private message to robin   Edit/Delete Message   Reply w/Quote   Search for more posts by robin
Chrysler
Chrysler repair questions? Ask a mechanic for answers ASAP
Ask an ExpertCar QuestionsChrysler Repair
Prowler: plymouth..test light..#4 15amp fused Interior Lights circuit…
I have a 1999 Plymouth Prowler something is draining the battery. I have found through using a test light the problem is in the #4 15amp fused Interior Lights circuit. When I remove the fuse there is no battery drain. This circuit is for interior lights, door locks, and radio. I had disconnected the negative battery cable and connected my test light between them and that's how I traced my problem to #4 circuit. I have disconnected the glove compartment light switch, the door light switches, and the courtesy lights in the mirror. With these items disconnected and the fuse installed and the battery connected I let the car sit for four days and there wasn't any drain on the battery when I checked it with a volt meter. When every thing is connected all the lights work normally except for drain on the battery. I've been at this for over a week. Any thoughts, ideas, suggestions?
Greg
Share this conversation
Answered in 4 minutes by:
2/10/2012
Chrysler Mechanic: Amedee
Hello and Welcome to Just Answer. My name is XXXXX XXXXX I will try my best to assist you and your 100% satisfaction is my goal. I have been working on these vehicles for over 10 years so I am very familiar with this system and how they work. However, keep in mind, that I need some solid concrete facts/evidence/clues from you in order to give you a good answer about your vehicle. Please realize that all my answers are based solely on the info that you provide me with.
This is fuse number 4 in the fuse block correct? Not the power distribution center?
Ask Your Own Chrysler Question
Correct
Ok.. are you aware that there are 10 components on this circuit? Would you like me to list them all?
Yes. Please.
BCM
Ignition switch
Power mirror switch
Glove box lamp switch
radio
Remote Key less entry module
Right foot well lamp
Left foot well lamp
Front reading lamp switch
instrument cluster
Although the switches don't normally cause a battery draw... it is possible. However, I would start by checking the modules as one of them may be bad or staying awake causing your battery drain..
With the #4 15amp fuse removed I can unlock the doors with the drivers door switch but I can't lock them. Is this normal?
YES
When I have my test light connected between the negative battery cable and post and the 15amp fuse in and the swithches I listed disconnected, the test light is out. When I connect and disconnect either door light switch or glove compartment light switch one at a time the test light will come on and go out. When I connect the mirror lights the test light will come on but when I disconnect the mirror lights the test light will stay on. I then pull the fuse and wait ten seconds reinstall the fuse and the test light is out. Is this normal?
NO
I didn't think so. Where do I go from here?
Disconnect one component at a time to see which one is causing the biggest draw on the battery. It would be easier to use a voltmeter that can measure milliamps.
Little video...good info.
http://www.youtube.com/watch?v=zdIKNnwEjIs
This message has been edited by robin on 09-07-2018 at 10:31 AM
robin
posted 09-07-2018 10:21 AM     Click Here to See the Profile for robin     send a private message to robin   Edit/Delete Message   Reply w/Quote   Search for more posts by robin
If you can't find the parasitic draw.Then this maybe a cure for you.
Do you have after market add on's lights alarm stereo etc. These can cause your problem.
http://www.youtube.com/watch?v=GjuewYMXeXU
good luck check in with any results
jimsutton
posted 09-07-2018 05:53 PM     Click Here to See the Profile for jimsutton     send a private message to jimsutton   Edit/Delete Message   Reply w/Quote   Search for more posts by jimsutton
I have kill switch on most of my cars . and on the Prowlers they are mounted on a bracket above the battery . They are cheep and ez to install .. On the Street Rods they are hidden from sight ...
robin
posted 09-22-2018 09:27 AM     Click Here to See the Profile for robin     send a private message to robin   Edit/Delete Message   Reply w/Quote   Search for more posts by robin
Please try to post your solution if found.
scottmartin
Prowler Enthusiast
posted 09-22-2018 05:40 AM
I agree with Gary - I was having problems with mine starting if it sat for a week or two - I noticed the negative post on the battery was not tight even though I had tightened the nut as tight as possible so I crimped the terminal a bit so it fits tight to the battery post and have not had a problem the last 3 weeks. Hopefully this resolved my problem - appears to have.
