Author | Topic: Thoughts on rear rotors |
posted 06-14-2017 01:48 PM
Does anyone happen to know of standard rotors that fits the rear of the prowler??? IE: If I were to change out the OEM, what can be used as a replacement? Although this will add weight, I was thinking that the benefit in cleaner wheels (Being able to use ceramic pads) is a good trade off.... Any thoughts out there? Many Thanks |
posted 06-14-2017 02:05 PM
Hello Rich.. Guess who... The prowler has specific rear rotors. they are still available to purchase about 400 a side. not suppose to use ceramic pads. The only person that has duplicated a rotor is Bill the Parts guy. They are your every day steel rotor that can be turned if desired. You can use ceramic pads on these. (where as originals should not be turned) These are cheaper about 240 each? There are no other off the shelf rotors that fit the prowler as of yet. http://www.prowleronline.com/ubb/Forum6/HTML/010517.html robin This message has been edited by robin on 06-14-2017 at 02:13 PM |
posted 06-14-2017 03:26 PM
The cast iron rotors that Bill has are safe to use, It just adds a pound or so to the weight. At least with the cast rotors that he has, you will be able to use ceramic pads on the rear |
posted 06-14-2017 04:43 PM
A couple of years ago I was curious what existing applications might have compatible Rear Brake Rotors that may work on our cars AND be able to be resurfaced if needed, available, and more cost effective. I came up with one possibility from Advance Auto Parts. It appeared to be "Close" to our O.E. rotors but I as of the moment I have not gotten around to actually taking a rotor off of my car and measured or compared them to say yes or no as to compatibility. This evening when I saw this topic, it renewed my interest. I went into the Advance site and it appears this part number is no longer "Available" so I went to a cross reference chart for Bendix and found the number noted as "Obsolete". I dug a little further and wound up on the Raybestos site where I found a cross over number of 7993R With that information, I was able to come up with a few vehicles that this rear rotor is intended to fit. Chrysler Daytona 1989-1993 The specifications for these applications are as follows: Part Number: 7993R I then went to the NAPA website and looked up a 1992 Chrysler Lebaron with the 3.0 V6 and "Vented Rear Rotors" (NOT the Solid Rotors). These are the numbers for it:
1992 Chrysler Lebaron w/vented rotors Vane Configuration Reduces Temperatures & Improves Performance. The Non-Directional Finish On NAPA Premium Rotors Reduces Noise & Braking Roughness. Type K - Rotor Only. Wheel Studs Are Pressed Into The Hub Only. The Rotor Is A Loose Fit On The Hub & Is Retained By Either Machine Screws Or The Wheel Nuts. UNSPSC 25171715 If someone out there has the time and or inclination to further research the accurateness of this research, please be kind enough to post the results as it may be a benefit to us all. I hope this is of some help. NOTE: These photo's were downloaded from the Raybestos site. http://www.brakepartsinc.com/raybestos/en-us/catalog-part-search.html Once the site comes up, type in the number 7993R and these photo's and specs and cross reference of applications should become available if desired. This message has been edited by alrtg on 06-14-2017 at 04:57 PM |
GaryE POA Site Supporter and Vendor Prowler JunkieProwler Products by Gary From:Laguna Woods, CA, USA |
posted 06-14-2017 06:29 PM
Chrysler has reduced the price of the rear rotors to less than $300 each. Don't remember the exact amount. The big issue is that Chrysler is going to eliminate stocking most of their Prowler spare parts very soon. The rear brake rotor is one item they will no longer stock. Chrysler is in the process of selling most of their Prowler spare parts. |
posted 06-14-2017 07:02 PM
quote: I will be at Napa anyway tomorrow, I will check this out. If it turns out that these fit, this will be another taken care ofheadache |
posted 06-18-2017 10:21 PM
I have picked up the rotors as there are 2 possibilities with these part numbers. Its been in the upper 90s here and this old Chicago Boy does not take the heat well. As soon as it cools down a little , I will pull one of my rotors & match them up. They DO LOOK THE SAME AS THE PROWLER ONES. Both rotors are almost identical with one being a 1/4 larger. I will post as soon as it cools off. |
