  Technical Questions & Answers
  Ran out of gas now engine runs rough in mid range speeds
Author Topic:   Ran out of gas now engine runs rough in mid range speeds
John1923t
Prowler Enthusiast
posted 11-29-2017 08:21 AM     Click Here to See the Profile for John1923t     send a private message to John1923t   Edit/Delete Message   Reply w/Quote   Search for more posts by John1923t
Gas gauge said a little less than 1/4 tank, and it ran out of gas. I put in 2 gallons and drove to a fuel station. Now it idles and at almost full throttle it runs ,but at mid range /lower speeds it has no power and will not run correct.any one have this problem ? I might be selling a beautiful prowler cheap ...
robin
posted 11-29-2017 11:53 AM     Click Here to See the Profile for robin     send a private message to robin   Edit/Delete Message   Reply w/Quote   Search for more posts by robin
running out of gas introduces air into the system and can damage fuel injectors. I don't think its the fuel filter.
Check and see if it threw any codes?
could it some how have gone into safe mode . Try disconnecting negative cable on battery and then wait couple minutes and reconnect.
This message has been edited by robin on 11-29-2017 at 12:49 PM
robin
posted 11-29-2017 11:59 AM     Click Here to See the Profile for robin     send a private message to robin   Edit/Delete Message   Reply w/Quote   Search for more posts by robin
Throttle positioning sensor may have gone bad.
http://www.partsgeek.com/mmparts/throttle_position_sensor/chrysler/prowler.html
2001 Plymouth Prowler Throttle Position Sensor 6 Cyl 3.5L Walker
Part # P311-43B88EA   Manu # 200-1104  Condition: New
This message has been edited by robin on 11-29-2017 at 12:06 PM
quincy
posted 12-04-2017 01:27 PM     Click Here to See the Profile for quincy     send a private message to quincy   Edit/Delete Message   Reply w/Quote   Search for more posts by quincy
John....any update in regards to your recent issue???
John1923t
Prowler Enthusiast
posted 12-12-2017 11:06 PM     Click Here to See the Profile for John1923t     send a private message to John1923t   Edit/Delete Message   Reply w/Quote   Search for more posts by John1923t
Sorry, went on a trip to see new grandson I'll work on it this week end. I'd like to drive it for xmas.
John1923t
Prowler Enthusiast
posted 12-12-2017 11:08 PM     Click Here to See the Profile for John1923t     send a private message to John1923t   Edit/Delete Message   Reply w/Quote   Search for more posts by John1923t
Tried the battery trick, no help...
phil2237
posted 12-13-2017 11:18 PM     Click Here to See the Profile for phil2237     send a private message to phil2237   Edit/Delete Message   Reply w/Quote   Search for more posts by phil2237
You might just have air in the fuel line, The fuel pump will not create enough fuel pressure to pass thru the injectors. Before you buy all these parts, hook up a pressure tester to the fuel port at the top of the engine, turn the key on and bleed the port valve by either loosen the tester hose or by opening the small relief valve. You can buy a cheap tester from Harbor tools. If the car ran fine before running out of fuel, This is what it sounds to me is your problem. It is very easy to do & you don't have to be a mechanic to perform this repair. You may have to turn the key on for 10 or 15 seconds many times to bleed it. Try this before you spend money for parts need. (( Just My Opinion ))
robin
posted 12-14-2017 09:39 AM     Click Here to See the Profile for robin     send a private message to robin   Edit/Delete Message   Reply w/Quote   Search for more posts by robin
Great idea Phil... The old Schrader valve..
John1923t
Prowler Enthusiast
posted 12-23-2017 09:20 AM     Click Here to See the Profile for John1923t     send a private message to John1923t   Edit/Delete Message   Reply w/Quote   Search for more posts by John1923t
Filled a half tank of gas and drove it for about 30 min. and there was no change. So I took it to get the codes read and it said the evaporative canister was bad. And an engine misfire between cylinders 1 and 12. (Yes it said 12) Ok now the good news I bought a bottle of CRC power 1 tank power additive to put in the car and the idle smoothed out within 10 mins. And the car gradually straightened out over the next couple times I drove it. The check engine light went off and I checked the codes again and the canister code was off.
I decided to unhook the battery over night and read the codes again after I drove to work and back,60 miles , and no codes. It has more power and still idles perfect. Check engine light is off.
robin
posted 12-23-2017 10:12 AM     Click Here to See the Profile for robin     send a private message to robin   Edit/Delete Message   Reply w/Quote   Search for more posts by robin
good to hear John..
Now don't run out of gas LOL
garysss
posted 12-23-2017 10:19 AM     Click Here to See the Profile for garysss     send a private message to garysss   Edit/Delete Message   Reply w/Quote   Search for more posts by garysss
John I would not put up with these problems, you should sell it to me for next to nothing and be done with it. LOL
Glad you are back on the road and thanks for following up with results. Might pay to put a bottle of this stuff in once a year.