NullMind
posted 09-28-2018 10:27 AM     Click Here to See the Profile for NullMind     send a private message to NullMind   Edit/Delete Message   Reply w/Quote   Search for more posts by NullMind
Same problem here, 2 weeks and the battery is flat .. unfortunately where I park it at the moment (underground secure garage) I have no access to a power plug, so no battery tender for me
scottmartin
Prowler Enthusiast
posted 09-29-2018 03:41 AM     Click Here to See the Profile for scottmartin     send a private message to scottmartin   Edit/Delete Message   Reply w/Quote   Search for more posts by scottmartin
I haven`t fired up the cat for a couple of weeks - I will try today to see if it starts- if it does then I believe it was because the terminal on the negative post of the new battery I bought was to loose even though I tighten it as tight as the bolt would allow. Even then I could twist the terminal so I grabbed some pliers and slightly crimped the terminal and it has been starting - but I will try because I think this has been the longest time sitting since I tries. I will keep u posted.
scottmartin
Prowler Enthusiast
posted 09-29-2018 01:38 PM     Click Here to See the Profile for scottmartin     send a private message to scottmartin   Edit/Delete Message   Reply w/Quote   Search for more posts by scottmartin
well it started no problem and usually it doesn't when sitting this long. Hopefully that was my problem - crimp the negative terminal so it fits tight to the negative post.
garysss
posted 09-29-2018 07:08 PM     Click Here to See the Profile for garysss     send a private message to garysss   Edit/Delete Message   Reply w/Quote   Search for more posts by garysss
Glad to hear you might have found your problem.
scottmartin
Prowler Enthusiast
posted 10-05-2018 04:29 PM     Click Here to See the Profile for scottmartin     send a private message to scottmartin   Edit/Delete Message   Reply w/Quote   Search for more posts by scottmartin
Well so much for that theory / hope - car wouldn't`t start today. Must have an electrical drain somewhere - no aftermarket accessories have been added which draws any amps - back to trouble shooting. I thought the loose negative terminal on the battery was the problem but it was not. It seemed to have rectified the problem but today. Well the car will be going away for the winter storage soon so I will have all winter to research the problem.
ed monahan
posted 10-05-2018 04:43 PM     Click Here to See the Profile for ed monahan     send a private message to ed monahan   Edit/Delete Message   Reply w/Quote   Search for more posts by ed monahan
Good luck. I hope you can find it. Keep us posted as it is somewhat of a common problem.
katmat
posted 10-21-2018 08:25 PM     Click Here to See the Profile for katmat     send a private message to katmat   Edit/Delete Message   Reply w/Quote   Search for more posts by katmat
My 2000 has started to have this problem. If it sits w/ the battery connected for a day or 2, the battery will be dead. if I unhook the battery there isn't a problem.
For the last 2 years I have had some noise from my radio when it is on (sounds like the tape motor is running). When I was putting the car away for the winter, I noticed when I opened the passenger door & moved the door back & forth I could hear a static sound from the door speaker w/ the radio off (then I disconnected the battery & moved the door there wasn't a sound). I'm wondering if the radio isn't the power drain problem. I have a stock radio. I guess I will need to do some tracing out next spring.
fvee25
Prowler Enthusiast
posted 10-22-2018 06:40 AM     Click Here to See the Profile for fvee25     send a private message to fvee25   Edit/Delete Message   Reply w/Quote   Search for more posts by fvee25
Most radios whether factory or aftermarket have
a wire that connects to constant power so as to keep
any presets or adjustments constant. It is a very small
drain. I always keep mine on a tender.
garysss
posted 10-22-2018 07:07 AM     Click Here to See the Profile for garysss     send a private message to garysss   Edit/Delete Message   Reply w/Quote   Search for more posts by garysss
Is that pull the radio fuse next time and leave battery connected. If it starts it might be the radio.
