Author | Topic: Fuel leak part II |
posted 06-22-2018 11:41 AM
Not sure what the heck is going on here.....Took a ride with Sharon the other day, again I smelled fuel when I pulled into the garage. I lifted the carpet in the trunk and opened up the hatch for access to the fuel tank. Fuel was leaking again. And again the one fuel line (closest to the passenger compartment) was lifted off its fitting. When I lifted it further fuel started to gush out. Not a good scenario. So, I cable tied each fuel line female coupling to the tank cap male nipple. Two cable ties per fuel line. Then I used one cable tie around both lines. Then I took a folded in half sponge and placed it on top of the fuel lines to create a interference fit between the inside of access panel and the top of the fuel lines hoping to keep them pushed downward. Anyone familiar with this fuel line hook up? Why would I be having this issue all of a sudden? Thanks in advance for comments and clues. Lou |
posted 06-22-2018 12:14 PM
What hoses is coming loose?
This message has been edited by robin on 06-22-2018 at 12:22 PM |
posted 06-22-2018 01:42 PM
First, check that female connector is not broken at place were male tabs go. (little windows) Carefully bend male tabs (in last picture) outward slightly so female with click in place when properly seated. If that doesn't work, you'll need to replace fuel pump housing. Contact Tom Mills, he may have a housing. Or, if your repairs holds, let it be. This message has been edited by Tomcal on 06-22-2018 at 03:27 PM |
posted 06-23-2018 09:54 AM
WOW blew my presentation out of the water Tomcal! Fantastic visual display. |
posted 06-23-2018 10:29 AM
Tomcal, Thanks guys. The hose coming off is shown in the second photo as detached. The line with the silver cap on the post or nipple... |
posted 06-30-2018 07:37 PM
Went out for a long ride today (June 30th) and tossed the Kat around the curves a bit hard. Got home.....No Fuel Smell.. Good news!! I believe the issue is resolved! |
posted 07-02-2018 07:08 PM
You are playing with a potential fire hazard using cable ties. It is best to follow Toms advise and bend the metal clips to prevent the hose from coming off. Leaking fuel could hit the exhaust and you will have a heck of a fire. Best to fix it the right way. |
posted 07-03-2018 11:45 AM
quote: Thanks for the safety tip.....I realize this was a serious condition! I still don't know why it all of a sudden just occured. |
posted 07-03-2018 10:24 PM
Just wear & tear on a car and vibrations will cause this. Just bend the tabs to make it lock down properly and your troubles will be over. |
posted 09-11-2018 08:15 PM
This may be my issue, the previous owner tried to seal it with jb weld or something similar. May have to replace the housing top and both female connectors. I’ll post a picture once I can work on it some. |
posted 09-12-2018 07:46 PM
Found my fuel leak on #4 Silver - look at what they did to this!!! Whatever that is will not come off, feels almost like JB Weld. Leak is coming from under the JB Weld in between the two nipples. Looks like I will need a new top, can I get those separate from the assembly, and are they Prowler specific? Any input would be appreciated. I need to get this done before anything else, as it is really pushing out a lot of fuel when the key is on. On a positive note, she starts right up and runs well. |
posted 09-12-2018 09:26 PM
Tom Mills is the resident expert on replacement Fuel Pumps. Give him a call to see if he has a part (canister) for you, or where to get it. He's in the vendor section on home page. PH (574) 259-6875 This message has been edited by Tomcal on 09-12-2018 at 09:27 PM |
posted 09-12-2018 10:55 PM
If you need the part with the line nipples on it, the part that is in the picture it was never sold separately, only available with the complete pump assembly. And the only hope you would have to get one now is if someone here would have an old used pump assembly that they replaced years ago. I would like to find a couple myself. Good luck hunting. You might remove the pump and clean the gook off of the lid and see what you have under there. You may be able to fix it if it is a crack in the plastic. We have some amazing glue on the market now. Tom This message has been edited by Tom Mills on 09-12-2018 at 11:00 PM |
posted 09-12-2018 11:17 PM
Thanks Tom, was hoping that the canister top would interchange with another Chrysler vehicle from that time frame. Looks very similar to a couple, but looks like it might be a hard find. |
posted 09-13-2018 08:14 AM
The similar ones are the wrong angle. Won't work. Clean up your lid and see what you have, might be repairable. |
posted 09-13-2018 01:50 PM
give these guys a call! just maybe click on number 1 fuel pump 4865223AB
This message has been edited by robin on 09-13-2018 at 02:14 PM |
posted 09-13-2018 02:09 PM
I will do some research on that later today but I would be totally surprised if it will fit a Prowler |
posted 09-13-2018 05:36 PM
Hi Mr. Randall, It is recommended you start a fresh thread on your particular issue. My particular issue is resolved and closed as far as I am concerned. It seems your particular issue involved a failed repair using JB Weld......I don't believe that will work long term. Regards, |
posted 09-13-2018 07:07 PM
http://www.moparpartsoverstock.com/p/__/MODULE-KIT-Fuel-PumpLevel-Unit/10139753 /RL016845AA.html This part is no longer available. |
posted 09-13-2018 09:13 PM
Looks like I hijacked quincy's thread, please move to the new thread. Thanks, |
posted 09-14-2018 10:32 AM
Lesson learned from both post.... Don't fool around with the fuel lines. You're risking a fire . This is not the place to use home made fixes you will get burned. Quincy I hope you resolve your problem. TLRandall we will see you in your new thread. .take care This message has been edited by robin on 09-14-2018 at 10:34 AM |