posted 06-19-2017 09:44 AM
Appreciate the effort Phil!!!! This will be a huge help to many and hopefully end the issue on a direct replacement rotor for the rear... |
posted 06-20-2017 01:32 PM
The Napa number is good, and it is A PERFECT FIT ! They run about $ 39.00 each |
posted 06-20-2017 01:47 PM
Well Well look at that alrtg You did it ..New rotors for 40 bucks can't beat that....Thanks for the info....robin thanks for the confirmation Phil . I will retire now. As I'm sure Rich is looking for the next prowler item to challenge me on.... |
posted 06-20-2017 02:50 PM
We need to come up with the computer now |
posted 06-20-2017 05:22 PM
Thank You all involved in doing the leg work for a compatable rear rotor. |
posted 06-20-2017 09:07 PM
Thanks to ALL who contributed to this solution to an expensive problem. I guess my two spare OEM rotors are now worth a lot less than I paid for them. |
posted 06-20-2017 09:26 PM
So I buy 2 kats....come onto this forum a year ago ...buy doing that I now know how to save over 2k in rear rotors(both cars) if I need them.....and YOU STILL HAVE PEOPLE WHO WONDER WHY I CONTRIBUTE MONEY TO A FORUM THAT I CAN BROWSE FOR FREE.......PPPPPPPLEASE SPARE ME......Good job guys.....luv it.....jim This message has been edited by 401KAT on 06-20-2017 at 09:28 PM |
posted 06-20-2017 11:06 PM
SORRY ABOUT THAT ED ! |
posted 06-21-2017 12:05 AM
Nothing to be sorry about. I am glad folks are trying to help ALL of us out by solving these problems. I hope I never have to use any rear rotors, aluminum or otherwise. I sure hope someone solves the computer problems in the near future and makes my spares worth a lot less, also. |
posted 06-21-2017 08:07 AM
quote: There will always be members here that want to keep their Prowlers stock, So selling them , most likely won't be a problem. I am taking the cast ones off my car today & having them drilled & slotted for a better look and will continue to use the stock ones until one cracks or wears out. Just glad ALRTG was able to come up with a part number to try. Make sure when you order them to use the NAPA number only as the other number is for a rotor 1/4 inch larger in diameter. If anyone decides to not use NAPA, most likely any good auto parts store will be able to cross this number to a different brand. This same rotor is made by many different manufactors under different names This message has been edited by phil2237 on 06-21-2017 at 08:12 AM |
posted 06-21-2017 09:35 AM
BOOM!!!!!!!!!!!!!! FANTASTIC NEWS!!!!! What a Team!!!!!!! alrtg... This started with you and your amazing persistence on this topic (Beyond measure the info you shared)!!! Phil... Thanks so much for all the effort in confirming the replacement!!!! This is a HUGE WIN for EVERYONE!!!!!!!! |
posted 06-21-2017 11:39 AM
Think you were hit hard ED . I just purchased the remaining stock from Chrysler... Hence my little story to Rich.....
I have 4000 sets of OEM rotor 50 Canadian dollars each . |
posted 06-24-2017 09:06 PM
Hi all, I am glad that the information I gathered proved to be of some use to those of us out there that are in the market for an alternative rear rotor. Having just returned from a week's vacation, this is great news. I had deliberately left the laptop home and since my 15 year old cell phone only makes and gets phone calls, I was "off the grid" as well. FYI, The Prowler turned 52K today on the way home from South Carolina. This message has been edited by alrtg on 06-24-2017 at 09:18 PM |
posted 06-25-2017 08:34 AM
Thanks to all for their persistence in getting this accomplished. One less item to worry about down the road. If we can get the PCM / TCM issues resolved, I think we'll be in great shape for the future. |
RDinTN POA Site Supporter Prowler Junkie From:Beautiful East Tennessee |
posted 06-25-2017 09:18 AM
Kudos to those who make things happen & congrats to us all!! This message has been edited by RDinTN on 06-25-2017 at 09:19 AM |
posted 06-29-2017 05:33 PM
Just for future reference, the following post has additional information related to these rotors. http://www.prowleronline.com/ubb/Forum1/HTML/024112.html#4 |
posted 10-15-2020 02:25 PM
it states in it's specs that the bolt diameter pattern is 5x100, the bolt pattern for a prowler is 5x114.3 Just by bolt pattern they won't fit. This message has been edited by mslc10 on 10-15-2020 at 02:29 PM |
