Technical Questions & Answers Belt Squealing when turning on A/C
Author | Topic: Belt Squealing when turning on A/C |
prowlerFreek POA Site Supporter Prowler Junkie From:Spotsylvania, VA |
posted 06-07-2018 06:44 AM
Hey folks, I'm not the most technical person when it comes to cars, but just to summarize: I just had my timing belt replaced, but a few days later I heard a loud squealing when turning on my A/C. And every so often it would squeal VERY loud. It's not consistent, only for about 3-5 seconds when turning on the A/C, and randomly every 10 mins or so while driving. Not sure if the timing belt is really related, but I'm assuming the mechanic had to take off the A/C belt to get to the timing belt, and maybe something just didnt get tightened? If possible, I want to see if there's something I can do in my own garage to fix this issue before taking it back to the mechanic. Thoughts? Thank you! Steve This message has been edited by prowlerFreek on 06-07-2018 at 06:44 AM |
posted 06-07-2018 07:57 AM
7-13-2013 quote: |
posted 06-07-2018 09:48 AM
belt has to be really tight....we have all had this ...like a.c. said needs to be torqued...easy fix |
posted 06-07-2018 11:21 AM
OK thanks guys, now I just need to learn how to tighten the belt :D |
posted 06-07-2018 03:22 PM
Just for clarification: The Timing Belt is an Internal belt (Inside the engine) that drives the water pump and camshaft. The Serpentine Belt is an External Belt that is essentially flat on one side with small grooves on the other side. It drives the Alternator and A/C Compressor from the Crankshaft Pulley. The "V" Belt drives the Power Steering Pump, again off the Crankshaft Pulley. There is a torque specification for New Belts and a different torque specification for Used Belts. I spent the money and purchased a Belt Tension Gauge so that I could better be able to tighten my belts correctly. If memory serves me correctly, the New Belt Tensions are 190 foot pounds for the serpentine belt and 150 foot pounds for the A/C "V" Belt while the used tension is 120 foot pounds for both but I would strongly suggest checking your repair manual for the correct numbers. As a precaution, I will tell you that the power steering pump has a second bolt that needs to be loosened in order to allow for adjustment. It is somewhat hidden and unless you know to look for it, it is easy to miss. Below are a couple prior threads where this was discussed: This message has been edited by alrtg on 06-07-2018 at 03:22 PM |
posted 06-07-2018 06:07 PM
To Reclairify.....the serpentine belt drives the power steering pump and alternator with tensioner...The v-belt is A.C. only with a tensioner...both tensioners have to have nut on face of pully loosened and then tighten adjustment bolt.... |
posted 06-07-2018 07:05 PM
posted 06-07-2018 07:44 PM
and not to be an ass but power steering pump is mounted rigid..adjustment is in tensioner....you are right that a bolt is hidden but it is behind tensioner pully...it is a pain but doable.... |
