Author | Topic: Power Steering Pump |
TJR178 Prowler Enthusiast From:Erie, PA |
posted 08-23-2018 06:12 AM
Hi Everyone, I'm trying to remove my power steering pump, but I can't find a tool to remove the fluid return line from the pump. It's an 18mm nut, but it's really hard to get at with any tool that I have. If I can get this line off, I can remove the pump and change out my failed pulley. Can anyone suggest anything? Thanks! |
posted 08-23-2018 06:13 AM
FYI, #2 is what I'm talking about. |
posted 08-23-2018 09:32 AM
need a special type of wrench slides over the top second youtube might help a bit more good luck. http://www.youtube.com/watch?v=BGBUv5r9fk0 http://www.youtube.com/watch?v=wZanabsjXmk This message has been edited by robin on 08-23-2018 at 09:52 AM |
posted 08-23-2018 09:34 AM
Thanks, Robin. I actually tried those, but due to the fact that there is no room for the wrench to fit/turn, they didn't work. I was just thinking about trying a crows foot wrench on a rachet. I'm going to try that today once I go get a set of crows feet. |
u00tjs2 a POA Site Supporter Prowler Junkie From:ft wayne, in, USA |
posted 08-23-2018 09:41 AM
Search for; Flare nut wrench @ Sears, Amazon or??? A Crows foot might be easiest to access. Good luck ------------------ |
posted 08-24-2018 07:54 AM
Update: I managed to remove the nut last night with this wonder tool called a crescent wrench. I hate using these things, but it worked with no damage to the nut. |
posted 08-24-2018 07:57 AM
Here's the bad pulley as reference. You can see where the wheel was spinning on the boss causing the rattling, which was getting worse: New one: |
