Author | Topic: Transmission and Guages |
NeverBland Prowler Junkie From: |
posted 04-09-2018 07:04 PM
Car has been running fine. Stopped to run an errand, turned the car back on, transmission seemed to be stuck in first gear (limp mode?). Gauge cluster seemed to have all gears selected (square box around PRND on the readout). Turned ignition off and back on, all gauges except voltage were are off. Instrument cluster readout and tach also off. Pulled #10 and #11 fuses, no change I thought it might be trans sensor, but I thought those only made the speedo turn off, not most of the gauges. Ideas? |
posted 04-09-2018 07:42 PM
Cheapest and a easy fix is to change both input and output sensors. Then go from there.
Output Sensor (Part# 04800879)
This message has been edited by robin on 04-10-2018 at 12:53 PM |
posted 04-09-2018 08:40 PM
Just came back from buying sensors in case they were the problem. Instrument cluster fuse was blown, gauges kick back on with new fuse, but as soon as trans downshifts, it blows the fuse again. Would that be a symptom of bad trans sensors? Managed to pull code p1698... |
posted 04-10-2018 07:35 AM
P1698 - No messages coming from the TCM. Located in the trunk, check the plug for corrosion, clean and resecure. Also check the ground. The fuse blew due to a short or a spike in voltage. The missing output messages (data) from the TCM control the things that you saw on the dash. |
posted 04-11-2018 01:40 PM
Replaced both transmission sensors on Monday night (not fun getting to the further one), and reset the computer. Car was running fine yesterday. Today symptoms came back. Took apart TCM to check for issues. Everything was clean, but I made sure everything was tight (including ground). TCM Board is potted in soft epoxy, so couldn't take the board out to check... What should I be checking next? |
posted 04-11-2018 02:04 PM
what year prowler?
This message has been edited by robin on 04-11-2018 at 02:07 PM |
posted 04-11-2018 02:25 PM
2001. |
posted 04-11-2018 02:32 PM
did you erase the code p1698...If not erase and reset computer and then try the car again. If you're able to find a competent garage have them do a deeper scan to see if they can pin point if it's one of the sensors mentioned above.
This message has been edited by robin on 04-11-2018 at 02:34 PM |
posted 04-11-2018 02:38 PM
Yes, cleared all codes after replacing transmission sensors. |
posted 04-11-2018 07:52 PM
I presume you already disconnected the battery and waited about 10 minutes for it to reset. That should clear the code. It may reappear, of course. |
posted 04-11-2018 07:53 PM
quote: Yes, after I replaced the transmission sensors. |
