Technical Questions & Answers Part number for Starter (99) (Page 1)
Author | Topic: Part number for Starter (99) |
NullMind POA Site Supporter Prowler Junkie From:London |
posted 01-24-2018 06:18 AM
Hi everybody My 99 seems to be having problems with the starter (battery seems fine, turn it gives one single click, try a few times and then it starts) Can somebody tell me the Part number for the 99 starter please ? Carlos |
alprowl POA Site Supporter Prowler Junkie From:Katonah , NY, USA |
posted 01-24-2018 07:08 AM
NOT AN EXPERT! But it sounds like a few times when I've had loose terminal clamps or bad ground cable connection |
posted 01-24-2018 07:24 AM
quote: Yeah, I tough it might be the clamps, but it also did it for me when I had the jump cables on it, but will have them re-check them |
posted 01-24-2018 08:09 AM
Check all connections especially ground wire to frame Carlos. |
posted 01-24-2018 10:16 AM
04609150 STARTER Prowler 99 ------------------ |
posted 01-24-2018 10:47 AM
http://www.ebay.com/itm/Starter-Plymouth-Prowler-1997-1998-1999-3-5L-V6/331362224569?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D1%26asc%3D49923%26meid%3D2c7f4d2c69d34206b7 4609150 This message has been edited by robin on 01-24-2018 at 10:49 AM |
posted 01-24-2018 11:02 AM
http://www.ebay.com/itm/NEW-Starter-for-Chrysler-LHS-New-Yorker-Plymouth-Prowler-Eagle-Vision-Intrepid/162180570192?hash=item25c2b71c50:g:lNcAAOSwi8xaKXtC&vxp=mtr |
posted 01-24-2018 11:09 AM
quote: Did you try putting the negative jumper to the frame or metal instead of the battery? |
posted 01-24-2018 11:55 AM
I little trick I have used for checking connections is have someone in the car turn the key to the start position and someone under the hood with a large coin. Wedge the coin between the battery terminal and the battery lead. It bridges the connection and if it is bad you will know it. This can be done with any metallic object but usually you have a coin in your pocket if you own a Prowler. lol You can use this method on any connection you can get to. |
posted 01-24-2018 05:49 PM
quote: No, I was using one of those battery powered jumpstart systems, should I try with it ? |
posted 01-24-2018 05:51 PM
quote: I was able to get to the starter, the part on mine is 4609346ab .. from my googling the one I have it’s listed as 00 onwards ... strange |
posted 01-24-2018 05:52 PM
quote: Can you help me with this one, how do I check ground wire ? What should I be looking for ? Told the mechanic to check, but not sure he did, need a new mechanic, he is just set on replacing my starter |
posted 01-24-2018 06:46 PM
Loose cable or bad starter solenoid. Try starting with the headlamps on. If it is a cable, it will kill the headlights for a second or two. If the headlamps stay bright, change the solenoid. This message has been edited by phil2237 on 01-24-2018 at 06:48 PM |
posted 01-24-2018 07:03 PM
Good thread here Carlos. 1...Take both cables off battery and clean the post. Plus the cable ends. 2 if 1 doesn't fix problem there is a relay in the engine compartment on drivers side . Remove side panel to access. Switch the relay out with one beside it. Replace both and try to start. This message has been edited by robin on 01-25-2018 at 12:25 PM |
posted 01-24-2018 07:17 PM
Diagrams for relays provided by padroo. http://www.prowleronline.com/ubb/Forum2/HTML/005594.html
This message has been edited by robin on 01-24-2018 at 07:23 PM |
Stroker Prowler Junkie From:Sevierville, Tennessee, USA |
posted 01-24-2018 07:49 PM
If you buy a new or rebuilt starter make sure you can return it if mail order. I bought a new one from Summit Racing the nose was wrong the solenoid was clocked so it would not fit. Bought a rebuilt from Auto Zone same thing. I wound up taking it off and to a starter rebuild shop. He tore it down and assured me it was like new inside. I had him put on a new solenoid which is not repairable only replaceable. We broke old one open and the contacts were worn off. Some where my post with pictures is on POA. |
posted 01-24-2018 08:47 PM
quote: I've done it many times with the jump box. You'll know right away if the problem is the ground cable connection |
posted 01-24-2018 09:32 PM
Stroker's pictures are on this thread. http://www.prowleronline.com/ubb/Forum2/HTML/005332.html |
posted 01-25-2018 06:39 AM
quote: So if it starts fine every time doing it that way, then one knows for sure the ground connection has a problem ? because I have grounded it that way .. correct ? I just wish the problem was persistent, it's easier to diagnose, if I run with the car for a little while, it does not seem to happen This message has been edited by NullMind on 01-25-2018 at 06:40 AM |
posted 01-25-2018 07:19 AM
quote: Based on my experience, yes, it's the ground cable... When there is a problem I will hear one loud click and the engine wil not turn over...and if I don't do anything about it, (clean/tighten cable) it may work fine for a few days and then a week later it won't start again. |
posted 02-03-2018 11:46 AM
How about an update? |
posted 02-06-2018 09:05 AM
quote: Sure It seems to indeed be the starter, I cleaned the contacts .. no help, I tried to use a jumpstart and ground it to the car metal, no help, when I start and it fails, the lights dont dim So far it seems to be the starter, it's a hit or miss, the weird bit is if I drive on it for a little while, it starts fine the next time My only confusion is the starter on mine has the model 04609346AB, but from my investigation thats a starter for the 00 onwards, mine is a 99, my other issue is, are all 04609346AB the same ?, I see some Chrysler models (300M for example) seem to have the same model number, but I read somewhere here somebody ordering one and the fit was not the same ... ugh Unsure the best place to get another one |
posted 02-06-2018 09:08 AM
example lists for the Prowler 99, but the Model is 4609011 not 04609346AB That model for instance shows on this starter below I could buy locally (well, Germany ... close enough) .. but unsure if it fits https://www.ebay.co.uk/itm/Starter-Motor-CHRYSLER-CONCORDE-3-5-LX-NEW-YORKER- 3-5-NEW/201899149751 This message has been edited by NullMind on 02-06-2018 at 09:11 AM |
posted 02-06-2018 09:29 AM
quote: Just the solenoid ? not the entire starter ? any idea what the part number is ? |
posted 02-06-2018 09:51 AM
One more item, how do I check if it's not the Ignition switch ? |
