  Technical Questions & Answers
  "Clunk" from front end over slow bumps
Author Topic:   "Clunk" from front end over slow bumps
kayaksrfr1069
posted 06-15-2018 08:07 AM     Click Here to See the Profile for kayaksrfr1069     send a private message to kayaksrfr1069   Edit/Delete Message   Reply w/Quote   Search for more posts by kayaksrfr1069
Im hearing a 'Clunk' That I can feel in the footwell since after the work I had done on the car... I cant identify what it is but of course my first thought was the new lower ball joints... I raised the car and did the crowbar trick, and pulled on the wheels, and theyre perfectly fine. No play. Here are the conditions:
Going into and out of the driveway (Usually on an angled approach)
Going over a speed bump (Slowly of course... it will do it in the front when both the front AND rear wheels go over the bump)
It doesnt seem to do it any other time, Im thinking suspension movement past a certain point, and it seems to primarily be coming from the drivers side.
Here is a list of the work I did on the front end:
New lower ball joints (Updated version)
New VSLs
Crossbar modification tying in shock towers
4 wheel alignment
Im also wondering if having the car on jack stands for ~3 months could have screwed up the old front shocks, because the rear had locked up once they were extended (which is why I wound up replacing the rears)
Thoughts please?
This message has been edited by kayaksrfr1069 on 06-15-2018 at 08:08 AM
jimsutton
posted 06-15-2018 09:28 AM     Click Here to See the Profile for jimsutton     send a private message to jimsutton   Edit/Delete Message   Reply w/Quote   Search for more posts by jimsutton
What shocks are on the car ??? Some of the Prowlers had the Dynamic shocks,and I had a set of them on mine they made a sound like that - they were wore out and the spring was the only thing holding them to gather . Only way to check them is take them off the car and check them out ..
401KAT
posted 06-15-2018 10:35 AM     Click Here to See the Profile for 401KAT     send a private message to 401KAT   Edit/Delete Message   Reply w/Quote   Search for more posts by 401KAT
make sure whoever did work tightened bottom of front coilovers and other components...U have to loosen several pieces when working with the a-arms and joints....jim
ALLEY CAT
posted 06-15-2018 10:39 AM     Click Here to See the Profile for ALLEY CAT     send a private message to ALLEY CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by ALLEY CAT
From his avatar picture, he has a silver cat [ 2000 model or newer ]....which had KONI shocks when new.
kayaksrfr1069
posted 06-15-2018 10:50 AM     Click Here to See the Profile for kayaksrfr1069     send a private message to kayaksrfr1069   Edit/Delete Message   Reply w/Quote   Search for more posts by kayaksrfr1069
It still has the stock Konis in the front... I'll talk to the alignment guy. Thanks guys!
This message has been edited by kayaksrfr1069 on 06-15-2018 at 10:51 AM
Tom Mills
POA Site Supporter and Vendor
prowlerparts@jeffersonautocollision.com
posted 06-15-2018 06:46 PM     Click Here to See the Profile for Tom Mills     send a private message to Tom Mills   Edit/Delete Message   Reply w/Quote   Search for more posts by Tom Mills
A clunk going in and out of the driveway at an angle is usually the rear frame braces that go forward out at an angle from the rear crossmember. Tighten them up and it goes away.
kayaksrfr1069
posted 06-15-2018 10:42 PM     Click Here to See the Profile for kayaksrfr1069     send a private message to kayaksrfr1069   Edit/Delete Message   Reply w/Quote   Search for more posts by kayaksrfr1069
I can check them Tom but the clunk is coming from the front of the car.
mslc10
posted 06-17-2018 10:10 PM     Click Here to See the Profile for mslc10     send a private message to mslc10   Edit/Delete Message   Reply w/Quote   Search for more posts by mslc10
Do you feel it in the steering wheel? Is there any play/sloping the steering wheel? If so chk steering mid shaft to steering colum shaft bolts....
kayaksrfr1069
posted 06-18-2018 08:55 AM     Click Here to See the Profile for kayaksrfr1069     send a private message to kayaksrfr1069   Edit/Delete Message   Reply w/Quote   Search for more posts by kayaksrfr1069
I can check that but steering feels fine, I do not feel it in the wheel but I do in the floorboard on my left foot. Shes going back to the shop this week...
dbudner
posted 06-19-2018 06:12 AM     Click Here to See the Profile for dbudner     send a private message to dbudner   Edit/Delete Message   Reply w/Quote   Search for more posts by dbudner
I had lose bolts around the suspension pushrod. All were around the top. Also had the shocks leak later but there was no noise after I went through and re-tightened everything.I bought the car new and they were lose from the factory. Just a thought...
mslc10
posted 06-21-2018 07:03 PM     Click Here to See the Profile for mslc10     send a private message to mslc10   Edit/Delete Message   Reply w/Quote   Search for more posts by mslc10
VSLs mounted correct side of sway bar so they are not hitting the frame?
Sway bar bolts thightened?
Lock nuts tight on the adjustments of VSLs?
This message has been edited by mslc10 on 06-21-2018 at 07:05 PM
kayaksrfr1069
posted 06-24-2018 07:12 PM     Click Here to See the Profile for kayaksrfr1069     send a private message to kayaksrfr1069   Edit/Delete Message   Reply w/Quote   Search for more posts by kayaksrfr1069
VSLs are fine, initial diagnosis is that the passenger side shock is binding or seizing... which is pretty much what happened with the drivers rear when she was sitting on jack stands.
