Technical Questions & Answers the steering gear more precise or direct
Author | Topic: the steering gear more precise or direct |
tilack Prowler Newbie From:bern |
posted 08-14-2017 07:02 AM
Hello guys Can you help me make the steering gear more precise or direct. The center position is too much leeway. There is another steering mechanism that works better, or you can adjust it mechanically better. Thank you for feedback |
posted 08-14-2017 10:09 AM
Several items to check in this thread. Lower ball joint Tires what do you have on your car? Wonder bar. Frame brace.? http://www.prowleronline.com/ubb/Forum1/HTML/019634.html robin |
posted 08-14-2017 10:24 AM
This contains numbers on alignment.. http://www.prowleronline.com/ubb/Forum2/HTML/002819.html
robin |
posted 08-14-2017 10:57 AM
I have 3 prowlers...2 have less than 20k ...steering is like they are on rails...3 rd car has 34k..just acquired....and has Some play...Im in process of doing Robin's checks...will let u know what i find...jim |
posted 08-15-2017 05:41 PM
I'd be curious as well. Mine has 8500 miles on it and has been perfect right up until a few months ago. Just started feeling play in it one day. It's not a lot, just enough to be irritating and to wonder what happened weezy |
posted 08-15-2017 07:06 PM
If all other things check out then Loosen and then re tighten the bolt on the steering yoke as it comes thru the firewall to engine compartment! Short story..had dealer replace the steering shaft as its joint had slop in it. Got car back and drove it home and it was sloppier than when I took it in! Don't believe me ? Mark the position of the bolt/nut , then loosen 2-3 turns , then tighten it back up. As long as you count the turns properly, you will surpass your original Mark. And take up slack in the yoke-to-shaft. Of course you could have the small u- joint in the shaft going bad also..... This message has been edited by mslc10 on 08-15-2017 at 07:15 PM |
posted 08-15-2017 08:45 PM
Noted....and will check that too.....jim quote: |
posted 09-26-2020 08:25 PM
Any updates from posters.....? |
